Sonos keeps falling off network
Sun Apr 16, 2017 11:29 am
pgershon offline
I just installed a Sonos and downloaded the plugin for Indigo. Sonos is hardwired on 192.168.0.122. It keeps generating message in log:
Sonos Error [Sun Apr 16 11:55:29 2017] ZonePlayer: Sonos Connect has fallen off the network.
Sonos Error [Sun Apr 16 11:55:29 2017] Resubscription due to timeout for ZonePlayer: Sonos Connect
With debug, the following additional message comes with it:
Sonos Debug [Sun Apr 16 11:56:29 2017] Unsubscribing to ZonePlayer: Sonos Connect
I have a Sonos Connect and it is supposed to be playing SiriusXM. Added screenshot of config
Screen Shot 2017-04-16 at 1.28.49 PM.png (189.01 KiB) Viewed 2368 times
Sun Apr 16, 2017 11:39 am
nlagaros offline
Re: Sonos keeps falling off network
Can you restart the plugin with debugging on and post all the output. Thanks.
Sun Apr 16, 2017 12:27 pm
pgershon offline
Output from restart:
Apr 16, 2017, 2:26:37 PM
Sonos Error [Sun Apr 16 14:26:37 2017] ZonePlayer: Sonos Connect has fallen off the network.
Sonos Error [Sun Apr 16 14:26:37 2017] Resubscription due to timeout for ZonePlayer: Sonos Connect
Sonos Debug [Sun Apr 16 14:26:37 2017] Unsubscribing to ZonePlayer: Sonos Connect
Reloading plugin "Sonos 1.0.3"
Stopping plugin "Sonos 1.0.3" (pid 52300)
Sonos Debug Method: stopConcurrentThread
Sonos Debug Stopping Concurrent Thread
Sonos Debug Stopping device: Sonos Connect
Sonos Debug [Sun Apr 16 14:26:38 2017] Unsubscribing to ZonePlayer: Sonos Connect
Sonos Debug Method: shutdown
Sonos SoCo Reactor Landing...
Stopped plugin "Sonos 1.0.3"
Starting plugin "Sonos 1.0.3" (pid 55078)
Started plugin "Sonos 1.0.3"
Sonos Your plugin version, v1.0.3, is current.
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 257, in startup
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 150, in makedirs
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py", line 157, in makedirs
OSError: [Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images'
Sonos Adding ZonePlayer: 192.168.0.122, RINCON_949F3E24D8CE01400, Sonos Connect
Sun Apr 16, 2017 2:22 pm
pgershon offline
So to add, after the reload, the prior entry showed the immediate log. Then it stayed quiet for a bit more than 10 mins, and then:
Apr 16, 2017, 2:38:56 PM
Trigger Motion Living Room
Apr 16, 2017, 2:42:42 PM
Sonos Error [Sun Apr 16 14:42:42 2017] ZonePlayer: Sonos Connect has fallen off the network.
Sonos Error [Sun Apr 16 14:42:42 2017] Resubscription due to timeout for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from avTransport events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from renderingControl events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from zoneGroupTopology events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from queue events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from groupRenderingControl events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from contentDirectory events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from groupManagement events for ZonePlayer: Sonos Connect
Sonos Error Cannot unsubscribe from audioIn events for ZonePlayer: Sonos Connect
Trigger Downstars Humidity Change
Sent INSTEON "Thermostat - Downstairs" humidity request (received: 34.0)
Apr 16, 2017, 2:43:42 PM
Sonos Error [Sun Apr 16 14:43:42 2017] ZonePlayer: Sonos Connect has fallen off the network.
Sonos Error [Sun Apr 16 14:43:42 2017] Resubscription due to timeout for ZonePlayer: Sonos Connect
Apr 16, 2017, 2:44:42 PM
Sonos Error [Sun Apr 16 14:44:42 2017] ZonePlayer: Sonos Connect has fallen off the network.
