Thank you!
Curious how to configure the 8 button Insteon remote for music playing. I know how to actually configure it of course, more so the question is which buttons do you use for which purpose that provides the best user experience?
-Josh
jmortizsilva wrote:Hi there,
I'm using version v0.9.1 and I can not access my favorite or my radio stations.
When creating a new action, I choose Sonos: RadioTime Favorite Station or Sonos Favorites and when trying to configure the settings drop-down to select the radio station or favorites are empty.
I am doing something wrong?
In previous versions of the plugin if it was able to make this choice.
Thank you
Thank you very much, I disabled the plugin and I've been reactivated and now it works.
One question, is it possible to consolidate multiple devices in the same action?
I would like to play a radio station in my two speakers have tried to include two devices in the same action, but not synchronized, you go a little earlier than the other.
I want to do is play the same in two rooms at a time in sync.
MarcoGT wrote:I have build a small CP putting info on what in currently being played (the Sonos_art.jpg, I think is called), volume adjustments, play/pause and links to play my favourites radio.
What happens is: I play Radio Indigo ( ) and I get the icon for Radio Indigo, then I pause/stop it but the icons is the same, how can I change it based on the current status (play/pause)?
RAID5 wrote:Hi
When I try to adjust the volume, only one volume change is applied, the next coming button pushes does not change the volume. If I restart the SONOS plugin it temporarly solves the problem.
Any suggestions?
/RAID5
Sent from my iPhone with Tapatalk
RAID5 wrote:I use a action under the button
/RAID5
