How to check if speaker isn't actively playing music
Mon Oct 09, 2017 8:55 am
zini offline
I am trying to create a trigger that will periodically check and see if my zones are actively playing music, and if not, will restart them playing a favorite station.
Sorry if this has been covered somewhere, but I haven't been able to find this anywhere. What variable do I use to accomplish this? Assuming it's under the "device state changed" options.
Thank you in advance!
Mark
Mon Oct 09, 2017 8:59 am
roussell offline
Re: How to check if speaker isn't actively playing music
I do something similar in a few situations; I forget the exact trigger, but I check the state of the device and if the state "is not playing", I do some action. I can look a little later and see exactly what it is if you can't find it.
Terry
Mon Oct 09, 2017 9:08 am
roussell offline
Actually, I did trigger off of any change. Here is an example that turns off a sub amp on the patio if the Sonos outside isn't playing. I did it this way to avoid the trigger firing when the Sonos is transitioning between songs/stations/playlists.
Screen Shot 2017-10-09 at 10.02.13 AM.png (61.06 KiB) Viewed 1646 times
Screen Shot 2017-10-09 at 10.05.32 AM.png (120.99 KiB) Viewed 1646 times
Screen Shot 2017-10-09 at 10.02.50 AM.png (79.91 KiB) Viewed 1646 times
Terry
Tue Oct 10, 2017 9:16 am
zini offline
Terry,
Awesome! Thanks for the quick response. I used the same setup you use and it seems to be working great. This is a great method to keep music always on, even if something like an internet stream times out.
Mark
Thu Oct 12, 2017 10:04 am
zini offline
Terry,
Is there a published list somewhere of the speaker states for the plugin? When I run the STOPPED and PAUSED states as conditions in a schedule it doesn't seem to work. If I manually execute the schedule, it works perfectly. So it seems like it's something with the plugin not properly understanding the state of the speaker.
Any thoughts?
Mark
Thu Oct 12, 2017 10:16 am
Have you checked the custom states listed beneath the device in the main Indigo UI?
Select a device in the main UI and then make the display in the lower pane larger or scroll it. I don't use the Sonos plugin (I haven't got any Sonos devices :wink: ) but plugins list their custom states in the lower pane.
This may help if you haven't discovered these already. :)
Fri Oct 13, 2017 9:51 am
zini offline
Ahhh... got it. Makes sense. This helps a lot! By looking at these, I was able to figure out that changing the condition to "contains" instead of "equals" has solved my issue.
Thanks for the help!
Mark