Sonos Error [Sun Apr 16 14:44:42 2017] Resubscription due to timeout for ZonePlayer: Sonos Connect
Sun Apr 16, 2017 2:28 pm
pgershon offline
Well I fixed the permissions error. It seems that the plugin creates a folder Images directly in the Perceptive Automation folder instead of in the Indigo 7 folder. After that correction, here is the startup with debugging on:
Apr 16, 2017, 4:25:50 PM
   Stopping plugin "Sonos 1.0.3" (pid 56597)
   Starting plugin "Sonos 1.0.3" (pid 56628)
   Sonos Debug                     zoneIP: 192.168.0.122, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
   Sonos Debug                        Sonos Favorites: FV:2/0, 28 - The Spectrum, x-sonosapi-hls:r%3athespectrum?sid=37&flags=8480&sn=1
   Sonos                           Loaded Sonos Favorites... [1]
   Sonos                           Loaded Playlists... [0]
   Sonos                           Loaded RadioTime Favorite Stations... [0]
   Sonos                           Serving HTTP Streamer on 192.168.0.110 [0.0.0.0], port 8888
   Sonos Debug                        SiriusXM: 2|2|siriushits1|siriushits1|SiriusXM Hits 1
   Sonos Debug                        SiriusXM: 3|3|9389|9389|Venus
   Sonos Debug                        SiriusXM: 4|4|9406|9406|Pitbull's Globalization
   Sonos Debug                        SiriusXM: 5|5|siriusgold|siriusgold|50s on 5
   Sonos Debug                        SiriusXM: 6|6|60svibrations|60svibrations|60s on 6
   Sonos Debug                        SiriusXM: 7|7|totally70s|totally70s|70s on 7
   Sonos Debug                        SiriusXM: 8|8|big80s|big80s|80s on 8
   Sonos Debug                        SiriusXM: 9|9|8206|8206|90s on 9
   Sonos Debug                        SiriusXM: 10|10|8208|8208|Pop2K
   Sonos Debug                        SiriusXM: 13|13|9361|9361|Velvet
   Sonos Debug                        SiriusXM: 14|14|coffeehouse|coffeehouse|The Coffee House
   Sonos Debug                        SiriusXM: 15|15|thepulse|thepulse|The Pulse
   Sonos Debug                        SiriusXM: 16|16|starlite|starlite|The Blend
   Sonos Debug                        SiriusXM: 17|17|siriuslove|siriuslove|SiriusXM Love
   Sonos Debug                        SiriusXM: 18|18|9138|9138|SXM Limited Edition
   Sonos Debug                        SiriusXM: 300|300|9412|9412|Poptropolis
   Sonos Debug                        SiriusXM: 301|301|9415|9415|Road Trip Radio
   Sonos Debug                        SiriusXM: 302|302|9416|9416|The Covers Channel
   Sonos Debug                        SiriusXM: 303|303|9419|9419|ONEderland
   Sonos Debug                        SiriusXM: 158|158|rumbon|rumbon|Caliente
   Sonos Debug                        SiriusXM: 700|700|8372|8372|Neil Diamond Radio
   Sonos Debug                        SiriusXM: 702|702|9362|9362|Elevations
   Sonos Debug                        SiriusXM: 703|703|9378|9378|Oldies Party
   Sonos Debug                        SiriusXM: 704|704|9372|9372|70s/80s Pop
   Sonos Debug                        SiriusXM: 705|705|9373|9373|80s/90s Pop
   Sonos Debug                        SiriusXM: 782|782|9342|9342|Holiday Traditions
   Sonos Debug                        SiriusXM: 19|19|elvisradio|elvisradio|Elvis Radio
   Sonos Debug                        SiriusXM: 20|20|estreetradio|estreetradio|E Street Radio
   Sonos Debug                        SiriusXM: 21|21|undergroundgarage|undergroundgarage|Underground Garage
   Sonos Debug                        SiriusXM: 22|22|8370|8370|Pearl Jam Radio
   Sonos Debug                        SiriusXM: 23|23|gratefuldead|gratefuldead|Grateful Dead
   Sonos Debug                        SiriusXM: 24|24|radiomargaritaville|radiomargaritaville|Radio Margaritaville
   Sonos Debug                        SiriusXM: 25|25|classicrewind|classicrewind|Classic Rewind
   Sonos Debug                        SiriusXM: 26|26|classicvinyl|classicvinyl|Classic Vinyl
   Sonos Debug                        SiriusXM: 27|27|thevault|thevault|Deep Tracks
   Sonos Debug                        SiriusXM: 28|28|thespectrum|thespectrum|The Spectrum
   Sonos Debug                        SiriusXM: 29|29|jamon|jamon|Jam_ON
   Sonos Debug                        SiriusXM: 30|30|8207|8207|The Loft
   Sonos Debug                        SiriusXM: 31|31|9407|9407|Tom Petty Radio
   Sonos Debug                        SiriusXM: 32|32|thebridge|thebridge|The Bridge
   Sonos Debug                        SiriusXM: 33|33|firstwave|firstwave|1st Wave
   Sonos Debug                        SiriusXM: 34|34|90salternative|90salternative|Lithium
   Sonos Debug                        SiriusXM: 35|35|leftofcenter|leftofcenter|SiriusXMU
   Sonos Debug                        SiriusXM: 36|36|altnation|altnation|Alt Nation
   Sonos Debug                        SiriusXM: 37|37|octane|octane|Octane
   Sonos Debug                        SiriusXM: 38|38|buzzsaw|buzzsaw|Ozzy's Boneyard
   Sonos Debug                        SiriusXM: 39|39|hairnation|hairnation|Hair Nation
   Sonos Debug                        SiriusXM: 40|40|hardattack|hardattack|Liquid Metal
   Sonos Debug                        SiriusXM: 41|41|faction|faction|Faction
   Sonos Debug                        SiriusXM: 42|42|reggaerhythms|reggaerhythms|The Joint
   Sonos Debug                        SiriusXM: 712|712|9352|9352|Petty's Buried Treasure
   Sonos Debug                        SiriusXM: 310|310|9174|9174|SXM Rock Hall Radio
   Sonos Debug                        SiriusXM: 311|311|9420|9420|Yacht Rock Radio
   Sonos Debug                        SiriusXM: 313|313|9175|9175|RockBar
   Sonos Debug                        SiriusXM: 314|314|9413|9413|SiriusXM Turbo
   Sonos Debug                        SiriusXM: 316|316|9176|9176|SiriusXM Comes Alive!
