Sonos Python 3 Beta
Wed Oct 04, 2023 9:36 am
Re: Sonos Python 3 Beta
Londonmark wrote:
Jon - really no problem at all. Great if you manage to look at it at some stage, but also understand if you never get round to it. Life...
Interestingly, my Intel Mac is showing all states but my M1 mini isn't.
I will dig deeper and try and figure out why that is happening.
Are you on an Apple Silicon Mac?
Wed Oct 04, 2023 9:52 am
rapamatic offline
autolog wrote:
No that isn't documented. What was the prompt to ask you to install Xcode command line tools?
I already have them installed which is probably why I have missed it being a requirement.
Are you on an Intel or Apple Silicon Mac?
I'm on an apple silicon Mac. The prompt was in terminal/pip when I was trying to install the libxml library, I believe. Some message about not being able to create a "wheel" or something like that... It suggested installing Xcode tools and gave the command to do so.
autolog wrote:
I think Pandora should work. I users have reported it working OK.
What message are you getting from the plugin?
I'm getting this message at plugin start:
   Sonos Error                     'User not yet authenticated' in module 'pandora.py', method 'check_authentication [2023.0.27]'
   Failing statement [line 12]: 'raise ValueError("User not yet authenticated")'
I open config, enter username, password, but then nothing seems to happen and I don't see any pandora stations when I create/edit actions to play a station
Wed Oct 04, 2023 10:21 am
mvignola29 wrote:
After running the updated plugin I get the following message in the indigo log
Oct 4, 2023 at 11:07:58 AM
Upgrading plugin Sonos to newer version 2023.0.27 (previous version moved to trash)
Error ReloadPlugin() caught exception: FileIOError -- rename/move of file or folder failed -- check file/folder permissions
Not sure what to do next, any help is appreciated
That usually means you have a permission problem in the Indigo install directories. Rerunning the installer may fix it?
It might also mean that somehow you have duplicates of the same plugin both in the Plugins directory and in the Plugins (Disabled) directory. If so, delete the one in the Plugins (Disabled) directory.
Wed Oct 04, 2023 1:55 pm
mvignola29 offline
mvignola29 wrote:
... I am not familiar in doing any programming. The Beta Sonos still not work, ...
What version of Indigo are you running?
I am running 2023.1
When you started the plugin, did it ask you to update lxml?
No
In terminal, you can run the command to update pip i.e.
/Library/Frameworks/Python.framework/Versions/3.10/bin/python3.10 -m pip install --upgrade pip
It will avoid the error message coming out next time.
I did this and I still do not see the plugin listed in menu of plugin choices
When you say The Beta Sonos still not work, what do you mean by that.
I assume this new version was a beta but I now realize that it was release to the public
What messages appeared in the log. I need more information to help you. :)
ct 4, 2023 at 3:41:02 PM
Installing and enabling plugin Sonos v2023.0.27
Reloading plugin "Web Server 2023.1.0" using API v3.3
Stopping plugin "Web Server 2023.1.0" (pid 81013)
Reflector shutdown reflector connection
Stopped plugin "Web Server 2023.1.0"
Starting plugin "Web Server 2023.1.0" (pid 5448)
Started plugin "Web Server 2023.1.0"
Web Server starting internal Web server on http://localhost:8176
Bonjour registered "Indigo - Bryson 37 (v2021.1.2) (v2021.1.2)"
Reflector starting reflector connection to https://mvignola29.indigodomo.net
Oct 4, 2023 at 3:42:40 PM
Sent INSTEON "Office MPV" on to 100
Sent INSTEON "Office MPV" off
Oct 4, 2023 at 3:43:13 PM
Stopping plugin "Web Server 2023.1.0" (pid 5448)
Starting plugin "Web Server 2023.1.0" (pid 5602)
I appreciate your help
Thank you
Michael
Wed Oct 04, 2023 2:29 pm
Hi Michael,
I think this is the same error @rapamatic is seeing (see above).
