Apple voice option
Sun Aug 06, 2017 5:10 am
haavarda offline
Re: Apple voice option
Upgraded to you 06 version, but still get the error.
Get this when I enable the plugin:
  Sonos Error                     Cannot start HTTP Streamer on None: [Errno 8] nodename nor servname provided, or not known
And this when I try to run TTS:
 Action Group                    sonos test
   Sonos                           Announcement: test, Volume: 25
   Sonos                           remove zone from group: Sonos - Hall
   Sonos                           ZonePlayer: Sonos - Hall, Current Volume: 25, New Volume: 25
   Sonos                           Announcement Length: 0.857052154195
   Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 198, in actionZP_announcementMP3
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1931, in actionAnnouncement
TypeError: cannot concatenate 'str' and 'NoneType' objects
Håvard
Sun Aug 06, 2017 5:31 am
nlagaros offline
The first error says it all. In the plugin configuration, please enter the IP address of your Indigo server where it asks for HTTP Streaming IP.
Sun Aug 06, 2017 8:01 am
norcoscia offline
Thanks Nick- the grouping in the app (visually) does not keep up with what is happening but it is working now - not sure why I was having a problem before - sorry to bug you....
_______
Norm
Sun Aug 06, 2017 12:14 pm
haavarda offline
Hi Nick.
I had the field for server blank, but changed it to my server IP. Now the startup error is gone. And I get no error when I run the TTS. But it is quite from the sonos player. And if I have the sonos application open, it says that it could not connect to "server ip adress:8888"
Any idea?
Håvard
Tue Aug 08, 2017 9:39 am
haavarda offline
Any idea Nick?
Håvard