   Sonos Debug                        SiriusXM: 715|715|9375|9375|Classic Rock Party
   Sonos Debug                        SiriusXM: 716|716|9139|9139|SXM Limited Edition 2
   Sonos Debug                        SiriusXM: 717|717|9353|9353|SXM Limited Edition 3
   Sonos Debug                        SiriusXM: 43|43|8124|8124|Backspin
   Sonos Debug                        SiriusXM: 44|44|hiphopnation|hiphopnation|Hip-Hop Nation
   Sonos Debug                        SiriusXM: 45|45|shade45|shade45|Shade 45
   Sonos Debug                        SiriusXM: 720|720|9397|9397|Sway's Universe
   Sonos Debug                        SiriusXM: 721|721|9398|9398|SXM Limited Edition 4
   Sonos Debug                        SiriusXM: 46|46|hotjamz|hotjamz|The Heat
   Sonos Debug                        SiriusXM: 47|47|9339|9339|SiriusXM FLY
   Sonos Debug                        SiriusXM: 48|48|heartandsoul|heartandsoul|Heart & Soul
   Sonos Debug                        SiriusXM: 49|49|soultown|soultown|Soul Town
   Sonos Debug                        SiriusXM: 50|50|8228|8228|The Groove
   Sonos Debug                        SiriusXM: 330|330|9364|9364|SiriusXM Silk
   Sonos Debug                        SiriusXM: 726|726|9399|9399|SXM Limited Edition 5
   Sonos Debug                        SiriusXM: 51|51|thebeat|thebeat|BPM
   Sonos Debug                        SiriusXM: 52|52|area33|area33|Electric Area
   Sonos Debug                        SiriusXM: 53|53|chill|chill|SiriusXM Chill
   Sonos Debug                        SiriusXM: 54|54|9145|9145|Studio 54 Radio
   Sonos Debug                        SiriusXM: 340|340|9219|9219|Tiësto's Club Life Radio
   Sonos Debug                        SiriusXM: 341|341|9365|9365|Utopia
   Sonos Debug                        SiriusXM: 730|730|9400|9400|SXM Limited Edition 6
   Sonos Debug                        SiriusXM: 55|55|9421|9421|The Garth Channel
   Sonos Debug                        SiriusXM: 56|56|newcountry|newcountry|The Highway
   Sonos Debug                        SiriusXM: 57|57|9418|9418|No Shoes Radio
   Sonos Debug                        SiriusXM: 58|58|primecountry|primecountry|Prime Country
   Sonos Debug                        SiriusXM: 59|59|theroadhouse|theroadhouse|Willie's Roadhouse
   Sonos Debug                        SiriusXM: 60|60|outlawcountry|outlawcountry|Outlaw Country
   Sonos Debug                        SiriusXM: 61|61|9340|9340|Y2Kountry
   Sonos Debug                        SiriusXM: 62|62|bluegrass|bluegrass|Bluegrass Junction
   Sonos Debug                        SiriusXM: 350|350|9178|9178|Red White & Booze
   Sonos Debug                        SiriusXM: 741|741|8227|8227|The Village
   Sonos Debug                        SiriusXM: 742|742|9401|9401|SXM Limited Edition 7
   Sonos Debug                        SiriusXM: 63|63|spirit|spirit|The Message
   Sonos Debug                        SiriusXM: 64|64|praise|praise|Kirk Franklin's Praise
   Sonos Debug                        SiriusXM: 65|65|8229|8229|enLighten
   Sonos Debug                        SiriusXM: 745|745|9402|9402|SXM Limited Edition 8
   Sonos Debug                        SiriusXM: 66|66|jazzcafe|jazzcafe|Watercolors
   Sonos Debug                        SiriusXM: 67|67|purejazz|purejazz|Real Jazz
   Sonos Debug                        SiriusXM: 68|68|spa73|spa73|Spa
   Sonos Debug                        SiriusXM: 69|69|8215|8215|Escape
   Sonos Debug                        SiriusXM: 70|70|siriusblues|siriusblues|BB King's Bluesville
   Sonos Debug                        SiriusXM: 71|71|siriuslysinatra|siriuslysinatra|Siriusly Sinatra
   Sonos Debug                        SiriusXM: 72|72|broadwaysbest|broadwaysbest|On Broadway
   Sonos Debug                        SiriusXM: 73|73|8205|8205|40s Junction
   Sonos Debug                        SiriusXM: 750|750|8211|8211|Cinemagic
   Sonos Debug                        SiriusXM: 751|751|9179|9179|Krishna Das Yoga Radio
   Sonos Debug                        SiriusXM: 752|752|9403|9403|SXM Limited Edition 9
   Sonos Debug                        SiriusXM: 74|74|metropolitanopera|metropolitanopera|Met Opera Radio
   Sonos Debug                        SiriusXM: 76|76|symphonyhall|symphonyhall|Symphony Hall
   Sonos Debug                        SiriusXM: 755|755|siriuspops|siriuspops|SiriusXM Pops
   Sonos Debug                        SiriusXM: 756|756|9404|9404|SXM Limited Edition 10
   Sonos Debug                        SiriusXM: 761|761|9186|9186|Águila
   Sonos Debug                        SiriusXM: 762|762|9188|9188|Caricia
   Sonos Debug                        SiriusXM: 763|763|8225|8225|Viva
   Sonos Debug                        SiriusXM: 764|764|9187|9187|Latidos
   Sonos Debug                        SiriusXM: 765|765|9185|9185|Flow Nación