The error you are getting usually means you have a permission problem in the Indigo install directories. Rerunning the installer may fix it?
Wed Oct 04, 2023 3:57 pm
Londonmark offline
Yes. M2 Studio.
Thu Oct 05, 2023 7:46 am
mvignola29 offline
I have run the indigo installation app again, still have no access to Sonos plugin that I also re-installed. Can not find the plugin disable directory. I can not find any of the indigo directories which I assume must exist somewhere. I have looked in the library/application support as well as many other directories. Can you please give me the path as to where these folder should be.
Any help is greatly appreciated
Michael
Thu Oct 05, 2023 9:23 am
mvignola29 wrote:
.... Can not find the plugin disable directory. ...
The Indigo 2023.1 files are located here: /Library/Application Support/Perceptive Automation/Indigo 2023.1
Access this folder by going to the Finder main menu > Go > Go to Folder...
Copy and paste the folder path above.
The Indigo 2023.1 folder contains the Plugins and Plugins (Disabled) folders. :)
Thu Oct 05, 2023 10:54 am
mvignola29 offline
Thank you for the path info. In any event I wonder because I have using Indigo software for many years I tried to attach a screen shoot showing all of the version of the aPP I have over the years. In the folder for the latest version in plugin folder the Sonos is not listed as well as the disable folder.
I do not know why the System is not allowing me to post the screen shot
but when I add the attachment it post it above my comments
Screenshot 2023-10-05 at 12.33.44 PM.jpeg (49.7 KiB) Viewed 110282 times
Thu Oct 05, 2023 11:01 am
mvignola29 offline
Here is another screen shot of the plugin disabled
plug d.jpeg (36.84 KiB) Viewed 110277 times
Screenshot 2023-10-05 at 12.33.44 PM.jpeg (49.7 KiB) Viewed 110277 times
Thu Oct 05, 2023 11:13 am
This is a bit of a mystery. :?
Just in case the wrong Indigo Client is being activated, can you double check the plugin folders in the Indigo 2022.2 folder i.e.: /Library/Application Support/Perceptive Automation/Indigo 2022.2 to see if the plugin is there?
Fri Oct 06, 2023 7:39 am
mvignola29 offline
After restarting my Mac the Sonos plug-in, I finally was able to install the sonos plugin. After installing and running the plug-in I'm getting it permission errors. Not sure what to do. At this point. I contacted Apple support and they were not able to determine that there was anything wrong with my operating system and permission settings. We ran the system in safe mode as Apple suggested, and the problem still exist.
I attached the system event log, not sure what to do next I hope there is a setting you're able to change the permissions for these files.
Thank you for your help. I truly appreciate it
Michael
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Font Yard_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Failing statement [line 1378]: 'localFile = open("/Library/Application Support/Perceptive Automation/images/Sonos/"+ZP_ZoneName+"_art.jpg", "wb")'
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Patio Deck_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Living Room_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Portable_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Sonos Loaded Playlists... [15]
Oct 6, 2023 at 9:25:33 AM
Oct 6, 2023 at 9:29:43 AM
Oct 6, 2023 at 9:30:16 AM
Oct 6, 2023 at 9:30:40 AM
Fri Oct 06, 2023 8:06 am
Can you look at what the permissions are set to for the folder images in folder: /Library/Application Support/Perceptive Automation
In Finder, right click on the images folder, click on Get Info and check what the permissions are set to at the bottom. Also do the same for the Sonos folder in the images folder.
Maybe this info may shed some light on the issue?
Fri Oct 06, 2023 8:55 am
mvignola29 offline
I have selected the folders you indicated and in both folder the info box indicates
Me Read & write
Admin Read & write
Everyone Read & write
Michael
Fri Oct 06, 2023 9:08 am
mvignola29 wrote:
Me Read & write
Admin Read & write
That's even more confusing :?
unfortuantely, I am not sure what to suggest next at the moment.
What type of Apple Mac are you using for Indigo?
