Sonos 1.04 Falling off network every minute
Sat Jun 17, 2017 9:37 pm
Ramias offline
Thank you for adding Amazon Polly.
Now I am getting these every minute. Was not getting this with 1.03. But getting similar "falling off network" messages with my Hikvision's.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Basement has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Basement
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Bedroom has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Bedroom
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Day Room has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Day Room
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Living Room has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Living Room
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Office has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Office
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Patio has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Patio
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos Rowing Room has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos Rowing Room
   Sonos Error                     [Sat Jun 17 23:35:45 2017] ZonePlayer: Sonos TV Room has fallen off the network.
   Sonos Error                     [Sat Jun 17 23:35:45 2017] Resubscription due to timeout for ZonePlayer: Sonos TV Room
Sun Jun 18, 2017 5:21 am
nlagaros offline
Re: Sonos 1.04 Falling off network every minute
Please restart the plugin in debug mode (the first debug checkbox) and check the custom state called "alive" for each of the ZonePlayers. It should be the second to last in the custom state list. It should be populated with the current time. Let's start there.
Sun Jun 18, 2017 5:32 am
colinpartridge offline
Watching this with interest as I also am seeing the same behaviour here, but mine has been doing this before the latest version.
C
Sun Jun 18, 2017 7:48 pm
aldera offline
Mine was doing this also but I reloaded the plugin and that has stopped it since then (15 minutes). However, I still get the following log entry whenever there is a sonos announcement:
   Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 198, in actionZP_announcementMP3
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1858, in actionAnnouncement
KeyError: key id 1440525837 not found in database
This has been happening since v1.0.3.
Mon Jun 19, 2017 4:35 pm
roussell offline
I'll do a "me too" post... I started seeing the same thing as the OP a few hours after upgrading to 1.04 - all 9 Sonos devices "fell" off the network. Reloading the plugin would bring them back for a (seemingly) random amount of time, but eventually they'd all fall off again. The Sonos application installed on the Indigo server correctly reported all speakers and would play to each of them. All speakers have reserved DHCP addresses and I double-checked to make sure they're unchanged. I tried deleting/re-installing the plugin, along with restarting Indigo and it's hosting server, didn't help. I downgraded to 1.03 with no other changes (including no restart/reboot) and all is well again.
Terry
Mon Jun 19, 2017 9:59 pm
Ramias offline
I enabled debug logging and did not see the 1 minute interval error.
Disabled logging and the error has not returned.
This could be a tough one to pin down.
Tue Jun 20, 2017 9:12 am
vtmikel offline
I also upgraded today and saw this behavior.
On startup, this occurs:
Sonos Error                     Error in plugin execution startup:
  File "plugin.py", line 36, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 265, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2220, in closedPrefsConfigUi
KeyError: key Polly not found in dict
I will turn on debugging and post what I see.
Wed Jun 21, 2017 5:03 am
eme jota ce offline
Me too. Downgrading to 1.03 worked.
[Edit] Thanks again for this great Plugin.
Wed Jun 21, 2017 6:23 am
nlagaros offline
Well crap! I must have screwed something up, although I do not have this issue with my 5 ZonePlayers. Sorry gang.
Wed Jun 21, 2017 7:58 am
eme jota ce offline
My system has 10 zones and one sub, if that matters. All have static IP's, except the sub.
Sat Jun 24, 2017 10:57 am
Gusten offline
I have the same issue, it seems like everything is working, just the logs filling up. Sorry for the noob question but how do I downgrade?
Fri Jun 30, 2017 6:42 am
Londonmark offline
I'm having this problem too.
Wed Jul 05, 2017 8:29 am
acesandeights18 offline
I'm having the same issues. Where did you find 1.0.3 version? so i can downgrade.
This is a great plugin! Thank you so much. Just 1.0.4 does not work for me.
Wed Jul 05, 2017 8:41 am
evansgo offline
Yup me too - anything you want tested?
I have a bunch of old and new units, along with Play 1's, 3's and 5's in stereo pairs, not sure if it could be related?
Wed Jul 05, 2017 8:53 am
FlyingDiver online
I was having this issue, then I did a Sonos software update using my iPhone and the problem went away.
