Announcement not working and Indigo Edit Window gets timeout
Wed Nov 22, 2023 3:26 am
MarcoGT offline
Hi all,
I have installed the last available version (.027) but I noticed that announcement are not working.
But, on top of that, after having executed the announcement action, I noticed that I cannot open the edit UI related to the Sonos plugin (where the announcement is defined) and I get following errors:
Error (client)                  timeout waiting for plugin response from com.ssi.indigoplugin.Sonos for request UiGetValues2
   Error (client)                  timeout waiting for plugin response from com.ssi.indigoplugin.Sonos for request CallPluginFunc
   Error (client)                  dialogForActionId() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
The only solution is to restart the plugin
Thu Nov 23, 2023 7:49 am
MartynD offline
Re: Announcement not working and Indigo Edit Window gets tim
Hi
I have the same issue...............
Martyn
Thu Nov 23, 2023 10:48 am
Can you try this pre-release version: Sonos Plugin Version 2023.0.30
Probably won't fix the issue but it will get you on the latest code-base and is worth a try.
I will do some more testing to see if I can reproduce it.
Fri Nov 24, 2023 3:23 am
MarcoGT offline
Unfortunately I get the error (on the UI)
Impossibile to Install the plugin, please contact the developer
:wink:
Fri Nov 24, 2023 5:02 am
I am unclear from your description as to where you are seeing this error.
Is it when you try and install the plugin?
I have just downloaded pre-release version 2023.0.30 and successfully installed it and it is running OK.
Fri Nov 24, 2023 5:23 am
I have just tried an announcement using version 2023.0.30 and it is working fine on my system. Having played the announcement, I can also edit the announcement action, modify the announcement, save it and execute it again successfully.
What source (voice) are you using in the action?
Fri Nov 24, 2023 6:55 am
MarcoGT offline
Yes, when installing the .30 I get the Indigo Message (UI) saying that there is an error (see attachment)
Fri Nov 24, 2023 7:24 am
Try deleting the downloaded plugin, download it again and try it again and see if the same error occurs.
In the meanwhile, I will attempt to find out what causes that (what looks to be an Indigo) message to appear.
Sun Nov 26, 2023 2:03 am
MarcoGT offline
No chance, downloaded twice, also from a different Mac, same issue
Tue Nov 28, 2023 11:45 am
When you try and install the plugin, is there anything shown in the Indigo Event Log and if so what?
Wed Nov 29, 2023 1:27 am
MarcoGT offline
This is what I get in the Error Log window
InstallPlugin() caught exception: FileIOError -- unable to get last mod time for file (file not found)
Wed Nov 29, 2023 7:16 am
Looks like file corruption of some sort.
You could try the following:
  • Shutdown the Indigo Server
  • Delete the existing Sonos plugin from the Indigo Plugins folder which is at /Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins - change the Indigo version as appropriate.
  • Start the Indigo server
  • Once the Indigo Server has started and all plugins have been started, try and install the Sonos plugin again
Please report back on output from the Indigo Event Log.
Wed Dec 13, 2023 8:21 am
MarcoGT offline
Update:
I was able to install the new version, but when try an announcement I get the popup saying that the plugin is coming from a not-verified developer:
13. Dec 2023 at 15:20:32
   Sonos                           Announcement: Chiudi tende terrazza, Volume: 30
   Sonos                           remove zone from group: Sonos-Corridoio-OG
   Sonos                           ZonePlayer: Sonos-Corridoio-OG, Current Volume: 8, New Volume: 30
   Sonos                           ZonePlayer: Sonos-Corridoio-OG, Play
   Sonos                           Announcement Length: 0.653
This appears when I click on "cancel" on the popup error
   Sonos Error                     UPNP Error: No Such Object
   Sonos Error                     Offending Command -> zoneIP: 192.168.2.244, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Play
   Sonos Error                     Error Response: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>701</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>
   Sonos                           ZonePlayer: Sonos-Corridoio-OG, Clear Queue
Wed Dec 13, 2023 10:33 am
I suspect the error is being triggered by the plugin using an embedded LAME MP3 Encoder for announcements.
Try running the following in a Terminal window:
sudo xattr -rd com.apple.quarantine /Library/Application\ Support/Perceptive\ Automation/Indigo\ 2023.1/Plugins
Then reload the plugin.
Wed Dec 13, 2023 10:48 am
ryanbuckner offline
I'm also unable to get this working:
- - group announcement .mp3
- - source: Apple Speech
- - errorCode>701 : Looks like maybe it's trying to pause a player that is not playing ?
Dec 13, 2023 at 11:41:15 AM
   Action Group                    Test SONOS Announcements
   Sonos                           Announcement: Hi there, whats' up. Trying to test this out., Volume: 30
   Sonos                           remove zone from group: SONOS - Family Room Speaker
   Sonos                           ZonePlayer: SONOS - Family Room Speaker, Current Volume: 34, New Volume: 30
   Sonos                           ZonePlayer: SONOS - Family Room Speaker, Play
   Sonos                           Announcement Length: 3.84
   Sonos Error                     Offending Command -> zoneIP: 192.168.1.191, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Play
   Sonos                           ZonePlayer: SONOS - Family Room Speaker, Clear Queue
