Getting Songs plugin to execute actions from within Python
Sun Apr 23, 2017 1:14 pm
pgershon offline
I have a plugin that run my Grand Concerto and I am trying to get the python code to communicate with the Sonos plugin. I can look at values within Sonos, but I am having trouble getting Sonos to perform actions. I tried two ways - the first fails, the second works but relies on an Action Group I wrote to perform:
sqzPlugin = indigo.server.getPlugin("com.ssi.indigoplugin.Sonos")
sqzPlugin.executeAction("TogglePlay", deviceId="42384538")
and
indigo.actionGroup.execute(1445798824)
42384538 is the ID of the Sonos device. 1445798824 is the ID of a Sonos Action Group that does Toggle Play. The action group works fine from the Indigo main interface, just not from within the Python script.
Error generated by first approach:
    NuVo Grand Concerto Error Error in plugin execution runConcurrentThread:
    File "plugin.py", line 226, in runConcurrentThread
    File "plugin.py", line 266, in parseToServerLine
    File "plugin.py", line 363, in parseToServer
    ArgumentError: Python argument types in
    PluginInfo.executeAction(PluginInfo, str)
    did not match C++ signature:
    executeAction(CPlugin {lvalue}, CCString actionTypeId, unsigned long deviceId=0, boost::python::api::object props=None, bool waitUntilDone=True)
    NuVo Grand Concerto Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Any thoughts?
Sun Apr 23, 2017 1:41 pm
Re: Getting Songs plugin to execute actions from within Pyth
Try this:
if sqzPlugin.isEnabled():
    sqzPlugin.executeAction("actionTogglePlay", deviceId="42384538")
Unless documented elsewhere by the plugin developer, you need to look at the Actions.xml file inside the plugin to determine the name of the action you're trying to invoke.
Tue May 02, 2017 3:46 pm
pgershon offline
I needed to remove the quotes from the device id, then it worked. Thanks.