   Sonos Debug                        SiriusXM: 766|766|9189|9189|Luna
   Sonos Debug                        SiriusXM: 767|767|9190|9190|Rumbón
   Sonos Debug                        SiriusXM: 768|768|9191|9191|La Kueva
   Sonos Debug                        SiriusXM: 80|80|espnradio|espnradio|ESPN Radio
   Sonos Debug                        SiriusXM: 81|81|8254|8254|ESPN Xtra
   Sonos Debug                        SiriusXM: 82|82|8213|8213|Mad Dog Sports Radio
   Sonos Debug                        SiriusXM: 83|83|9445|9445|FOX Sports on SiriusXM
   Sonos Debug                        SiriusXM: 84|84|siriussportsaction|siriussportsaction|College Sports Nation
   Sonos Debug                        SiriusXM: 85|85|9341|9341|SiriusXM FC
   Sonos Debug                        SiriusXM: 207|86|9385|9385|SiriusXM NBA Radio
   Sonos Debug                        SiriusXM: 210|87|8368|8368|SXM Fantasy Sports Radio
   Sonos Debug                        SiriusXM: 88|88|siriusnflradio|siriusnflradio|SiriusXM NFL Radio
   Sonos Debug                        SiriusXM: 209|89|8333|8333|MLB Network Radio
   Sonos Debug                        SiriusXM: 90|90|siriusnascarradio|siriusnascarradio|SiriusXM NASCAR Radio
   Sonos Debug                        SiriusXM: 91|91|8185|8185|SXM NHL Network Radio
   Sonos Debug                        SiriusXM: 208|92|8186|8186|SiriusXM PGA TOUR Radio
   Sonos Debug                        SiriusXM: 93|93|8230|8230|SiriusXM Rush
   Sonos Debug                        SiriusXM: 157|157|espndeportes|espndeportes|ESPN Deportes
   Sonos Debug                        SiriusXM: 370|370|9180|9180|SportsCenter
   Sonos Debug                        SiriusXM: 800|800|9146|9146|Arizona Cardinals
   Sonos Debug                        SiriusXM: 801|801|9147|9147|Atlanta Falcons
   Sonos Debug                        SiriusXM: 802|802|9148|9148|Baltimore Ravens
   Sonos Debug                        SiriusXM: 803|803|9149|9149|Buffalo Bills
   Sonos Debug                        SiriusXM: 804|804|9150|9150|Carolina Panthers
   Sonos Debug                        SiriusXM: 805|805|9151|9151|Chicago Bears
   Sonos Debug                        SiriusXM: 806|806|9152|9152|Cincinnati Bengals
   Sonos Debug                        SiriusXM: 807|807|9153|9153|Cleveland Browns
   Sonos Debug                        SiriusXM: 808|808|9154|9154|Dallas Cowboys
   Sonos Debug                        SiriusXM: 809|809|9155|9155|Denver Broncos
   Sonos Debug                        SiriusXM: 810|810|9156|9156|Detroit Lions
   Sonos Debug                        SiriusXM: 811|811|9157|9157|Green Bay Packers
   Sonos Debug                        SiriusXM: 812|812|9158|9158|Houston Texans
   Sonos Debug                        SiriusXM: 813|813|9159|9159|Indianapolis Colts
   Sonos Debug                        SiriusXM: 814|814|9160|9160|Jacksonville Jaguars
   Sonos Debug                        SiriusXM: 815|815|9161|9161|Kansas City Chiefs
   Sonos Debug                        SiriusXM: 816|816|9203|9203|Los Angeles Rams
   Sonos Debug                        SiriusXM: 817|817|9162|9162|Miami Dolphins
   Sonos Debug                        SiriusXM: 818|818|9163|9163|Minnesota Vikings
   Sonos Debug                        SiriusXM: 819|819|9164|9164|New England Patriots
   Sonos Debug                        SiriusXM: 820|820|9165|9165|New Orleans Saints
   Sonos Debug                        SiriusXM: 821|821|9166|9166|New York Giants
   Sonos Debug                        SiriusXM: 822|822|9167|9167|New York Jets
   Sonos Debug                        SiriusXM: 823|823|9168|9168|Oakland Raiders
   Sonos Debug                        SiriusXM: 824|824|9169|9169|Philadelphia Eagles
   Sonos Debug                        SiriusXM: 825|825|9170|9170|Pittsburgh Steelers
   Sonos Debug                        SiriusXM: 826|826|9171|9171|San Diego Chargers
   Sonos Debug                        SiriusXM: 827|827|9202|9202|San Francisco 49ers
   Sonos Debug                        SiriusXM: 828|828|9201|9201|Seattle Seahawks
   Sonos Debug                        SiriusXM: 829|829|9204|9204|Tampa Bay Buccaneers
   Sonos Debug                        SiriusXM: 830|830|9205|9205|Tennessee Titans
   Sonos Debug                        SiriusXM: 831|831|9206|9206|Washington Redskins
   Sonos Debug                        SiriusXM: 840|840|9231|9231|Arizona Diamondbacks
   Sonos Debug                        SiriusXM: 841|841|9232|9232|Atlanta Braves
   Sonos Debug                        SiriusXM: 842|842|9233|9233|Baltimore Orioles
   Sonos Debug                        SiriusXM: 843|843|9234|9234|Boston Red Sox
   Sonos Debug                        SiriusXM: 844|844|9235|9235|Chicago Cubs
   Sonos Debug                        SiriusXM: 845|845|9236|9236|Chicago White Sox
