Playing Sonos favourite track error
Tue Jul 25, 2017 8:20 am
siclark offline
I am able to get favourite radio stations and playlists to play with the plugin, but when I select a single favourite track to play now, I get this error.
Sonos I do not know what to do with Favorite: x-sonos-spotify:spotify%3atrack%3a600HVBpzF1WfBdaRwbEvLz?sid=9&flags=8224&sn=3
I was hoping it would work the same as the Sonos app, i.e. interrupt the current playlist, start playing the selected track, then continue the playlist. I have tried both Amazon and Sonos tracks and these ame issue occurs.
Is this an issue on my end, or does it only work on local tracks, or not at all?
Tue Jul 25, 2017 11:47 am
siclark offline
Re: Playing Sonos favourite track error
Ok, tested it works ok on local tracks. Seems to be only on cloud services for a single track.
Sun Aug 06, 2017 2:53 pm
siclark offline
Upgraded to 1.06 and still doesnt work on Spotify tracks as favourite.
Sun Aug 06, 2017 4:59 pm
nlagaros offline
I need to see some logs/debug logs to help here. Spotify is tricky - they are doing everything they can to be proprietary with Sonos. #Painful!
Tue Aug 08, 2017 2:54 pm
siclark offline
I turned on all the debug options and if I do a local track as favourite I get a lot of lines in the log. However when I execute playing a spotify track as favourite it still only gives the one line in the log saying it doesnt know what to do with it .
Happy to help debug if there is anything else you need to see.
Thu Feb 03, 2022 8:58 am
CBowles offline
Hi Nick,
I've recently been adding control pages to play favourites and playlist and although the playlists and favourites from local music work fine, as the other guy said, favourites from streaming services seem to get in a pickle.
Here are the errors I'm seeing in the log:
Sonos I do not know what to do with Favorite: x-sonos-http:song%3a1393183647.mp4?sid=204&flags=8224&sn=3
Sonos I do not know what to do with Favorite: x-sonos-http:track%2f18475094.flac?sid=174&flags=8224&sn=4
The first is from Apple Music, the second is from Tidal.
Then about 10mins later I get:
Web Server http://10.0.1.103:1400/getaa?s=1&u=x-so ... 8%26sn%3d4 load error: timed out
I think the Web Server error is related to displaying artwork, not the Sonos plugin.
Is there any magic you can work to get favourites playing from streaming services?
Any suggestions would be very appreciated ;-)
Chris
