Plugin not finding Play: 1's
Fri Apr 27, 2018 10:23 am
bjones offline
Hey Nick, new Sonos user here. I've gone through the initial setup of the plugin and I am getting the errors below. Indigo doesn't seem to see my speakers.
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 375, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 499, in socoSubTest
KeyError: (1202406921,)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any help would be greatly appreciated!
Fri Apr 27, 2018 11:27 am
nlagaros offline
Re: Plugin not finding Play: 1's
Can you restart the plugin and post all the log output. Thanks.
Fri Apr 27, 2018 11:42 am
bjones offline
Thanks for the fast response, Nick. I restarted the plugin, cleared the prefs/reinstalled, and checked my port reservations. Here's the most recent log:
Sonos Error Error in plugin execution runConcurrentThread:
Fri Apr 27, 2018 11:50 am
nlagaros offline
There should be output before what you posted. It should look something like this:
   Sonos                           Your plugin version, v1.0.12, is current.
   Sonos                           Using Reference ZonePlayer IP: 192.168.0.62
   Sonos                           Loaded Sonos Favorites... [8]
   Sonos                           Loaded Playlists... [43]
   Sonos                           Loaded RadioTime Favorite Stations... [14]
   Sonos                           Loaded Sound Files... [0]
   Sonos                           Serving HTTP Streamer on 192.168.0.5 [0.0.0.0], port 8888
   Sonos                           Loaded Pandora Stations for Nick... [14]
   Sonos Error                     [Fri Apr 27 13:27:17 2018] SiriusXM SessionID error, check credentials
   Sonos                           Loaded IVONA Voices... [51]
   Sonos                           Loaded Polly Voices... [52]
   Sonos                           [Fri Apr 27 13:27:17 2018] Processed plugin preferences.
   Sonos                           Loaded Apple Voices.. [47]
   Sonos                           SSDP Listener Started...
   Sonos                           Adding ZonePlayer: 192.168.0.63, RINCON_B8E93770DE6B01400, Sonos: Cave
   Sonos                           SoCo Reactor Ignition...
Fri Apr 27, 2018 11:53 am
bjones offline
FYI I am running v1.0.12, both of my Play:1's are on 8.5 (build 42251240)
Reloading plugin "Sonos 1.0.12"
   Stopping plugin "Sonos 1.0.12" (pid 7427)
   Sonos Error                     Cannot unsubscribe from avTransport events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from renderingControl events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from zoneGroupTopology events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from queue events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from groupRenderingControl events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from contentDirectory events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from groupManagement events for ZonePlayer: Basement Sonos
   Sonos Error                     Cannot unsubscribe from avTransport events for ZonePlayer: Living Room Sonos
   Sonos Error                     Cannot unsubscribe from renderingControl events for ZonePlayer: Living Room Sonos
   Sonos Error                     Cannot unsubscribe from zoneGroupTopology events for ZonePlayer: Living Room Sonos
   Sonos Error                     Cannot unsubscribe from queue events for ZonePlayer: Living Room Sonos
   Sonos Error                     Cannot unsubscribe from groupRenderingControl events for ZonePlayer: Living Room Sonos
   Sonos Error                     Cannot unsubscribe from contentDirectory events for ZonePlayer: Living Room Sonos
   Sonos Error                     Cannot unsubscribe from groupManagement events for ZonePlayer: Living Room Sonos
   Sonos                           SoCo Reactor Landing...
   Stopped plugin "Sonos 1.0.12"
   Starting plugin "Sonos 1.0.12" (pid 7483)
   Started plugin "Sonos 1.0.12"
   Sonos                           Using Reference ZonePlayer IP: 192.168.7.116
   Sonos                           Loaded Sonos Favorites... [0]
   Sonos                           Loaded Playlists... [0]
   Sonos                           Loaded RadioTime Favorite Stations... [0]
   Sonos                           Serving HTTP Streamer on 192.168.7.112 [0.0.0.0], port 8888
   Schedule                        Floor Lamp Dim
   Sent Hue Lights                 "Living Room Floor Lamp (White)" on to 2 at ramp rate 5.0 sec.
   Sonos                           [Fri Apr 27 13:52:46 2018] Processed plugin preferences.
   Sonos Error                     Error in plugin execution startup:
  File "plugin.py", line 36, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 286, in startup
  File "./lib/twisted/internet/posixbase.py", line 382, in listenMulticast
  File "./lib/twisted/internet/udp.py", line 178, in startListening
  File "./lib/twisted/internet/udp.py", line 198, in _bindSocket
CannotListenError: Couldn't listen on any:1900: [Errno 48] Address already in use.
   Sonos                           Adding ZonePlayer: 192.168.7.118, RINCON_7828CA2CA4E401400, Basement Sonos
   Sonos Error                     exception in deviceStartComm(Basement Sonos): need more than 0 values to unpack
   Sonos                           Adding ZonePlayer: 192.168.7.116, RINCON_7828CA22D40601400, Living Room Sonos
   Sonos Error                     exception in deviceStartComm(Living Room Sonos): need more than 0 values to unpack
Fri Apr 27, 2018 12:03 pm
bjones offline
See attached for current config. Thanks!
Screen Shot 2018-04-27 at 2.02.35 PM.png (260.89 KiB) Viewed 2005 times
Fri Apr 27, 2018 12:05 pm
nlagaros offline
It looks like you have something else running that is locking port 1900. That is likely what is causing the errors.
Fri Apr 27, 2018 1:49 pm
bjones offline
Thanks, Nick! This has been resolved.
Looks like HD Homerun was messing with that. I wiped that out of existence and it is working as expected.
