Sonos 1.06 Error
Mon Oct 02, 2017 1:15 pm
pgershon offline
Sonos 1.06 Error
Not sure when it started, but:
Oct 2, 2017, 3:12:14 PM
Trigger Start-Up
Email Sent to "pgershon@me.com"; subject "Indigo2 Start-up (Hamptons)"
Connected to PowerLinc 2413U interface on port usbserial-A60332O9
PowerLinc address 34.7A.BB, firmware version 9.14
Reloading plugin "Sonos 1.0.6"
Stopping plugin "Sonos 1.0.6" (pid 1102)
Stopped plugin "Sonos 1.0.6"
Starting plugin "Sonos 1.0.6" (pid 1109)
Started plugin "Sonos 1.0.6"
Sonos Your plugin version, v1.0.6, is current.
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos-3.indigoPlugin/Contents/Server Plugin/Sonos.py", line 268, in startup
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 150, in makedirs
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 157, in makedirs
OSError: [Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images'
Any ideas?
Tue Oct 24, 2017 2:52 pm
az138 offline
Re: Sonos 1.06 Error
It sounds like you don't have the proper access to that directory.
Mine show the following permissions:
drwxr-xr-x
From the command line, do the following to check the permissions:
ls -l /Library/Application\ Support/Perceptive\ Automation/images/
