Sonos 2023.1.0
Thu Jan 11, 2024 11:01 am
Colly offline
Sonos 2023.1.0
Hi Jon,
Getting the following errors after upgrading to latest version. Plugin appears to be working fine all the same.
   Upgrading plugin Sonos to newer version 2023.1.0 (previous version moved to trash)
   Loading plugin "Sonos 2023.1.0" using API v3.1
   Starting plugin "Sonos 2023.1.0" (pid 73908)
   Sonos                           Plugin logging now started.
   Sonos                           Distribution: Package=lxml, Version=4.9.2
   Sonos                           Loaded Sonos Favorites... [7]
   Sonos                           Loaded Playlists... [6]
   Sonos                           Loaded RadioTime Favorite Stations... [5]
   Sonos                           [Thu Jan 11 16:51:02 2024] Processed plugin preferences.
   Sonos                           Plugin __init__ ended.
   Started plugin "Sonos 2023.1.0"
   Sonos                           Plugin startup started.
   Sonos                           Loaded Apple Voices.. [48]
   Sonos                           SSDP Listener Started...
   Sonos                           Plugin startup ended.
   Sonos                           Serving HTTP Streamer on 127.0.0.1 [0.0.0.0], port 8888
   Sonos                           Adding ZonePlayer: 192.168.1.26, RINCON_5CAAFD2D9AD001400, Sonos Kitchen
   Sonos                           Adding ZonePlayer: 192.168.1.242, RINCON_5CAAFD2D999E01400, Sonos Master Bedroom
   Sonos                           SoCo Reactor Ignition...
   Trigger                         Sonos Master Off
   Sonos Error                     'HTTP Error 403: Forbidden' in module 'request.py', method 'http_error_default [2023.1.0]'
   Failing statement [line 643]: 'raise HTTPError(req.full_url, code, msg, hdrs, fp)'
   Trigger                         Sonos Kitchen
Users browsing this forum: Google [Bot] and 11 guests