   Sonos Debug                        SiriusXM: 846|846|9237|9237|Cincinnati Reds
   Sonos Debug                        SiriusXM: 847|847|9238|9238|Cleveland Indians
   Sonos Debug                        SiriusXM: 848|848|9239|9239|Colorado Rockies
   Sonos Debug                        SiriusXM: 849|849|9240|9240|Detroit Tigers
   Sonos Debug                        SiriusXM: 850|850|9241|9241|Houston Astros
   Sonos Debug                        SiriusXM: 851|851|9242|9242|Kansas City Royals
   Sonos Debug                        SiriusXM: 852|852|9243|9243|Los Angeles Angels
   Sonos Debug                        SiriusXM: 853|853|9244|9244|Los Angeles Dodgers
   Sonos Debug                        SiriusXM: 854|854|9245|9245|Miami Marlins
   Sonos Debug                        SiriusXM: 855|855|9246|9246|Milwaukee Brewers
   Sonos Debug                        SiriusXM: 856|856|9247|9247|Minnesota Twins
   Sonos Debug                        SiriusXM: 857|857|9248|9248|New York Mets
   Sonos Debug                        SiriusXM: 858|858|9249|9249|New York Yankees
   Sonos Debug                        SiriusXM: 859|859|9250|9250|Oakland Athletics
   Sonos Debug                        SiriusXM: 860|860|9251|9251|Philadelphia Phillies
   Sonos Debug                        SiriusXM: 861|861|9252|9252|Pittsburgh Pirates
   Sonos Debug                        SiriusXM: 862|862|9253|9253|San Diego Padres
   Sonos Debug                        SiriusXM: 863|863|9254|9254|San Francisco Giants
   Sonos Debug                        SiriusXM: 864|864|9255|9255|Seattle Mariners
   Sonos Debug                        SiriusXM: 865|865|9256|9256|St. Louis Cardinals
   Sonos Debug                        SiriusXM: 866|866|9257|9257|Tampa Bay Rays
   Sonos Debug                        SiriusXM: 867|867|9258|9258|Texas Rangers
   Sonos Debug                        SiriusXM: 868|868|9259|9259|Toronto Blue Jays
   Sonos Debug                        SiriusXM: 869|869|9260|9260|Washington Nationals
   Sonos Debug                        SiriusXM: 880|880|9266|9266|Atlanta Hawks
   Sonos Debug                        SiriusXM: 881|881|9268|9268|Boston Celtics
   Sonos Debug                        SiriusXM: 882|882|9267|9267|Brooklyn Nets
   Sonos Debug                        SiriusXM: 883|883|9269|9269|Charlotte Hornets
   Sonos Debug                        SiriusXM: 884|884|9270|9270|Chicago Bulls
   Sonos Debug                        SiriusXM: 885|885|9271|9271|Cleveland Cavaliers
   Sonos Debug                        SiriusXM: 886|886|9272|9272|Dallas Mavericks
   Sonos Debug                        SiriusXM: 887|887|9273|9273|Denver Nuggets
   Sonos Debug                        SiriusXM: 888|888|9274|9274|Detroit Pistons
   Sonos Debug                        SiriusXM: 889|889|9275|9275|Golden State Warriors
   Sonos Debug                        SiriusXM: 890|890|9276|9276|Houston Rockets
   Sonos Debug                        SiriusXM: 891|891|9277|9277|Indiana Pacers
   Sonos Debug                        SiriusXM: 892|892|9278|9278|Los Angeles Clippers
   Sonos Debug                        SiriusXM: 893|893|9279|9279|Los Angeles Lakers
   Sonos Debug                        SiriusXM: 894|894|9280|9280|Memphis Grizzlies
   Sonos Debug                        SiriusXM: 895|895|9281|9281|Miami Heat
   Sonos Debug                        SiriusXM: 896|896|9282|9282|Milwaukee Bucks
   Sonos Debug                        SiriusXM: 897|897|9283|9283|Minnesota Timberwolves
   Sonos Debug                        SiriusXM: 898|898|9284|9284|New Orleans Pelicans
   Sonos Debug                        SiriusXM: 899|899|9285|9285|New York Knicks
   Sonos Debug                        SiriusXM: 900|900|9286|9286|Oklahoma City Thunder
   Sonos Debug                        SiriusXM: 901|901|9287|9287|Orlando Magic
   Sonos Debug                        SiriusXM: 902|902|9288|9288|Philadelphia 76ers
   Sonos Debug                        SiriusXM: 903|903|9289|9289|Phoenix Suns
   Sonos Debug                        SiriusXM: 904|904|9290|9290|Portland Trail Blazers
   Sonos Debug                        SiriusXM: 905|905|9292|9292|Sacramento Kings
   Sonos Debug                        SiriusXM: 906|906|9291|9291|San Antonio Spurs
   Sonos Debug                        SiriusXM: 907|907|9293|9293|Toronto Raptors
   Sonos Debug                        SiriusXM: 908|908|9294|9294|Utah Jazz
   Sonos Debug                        SiriusXM: 909|909|9295|9295|Washington Wizards
   Sonos Debug                        SiriusXM: 920|920|9296|9296|Anaheim Ducks
   Sonos Debug                        SiriusXM: 921|921|9394|9394|Arizona Coyotes
   Sonos Debug                        SiriusXM: 922|922|9297|9297|Boston Bruins
   Sonos Debug                        SiriusXM: 923|923|9298|9298|Buffalo Sabres
