- Shutdown the Indigo Server
- Copy the Sonos plugin into Indigo's plugin directory at:
- Code: Select all
/Library/Application Support/Perceptive Automation/Indigo 2023.1/Plugins
- Restart the Indigo Server
Reloading plugin "Sonos 2023.0.27" using API v3.1
Stopping plugin "Sonos 2023.0.27" (pid 74054)
Sonos SoCo Reactor Landing...
Stopped plugin "Sonos 2023.0.27"
Starting plugin "Sonos 2023.0.27" (pid 81422)
Sonos Plugin logging now started.
Sonos Loaded Sonos Favorites... [12]
Sonos Loaded Playlists... [13]
Sonos Loaded RadioTime Favorite Stations... [0]
Sonos Loaded Sound Files... [44]
Sonos Error 'User not yet authenticated' in module 'pandora.py', method 'check_authentication [2023.0.27]'
Failing statement [line 12]: 'raise ValueError("User not yet authenticated")'
Sonos [Wed Nov 8 20:26:15 2023] Processed plugin preferences.
Sonos Plugin __init__ ended.
Started plugin "Sonos 2023.0.27"
Sonos Plugin startup started.
Sonos Serving HTTP Streamer on 10.0.1.77 [0.0.0.0], port 8888
Sonos Loaded Apple Voices.. [143]
Sonos SSDP Listener Started...
Sonos Plugin startup ended.
Sonos Adding ZonePlayer: 10.0.1.58, RINCON_000E58750DD801400, SonosSpkr_AlanaKit
Sonos Adding ZonePlayer: 10.0.1.59, RINCON_000E58C1855C01400, SonosSpkr_AlanaLR
Sonos Adding ZonePlayer: 10.0.1.60, RINCON_5CAAFD46046201400, SonosSpkr_AlanaWR
Sonos Adding ZonePlayer: 10.0.1.19, RINCON_542A1B85ABF101400, SonosSpkr_Beam
Sonos Adding ZonePlayer: 10.0.1.43, RINCON_B8E93747BD1501400, SonosSpkr_FrontPorch
Sonos Adding ZonePlayer: 10.0.1.36, RINCON_7828CA2979BA01400, SonosSpkr_Garage
Sonos Adding ZonePlayer: 10.0.1.25, RINCON_000E58723DEE01400, SonosSpkr_MBR
Sonos Adding ZonePlayer: 10.0.1.27, RINCON_000E58735A2001400, SonosSpkr_Office
Sonos SoCo Reactor Ignition...
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Basement - KT_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Failing statement [line 1378]: 'localFile = open("/Library/Application Support/Perceptive Automation/images/Sonos/"+ZP_ZoneName+"_art.jpg", "wb")'
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Basement - LvRm_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
Sonos Error '[Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images/Sonos/Basement - WR_art.jpg'' in module 'Sonos.py', method 'processArt [2023.0.27]'
wideglidejrp wrote:I am trying to add a bit more of a pause after each period in the text I submit for Polly. I inserted <break time="1000ms"/>. I got the following response.
aldera wrote:Hi,
Running Indigo 2023.1 on a Macmini (M1) with Ventura 13.0.1 OS.
I installed all the python libraries and got the plugin running. However, I'm not sure how to fix the last 3 errors in the code below. There are no image files in the directory specified and there never were any image files in the prior version. I'm not a Unix guy so I don't really know how to fix it. Thanks for any help.
- Code: Select all
aldera wrote:I got the 3 Sonos errors fixed. I just added three jpg files with the same names given in the error messages and now it's working fine.
Sonos Error ''NoneType' object has no attribute 'startSpeakingString_toURL_'' in module 'Sonos.py', method 'actionAnnouncement [2023.1.0]'
Failing statement [line 2579]: 'sp.startSpeakingString_toURL_(announcement, ru)'
MarcoGT wrote:With the last version on the plugin store I get following error
- Code: Select all
