Need some help with initial setup
Sat Oct 07, 2017 11:40 am
zini offline
I am getting back into running Indigo after a few years and I went to install the Sonos plugin (that I had running successfully a couple years ago) and am getting the following error. Not sure why - I have static IP's set on all of my zone players and I've tried inputting each one under the "Reference ZonePlayer ID" in the plugin config menu.
I seem to get the same "Cannot start HTTP streamer" error no matter which IP I put in.
Started plugin "Sonos 1.0.6"
   Sonos                           Your plugin version, v1.0.6, is current.
   Sonos                           Loaded Sonos Favorites... [16]
   Sonos                           Loaded Playlists... [10]
   Sonos                           Loaded RadioTime Favorite Stations... [1]
   Sonos                           [Sat Oct  7 13:32:39 2017] Processed plugin preferences.
   Sonos                           Loaded Apple Voices.. [47]
   Sonos Error                     Cannot start HTTP Streamer on None: [Errno 8] nodename nor servname provided, or not known
   Sonos                           SSDP Listener Started...
   Sonos                           Adding ZonePlayer: 192.168.7.91, RINCON_000E58F8F5D201400, Sonos Bar
   Sonos                           SoCo Reactor Ignition...
   Sonos                           ZonePlayer: Sonos Bar, Cannot Save Queue for Slave
Any help would be appreciated. I hope I am not forgetting or missing something obvious! Thank you!
Mark
Tue Oct 10, 2017 9:19 am
zini offline
Re: Need some help with initial setup
Just an update -
I have the plugin working well with all of my zones now, EXCEPT I am still getting the "cannot start HTTP streamer" error. It doesn't seem to matter except that I can't use the group announcement mp3 option - as of now, that seems to be the only feature that throws an error every time I try to use it.
I definitely want to use the announcement feature so any advice would be appreciated. Thanks.
Mark
Tue Oct 10, 2017 1:07 pm
zini offline
To be clear, here is the error I get when trying to execute a group mp3 voice announcement:
Oct 10, 2017, 3:04:58 PM
   Trigger                         voice test
   Sonos                           Announcement: voice check, Volume: 50
   Sonos                           remove zone from group: Sonos Bar
   Sonos                           ZonePlayer: Sonos Bar, Current Volume: 35, New Volume: 50
   Sonos                           Announcement Length: 0.937868480726
   Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 198, in actionZP_announcementMP3
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1931, in actionAnnouncement
TypeError: cannot concatenate 'str' and 'NoneType' objects
Mark
Tue Oct 10, 2017 1:09 pm
zini offline
When using the plugin to group zones, I get this error (even though it does successfully group the zones):
Oct 10, 2017, 3:08:14 PM
   Trigger                         If bar has no music, group with MZ2
   Sonos                           add zone to group: 1147208120
   Sonos Error                     UPNP Error: Invalid Args
   Sonos Error                     Offending Command -> zoneIP: 192.168.7.94, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetAVTransportURI
   Sonos                           add zone to group: 260454114
   Sonos                           add zone to group: 1863342814
   Sonos                           add zone to group: 453756819
   Sonos                           add zone to group: 330921376
Mark
Tue Oct 24, 2017 11:03 am
zini offline
So I got the mp3 announcements working. I realized I had to specify a player IP in the Streaming IP settings under the plugin config. Sorry about that. :roll:
Still getting the "UPNP Error, Offending Command" error, but it doesn't seem to be effecting the plugin because everything seems to be working.
Mark