   Sonos Debug                        SiriusXM: 924|924|9301|9301|Calgary Flames
   Sonos Debug                        SiriusXM: 925|925|9299|9299|Carolina Hurricanes
   Sonos Debug                        SiriusXM: 926|926|9302|9302|Chicago Blackhawks
   Sonos Debug                        SiriusXM: 927|927|9303|9303|Colorado Avalanche
   Sonos Debug                        SiriusXM: 928|928|9300|9300|Columbus Blue Jackets
   Sonos Debug                        SiriusXM: 929|929|9304|9304|Dallas Stars
   Sonos Debug                        SiriusXM: 930|930|9305|9305|Detroit Red Wings
   Sonos Debug                        SiriusXM: 931|931|9306|9306|Edmonton Oilers
   Sonos Debug                        SiriusXM: 932|932|9307|9307|Florida Panthers
   Sonos Debug                        SiriusXM: 933|933|9308|9308|Los Angeles Kings
   Sonos Debug                        SiriusXM: 934|934|9309|9309|Minnesota Wild
   Sonos Debug                        SiriusXM: 935|935|9310|9310|Montreal Canadiens
   Sonos Debug                        SiriusXM: 936|936|9312|9312|Nashville Predators
   Sonos Debug                        SiriusXM: 937|937|9311|9311|New Jersey Devils
   Sonos Debug                        SiriusXM: 938|938|9313|9313|New York Islanders
   Sonos Debug                        SiriusXM: 939|939|9314|9314|New York Rangers
   Sonos Debug                        SiriusXM: 940|940|9315|9315|Ottawa Senators
   Sonos Debug                        SiriusXM: 941|941|9316|9316|Philadelphia Flyers
   Sonos Debug                        SiriusXM: 942|942|9318|9318|Pittsburgh Penguins
   Sonos Debug                        SiriusXM: 943|943|9319|9319|San Jose Sharks
   Sonos Debug                        SiriusXM: 944|944|9320|9320|St. Louis Blues
   Sonos Debug                        SiriusXM: 945|945|9321|9321|Tampa Bay Lightning
   Sonos Debug                        SiriusXM: 946|946|9322|9322|Toronto Maple Leafs
   Sonos Debug                        SiriusXM: 947|947|9323|9323|Vancouver Canucks
   Sonos Debug                        SiriusXM: 948|948|9324|9324|Washington Capitals
   Sonos Debug                        SiriusXM: 949|949|9325|9325|Winnipeg Jets
   Sonos Debug                        SiriusXM: 953|953|9422|9422|Sports 953
   Sonos Debug                        SiriusXM: 954|954|9423|9423|Sports 954
   Sonos Debug                        SiriusXM: 955|955|9424|9424|Sports 955
   Sonos Debug                        SiriusXM: 956|956|9425|9425|Sports 956
   Sonos Debug                        SiriusXM: 957|957|9426|9426|Sports 957
   Sonos Debug                        SiriusXM: 958|958|9427|9427|Sports 958
   Sonos Debug                        SiriusXM: 959|959|9428|9428|Sports 959
   Sonos Debug                        SiriusXM: 960|960|9220|9220|Sports 960
   Sonos Debug                        SiriusXM: 961|961|9221|9221|Sports 961
   Sonos Debug                        SiriusXM: 962|962|9222|9222|Sports 962
   Sonos Debug                        SiriusXM: 963|963|9223|9223|Sports 963
   Sonos Debug                        SiriusXM: 964|964|9224|9224|Sports 964
   Sonos Debug                        SiriusXM: 965|965|9225|9225|Sports 965
   Sonos Debug                        SiriusXM: 966|966|9226|9226|Sports 966
   Sonos Debug                        SiriusXM: 967|967|9227|9227|Sports 967
   Sonos Debug                        SiriusXM: 968|968|9228|9228|Sports 968
   Sonos Debug                        SiriusXM: 969|969|9229|9229|Sports 969
   Sonos Debug                        SiriusXM: 970|970|9207|9207|Sports 970
   Sonos Debug                        SiriusXM: 971|971|9208|9208|Sports 971
   Sonos Debug                        SiriusXM: 972|972|9209|9209|Sports 972
   Sonos Debug                        SiriusXM: 973|973|9210|9210|Sports 973
   Sonos Debug                        SiriusXM: 974|974|9211|9211|Sports 974
   Sonos Debug                        SiriusXM: 975|975|9212|9212|Sports 975
   Sonos Debug                        SiriusXM: 976|976|9213|9213|Sports 976
   Sonos Debug                        SiriusXM: 977|977|9214|9214|Sports 977
   Sonos Debug                        SiriusXM: 978|978|9215|9215|Sports 978
   Sonos Debug                        SiriusXM: 979|979|9216|9216|Sports 979
   Sonos Debug                        SiriusXM: 980|980|9261|9261|Sports 980
   Sonos Debug                        SiriusXM: 981|981|9262|9262|Sports 981
   Sonos Debug                        SiriusXM: 982|982|9326|9326|Sports 982
   Sonos Debug                        SiriusXM: 983|983|9327|9327|Sports 983
   Sonos Debug                        SiriusXM: 984|984|9328|9328|Sports 984
   Sonos Debug                        SiriusXM: 985|985|9329|9329|Sports 985
   Sonos Debug                        SiriusXM: 986|986|9330|9330|Sports 986
   Sonos Debug                        SiriusXM: 987|987|9331|9331|Sports 987
   Sonos Debug                        SiriusXM: 988|988|9332|9332|Sports 988
   Sonos Debug                        SiriusXM: 989|989|9333|9333|Sports 989
   Sonos Debug                        SiriusXM: 990|990|9334|9334|Sports 990
   Sonos Debug                        SiriusXM: 991|991|9335|9335|Sports 991
   Sonos Debug                        SiriusXM: 992|992|9336|9336|Sports 992
   Sonos Debug                        SiriusXM: 993|993|9337|9337|Sports 993
   Sonos Debug                        SiriusXM: 994|994|9338|9338|Sports 994
   Sonos Debug                        SiriusXM: 100|100|howardstern100|howardstern100|Howard 100
   Sonos Debug                        SiriusXM: 101|101|howardstern101|howardstern101|Howard 101
   Sonos Debug                        SiriusXM: 112|112|cnbc|cnbc|CNBC
   Sonos Debug                        SiriusXM: 113|113|9369|9369|FOX Business
   Sonos Debug                        SiriusXM: 114|114|foxnewschannel|foxnewschannel|FOX News Channel
   Sonos Debug                        SiriusXM: 115|115|9410|9410|FOX News Headlines 24/7
   Sonos Debug                        SiriusXM: 116|116|cnn|cnn|CNN
   Sonos Debug                        SiriusXM: 117|117|cnnheadlinenews|cnnheadlinenews|HLN
   Sonos Debug                        SiriusXM: 118|118|8367|8367|MSNBC
   Sonos Debug                        SiriusXM: 119|119|bloombergradio|bloombergradio|Bloomberg Radio
   Sonos Debug                        SiriusXM: 120|120|bbcworld|bbcworld|BBC World Service
   Sonos Debug                        SiriusXM: 121|121|8183|8183|SiriusXM Insight
   Sonos Debug                        SiriusXM: 122|122|nprnow|nprnow|NPR Now
   Sonos Debug                        SiriusXM: 123|123|8239|8239|PRX Public Radio
   Sonos Debug                        SiriusXM: 147|147|9367|9367|RURAL Radio
   Sonos Debug                        SiriusXM: 155|155|cnnespanol|cnnespanol|CNN en Español
   Sonos Debug                        SiriusXM: 169|169|cbcradioone|cbcradioone|CBC Radio One
   Sonos Debug                        SiriusXM: 455|455|8237|8237|C-SPAN Radio
   Sonos Debug                        SiriusXM: 124|124|indietalk|indietalk|POTUS Politics
   Sonos Debug                        SiriusXM: 125|125|siriuspatriot|siriuspatriot|SiriusXM Patriot
   Sonos Debug                        SiriusXM: 126|126|8238|8238|SiriusXM Urban View
   Sonos Debug                        SiriusXM: 127|127|siriusleft|siriusleft|SiriusXM Progress
   Sonos Debug                        SiriusXM: 450|450|9370|9370|FOX News Talk
   Sonos Debug                        SiriusXM: 796|796|9355|9355|TheBlaze Radio Network
   Sonos Debug                        SiriusXM: 77|77|9366|9366|KIDZ BOP Radio
   Sonos Debug                        SiriusXM: 78|78|8216|8216|Kids Place Live
   Sonos Debug                        SiriusXM: 79|79|radiodisney|radiodisney|Radio Disney
   Sonos Debug                        SiriusXM: 102|102|9409|9409|Radio Andy
   Sonos Debug                        SiriusXM: 206|103|8184|8184|Faction Talk
   Sonos Debug                        SiriusXM: 105|105|9351|9351|EW Radio
   Sonos Debug                        SiriusXM: 106|106|9442|9442|VOLUME
   Sonos Debug                        SiriusXM: 108|108|9390|9390|Today Show Radio
   Sonos Debug                        SiriusXM: 109|109|siriusstars|siriusstars|SiriusXM Stars
   Sonos Debug                        SiriusXM: 110|110|doctorradio|doctorradio|Doctor Radio
   Sonos Debug                        SiriusXM: 111|111|9359|9359|Business Radio
   Sonos Debug                        SiriusXM: 128|128|9392|9392|Joel Osteen Radio
   Sonos Debug                        SiriusXM: 146|146|roaddogtrucking|roaddogtrucking|Road Dog Trucking
   Sonos Debug                        SiriusXM: 791|791|9363|9363|Jason Ellis
   Sonos Debug                        SiriusXM: 148|148|radioclassics|radioclassics|RadioClassics
   Sonos Debug                        SiriusXM: 415|415|8369|8369|Vivid Radio
   Sonos Debug                        SiriusXM: 790|790|9405|9405|SXM Limited Edition 11
   Sonos Debug                        SiriusXM: 792|792|9443|9443|Ramsey Media Channel
   Sonos Debug                        SiriusXM: 794|794|0000|0000|SiriusXM Preview
   Sonos Debug                        SiriusXM: 129|129|thecatholicchannel|thecatholicchannel|The Catholic Channel
   Sonos Debug                        SiriusXM: 130|130|ewtnglobal|ewtnglobal|EWTN Radio
   Sonos Debug                        SiriusXM: 131|131|8307|8307|Family Talk
   Sonos Debug                        SiriusXM: 94|94|9408|9408|SiriusXM Comedy Greats
   Sonos Debug                        SiriusXM: 95|95|9356|9356|Comedy Central Radio
