Can't select Sonos Favourite or Playlist
Fri Jan 06, 2017 5:20 pm
Colly offline
Hi Nick,
I've updated the plugin to latest version and when setting up a new action for one of my Play 1's I couldn't select either a favourite or a playlist, as in there are none to select even though I have both in the Sonos app.. My previous actions worked fine but couldn't create a new one. I then deleted my 2 Play 1 devices and reconnected them and no change, unfortunatley I now can only create an action to play or stop, can't select a source .
Any suggestions?
Colly
Fri Jan 06, 2017 5:50 pm
nlagaros offline
Re: Can't select Sonos Favourite or Playlist
Please restart the plugin in debug mode and post the output. It sounds like subscriptions are not working for your ZonePlayers. Thanks.
Colly wrote:
Hi Nick,
Any suggestions?
Colly
Fri Jan 06, 2017 6:03 pm
Colly offline
Have I posted the correct info below? Still a bit of an Indigo novice...
Reloading plugin "Sonos 1.0.2"
Stopping plugin "Sonos 1.0.2" (pid 5760)
Stopped plugin "Sonos 1.0.2"
Starting plugin "Sonos 1.0.2" (pid 5770)
Started plugin "Sonos 1.0.2"
Sonos Your plugin version, v1.0.2, is current.
6 Jan 2017 23:57:49
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 17 12 32 02 21 64 00 00 47 66 02 58 00 00 47 66 00 00 00 00 C9
Z-Wave Debug . . requestMeterLevel: node 023, endpoint None, meterType 01, raw value 6400...
Z-Wave Debug . . requestMeterLevel: 18.278 kWh (float: 18.278000)
Z-Wave Debug RCVD requestMeterLevel: 01 18 00 04 00 17 12 32 02 21 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 83
Z-Wave Debug . . requestMeterLevel: node 023, endpoint None, meterType 01, raw value 7400...
Z-Wave Debug . . requestMeterLevel: 0.000 W (float: 0.000000)
6 Jan 2017 23:58:22
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 03 0A 32 02 21 34 00 00 00 00 00 00 C7
Z-Wave Debug . . requestMeterLevel: node 003, endpoint None, meterType 01, raw value 3400...
Z-Wave Debug . . requestMeterLevel: 0.0 W (float: 0.000000)
6 Jan 2017 23:58:38
Sonos Error SOAPSend Error: HTTPConnectionPool(host='192.168.1.22', port=1400): Max retries exceeded with url: /MediaServer/ContentDirectory/Control (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x10d7fe8d0>: Failed to establish a new connection: [Errno 60] Operation timed out',))
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 257, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2079, in closedPrefsConfigUi
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2380, in getSonosFavorites
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 588, in SOAPSend
UnboundLocalError: local variable 'response' referenced before assignment
Sonos Adding ZonePlayer: 192.168.1.9, RINCON_5CAAFD2D9AD001400, Sonos Kitchen
Sonos Adding ZonePlayer: 192.168.1.8, RINCON_5CAAFD2D999E01400, Sonos Master Bedroom
Fri Jan 06, 2017 6:05 pm
nlagaros offline
Is 192.168.1.22 the IP address of one of your ZonePllayers? Looks like there is no response from that IP address.
6 Jan 2017 23:57:49
6 Jan 2017 23:58:22
6 Jan 2017 23:58:38
Fri Jan 06, 2017 6:10 pm
Colly offline
No, have 2 Play 1's as highlighted below - these are the correct IP's.
Fri Jan 06, 2017 6:11 pm
nlagaros offline
Your reference ZonePlayer in the plugin configuration should then be one of these IP addresses. Please check that. Thanks.
Fri Jan 06, 2017 6:18 pm
Colly offline
:oops: :oops:
That was it. Had a day without electricity yesterday and when everything got back up and running the Play 1's had different IP's - I guess that must have been my problem as I just changed them at device level..
Thanks for the quick and helpful response - have been really enjoying the Sonos kicking in as I get to the bottom of the stairs each morning :) :)
Fri Jan 06, 2017 7:06 pm
nlagaros offline
Cool! Glad you got it working.
Colly wrote:
:oops: :oops:
