Statuses still not updating
Sun Feb 05, 2017 3:19 am
Londonmark online
Hi
I'm still finding the status of my players gets stuck a few songs into a playlist. This includes the artist, track title etc and artwork. Restarting the plugin solves the problem for another few songs. I'm almost always using grouped players. Anyone else experiencing this? Am on latest version of everything...
LM
Sun Feb 05, 2017 5:28 am
nlagaros offline
Re: Statuses still not updating
I am guessing one of the music sources you are using is throwing an error. I have a small utility in the plugin directory that can be run to try to catch what the issue is. If you are able to open a terminal window and run the following:
cd "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/lib"
python ./soco_test_twisted.py [ip address] <- ip address is the IP of the ZonePlayer in question that you will be using during this test.
Updates for the ZonePlayer will fill the screen as the ZonePlayer plays songs. Keep advancing through your sources as you would normally until you see it crash. It should be pretty obvious. Send me that output and I should be able to fix it.
Londonmark wrote:
Hi
LM
Sun Feb 05, 2017 7:19 am
Londonmark online
Thanks for the very quick response. Not sure the utility is working for me at the moment... I get:
  File "./soco_test_twisted.py", line 6, in <module>
    import soco
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/lib/soco/__init__.py", line 14, in <module>
    from .core import SoCo
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/lib/soco/core.py", line 18, in <module>
    import requests
ImportError: No module named requests
Sun Feb 05, 2017 7:20 am
nlagaros offline
you running v7 indigo and v1.0.2 of the plugin?
    import soco
    import requests
Sun Feb 05, 2017 7:21 am
Londonmark online
Yes - 7.0.3 and 1.0.2.
Sun Feb 05, 2017 7:42 am
Londonmark online
Not sure if it's relevant, but I periodically get this in the Event Log:
Sonos Error UPNP Error: 500
Sonos Error Offending Command -> zoneIP: 10.0.1.34, soapRoot: /MediaRenderer, soapBranch: /Queue, soapAction: SaveAsSonosPlaylist
I haven't been able to find a strong correlation to the status update issue.
Sun Feb 05, 2017 8:00 am
nlagaros offline
Shouldn't be correlated but that is an odd one. Is this particular ZonePlayer part of surround group?
Sun Feb 05, 2017 8:03 am
Londonmark online
Not surround. Just a group of a Play 3 and a couple of Play 1s. No stereo pairs.
Sun Feb 05, 2017 8:09 am
nlagaros offline
I must have the requests library installed on my system. Will have to repackage that with the plugin...
    import soco
    import requests
Sun Feb 05, 2017 8:21 am
nlagaros offline
Sun Feb 05, 2017 8:33 am
Londonmark online
That's got the utility working. Have kicked off a playlist to see what it shows. Will let you know what I see as soon as the status gets stuck.
Sun Feb 05, 2017 8:49 am
Londonmark online
OK. Didn't take too long I'm afraid. My control page got stuck on Henri Texier / Varech (with My Journey to the Sky / Sister Rosetta Tharpe as "up next"). Here is what the utility shows:
'AVTransport'
{u'current_crossfade_mode': '1',
 u'current_play_mode': 'SHUFFLE',
 u'current_section': '0',
 u'current_track': '4',
 u'current_track_duration': '0:03:04',
 u'current_track_meta_data': <DidlMusicTrack 'Les "L?-bas"' at 0x10f52c390>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a5LawMt3aszO8M3IXzXXesM?sid=9&flags=8224&sn=1',
 u'enqueued_transport_uri': 'x-rincon-cpcontainer:10062a6cspotify%3auser%3alondonmark%3aplaylist%3a3wE2q0NVkPEm7JvxBbZOpr',
 u'enqueued_transport_uri_meta_data': <DidlPlaylistContainer 'Discover Archive' at 0x10f52c450>,
 u'next_track_meta_data': <DidlMusicTrack 'My Journey To The Sky' at 0x10f52c410>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3MwWbGqUaNGcvc0Jofg7An?sid=9&flags=8224&sn=1',
 u'number_of_tracks': '1846',
 u'transport_state': 'PLAYING'}
'AVTransport'
 u'current_track': '5',
 u'current_track_duration': '0:03:14',
 u'current_track_meta_data': <DidlMusicTrack 'My Journey To The Sky' at 0x10f52c390>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a3MwWbGqUaNGcvc0Jofg7An?sid=9&flags=8224&sn=1',
 u'enqueued_transport_uri_meta_data': <DidlPlaylistContainer 'Discover Archive' at 0x10f52c350>,
 u'next_track_meta_data': <DidlMusicTrack 'You Can't Judge a Book By It's Cover' at 0x10f52c290>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a4W5BrFxMwrLQJXbxIk10dK?sid=9&flags=8224&sn=1',
'AVTransport'
 u'current_track': '6',
 u'current_track_duration': '0:03:10',
 u'current_track_meta_data': <DidlMusicTrack 'You Can't Judge a Book By It's Cover' at 0x10f52c250>,
 u'current_track_uri': 'x-sonos-spotify:spotify%3atrack%3a4W5BrFxMwrLQJXbxIk10dK?sid=9&flags=8224&sn=1',
 u'enqueued_transport_uri_meta_data': <DidlPlaylistContainer 'Discover Archive' at 0x10f52c490>,
 u'next_track_meta_data': <DidlMusicTrack 'Don't Let Me Down' at 0x10f52c210>,
 u'next_track_uri': 'x-sonos-spotify:spotify%3atrack%3a5cyFCMVtUchNrpTMc8UWN8?sid=9&flags=8224&sn=1',
So that all looks as if it's doing the right things, but for some reason the status doesn't update.
Sun Feb 05, 2017 9:01 am
nlagaros offline
It just stops? That is so so bizarre. I see your source is Spotify ... why am I not surprised. They have been trouble, but this is just plain odd. No errors at all... I need to think...
Anything else running on your Indigo server that uses UPNP ports (1900) or Sonos ports (1400) that may be interfering?
Sun Feb 05, 2017 9:03 am
Londonmark online
Not as far as I know. Any easy way to check?
And it's not unique to Spotify - it happens if I play something from my music library too.
Mon Mar 13, 2017 4:44 pm
Londonmark online
Hi Nick
Any update on this?
