v0.9.15 runConcurrentThread error
Sat Nov 19, 2016 8:50 am
norcoscia offline
Hi, I see this error in my log a few dozen times a day - I did not notice it before upgrading to (both) SONOS v0.9.15 and Indigo 7.
Can you help me figure out the cause, thanks in advance for any help you can provide....
   Sonos Error                     [Sat Nov 19 06:28:35 2016] ZonePlayer: Sonos Play 1 in Bath Room has fallen off the network.
   Sonos Error                     Error in plugin execution runConcurrentThread:
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 344, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 367, in checkEvents
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 453, in socoTimeout
TypeError: not enough arguments for format string
   Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
_______
Norm
Sat Nov 19, 2016 10:46 am
nlagaros offline
Re: v0.9.15 runConcurrentThread error
Oops for me - typo on an event log entry. I'll get a release out soon... however, if you are seeing this many times a day, then something is going on with that ZonePlayer and the network.
Wed Nov 23, 2016 8:27 am
nlagaros offline
Wed Dec 14, 2016 11:32 am
Colly offline
Hi nlagaros,
I've just updated to the latest version, .16, and get these errors everyone minute! Communication with both Play 1's is fine however.
Sonos Error [Wed Dec 14 17:28:48 2016] ZonePlayer: Sonos Living Room has fallen off the network.
Sonos Error [Wed Dec 14 17:28:48 2016] Resubscription due to timeout for ZonePlayer: Sonos Living Room
Sonos Error [Wed Dec 14 17:28:48 2016] ZonePlayer: Sonos Master Bed has fallen off the network.
Sonos Error [Wed Dec 14 17:28:48 2016] Resubscription due to timeout for ZonePlayer: Sonos Master Bed
Any help for a newbie??
Wed Dec 14, 2016 12:20 pm
nlagaros offline
I suspect there to be something going on with your network. It is possible other devices are causing the ZonePlayers to "reset" their connections. It could be another UPNP device broadcasting. If this is happening consistently every minute, then I would try shutting down other devices one by one to see if the behavior stops.
Colly wrote:
Hi nlagaros,
Thu Dec 15, 2016 3:50 pm
colinpartridge offline
Colly wrote:
Hi nlagaros,
I'm getting identical issues with the latest plugin version, will let you know if I find out what's causing it.
Sat Dec 17, 2016 3:39 pm
Found the cause of my resubscription issue. It appeared to be a conflict with another plugin, the YamahaRX plugin. Since I don't rely on this plugin it wasn't an issue to delete it.
Colin
Sat Dec 17, 2016 3:51 pm
Ignore that last post.. still have issues.. :(
Sat Dec 17, 2016 4:12 pm
nlagaros offline
I'll look at the code. This may be some edge case. Just to confirm, this is happening every minute from plugin startup?
Sat Dec 17, 2016 4:17 pm
Yep , exactly 60 sec intervals from plugin startup.
Colin
Sun Dec 18, 2016 9:41 am
nlagaros offline
Would you restart the plugin and observe the state called alive for each ZonePlayer that is exhibiting this behavior. When the plugin initializes each ZonePlayer, it should populate with the current time. I want to see what it looks like for you. Thanks.
Colin
Sun Dec 18, 2016 1:15 pm
Clearly you have remote healing hands..Was looking at the 'alive' state and the date stamps were matching up with the correct time. I'd decided to reload all the plugins leaving the sonos plugin alone.Having turned them all off I was still seeing the errors so I assumed that co-plugin interference was not to blame. However once I had restarted all the plugins and reloaded the Sonos plug-in the errors have gone away. Weird.
All good now for a while, just wish I knew what the issue really was.
Colin