   Sonos Debug                        SiriusXM: 96|96|thefoxxhole|thefoxxhole|The Foxxhole
   Sonos Debug                        SiriusXM: 97|97|bluecollarcomedy|bluecollarcomedy|Comedy Roundup
   Sonos Debug                        SiriusXM: 98|98|laughbreak|laughbreak|Laugh USA
   Sonos Debug                        SiriusXM: 99|99|rawdog|rawdog|Raw Dog Comedy Hits
   Sonos Debug                        SiriusXM: 168|168|8259|8259|Canada Laughs
   Sonos Debug                        SiriusXM: 770|770|9181|9181|Carlin's Corner
   Sonos Debug                        SiriusXM: 769|769|9429|9429|Qué Funny
   Sonos Debug                        SiriusXM: 470|470|9414|9414|El Paisa
   Sonos Debug                        SiriusXM: 11|11|8241|8241|KIIS-Los Angeles
   Sonos Debug                        SiriusXM: 12|12|8242|8242|Z100/NY
   Sonos Debug                        SiriusXM: 141|141|9129|9129|HUR Voices
   Sonos Debug                        SiriusXM: 142|142|9130|9130|HBCU
   Sonos Debug                        SiriusXM: 143|143|9131|9131|BYUradio
   Sonos Debug                        SiriusXM: 144|144|9132|9132|Korea Today
   Sonos Debug                        SiriusXM: 152|152|9135|9135|En Vivo
   Sonos Debug                        SiriusXM: 153|153|9134|9134|La Politica Talk
   Sonos Debug                        SiriusXM: 154|154|9133|9133|American Latino Radio
   Sonos Debug                        SiriusXM: 162|162|cbcradio3|cbcradio3|CBC Radio 3
   Sonos Debug                        SiriusXM: 163|163|8245|8245|Ici Musique Chansons
   Sonos Debug                        SiriusXM: 165|165|9358|9358|Canadian IPR
   Sonos Debug                        SiriusXM: 166|166|rockvelours|rockvelours|Ici FrancoCountry
   Sonos Debug                        SiriusXM: 167|167|9172|9172|Canada Talks
   Sonos Debug                        SiriusXM: 170|170|premiereplus|premiereplus|Ici Première
   Sonos Debug                        SiriusXM: 171|171|bandeapart|bandeapart|CBC Country
   Sonos Debug                        SiriusXM: 172|172|8248|8248|SiriusXM Scoreboard
   Sonos Debug                        SiriusXM: 173|173|8244|8244|The Verge
   Sonos Debug                        SiriusXM: 174|174|8246|8246|Influence Franco
   Sonos Debug                        SiriusXM: 758|758|icebergradio|icebergradio|Iceberg
   Sonos Debug                        SiriusXM: 759|759|energie2|energie2|Attitude Franco
   Sonos                           Loaded SiriusXM Stations.. [373]
   Sonos                           [Sun Apr 16 16:25:54 2017] Processed plugin preferences.
   Sonos                           SSDP Listener Started...
   Sonos Debug                     ZonePlayer: Sonos Connect, Enabled: True
   Sonos Debug                     Resetting States for zone: 192.168.0.122
   Sonos Debug                     zoneIP: 192.168.0.122, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
   Sonos Debug                     Method: runConcurrentThread
   Sonos Debug                     Running Concurrent Thread
   Sonos                           SoCo Reactor Ignition...
   Sonos Debug                     Processing Cover Art: Sonos Connect:/getaa?s=1&u=x-sonosapi-hls%3ar%253afirstwave%3fsid%3d37%26flags%3d8480%26sn%3d1
   Sonos                           ZonePlayer: Sonos Connect, Nothing in Queue to Save
   Sonos Debug                     Update all states to slave ZonePlayers...
   Sonos                           LineIn: RINCON_949F3E24D8CE01400, Audio Component:Office
Sun Apr 16, 2017 2:31 pm
nlagaros offline
The errors at startup creating the directory are causing the plugin to fail. It seems like the user running Indigo does not have permissions. Think if you can get past that, all will be well.
Sun Apr 16, 2017 2:40 pm
pgershon offline
I am past and no error yet. I will let if go an hour or so and see. Thanks.
BTW, in terms of the permissions, I think you might want to look at this as I can see from the forum others have had this issue as well. Indigo is put in Library/Application Support/Perceptive Automation/... The Mac system puts "system" privileges as opposed to user privileges at the top level folder within application support. So the folder "Perceptive Automation" has system and not user level privileges by default. The folders insider (in my case Indigo 5 Indigo 6 and Indigo 7) all have user privileges. I added user privileges to folder "Perceptive Automation" and that fixed the issue. But for consistency, all the other Indigo folders are within the Indigo 7 folder, not at the top level of "Perceptive Automation" (so now I have Images as well as the 3 Indigo folders thin "Perceptive Automation"). Not a big deal, but this is, I think, why many get the same issue.
Still looks good for no error messages. I guess the inability to save images is what was causing the issues.
