Errors
Sat Nov 12, 2016 2:39 pm
nlagaros offline
Re: Errors
If you are unable to do that, the more drastic step is to restart the Indigo server.
Sat Nov 12, 2016 2:43 pm
farberm offline
Re: Errors
response
Farber-Media-Center:~ markfarber$ ps -eaf|grep Sonos
502 12389 12378 0 3:40PM ttys006 0:00.00 grep Sonos
When I type kill -9 12389 response is no such process
Sat Nov 12, 2016 4:07 pm
roussell offline
Re: Errors
I was getting similar, but not exactly the same errors after upgrading to .15. I went back into the plugin configuration and noticed that some previously filled-in fields were black (reference ZP and TTS stuff). I reentered those and for good measure, restarted Indigo and everything came up great with no errors. This was the first I've updated since .10 I believe.
Sun Nov 13, 2016 7:26 am
nlagaros offline
Re: Errors
Good advice - I didn't think of that and it certainly could be the cause of these troubles. Please check the plugin configuration and make sure all the required fields are filled in - especially the root ZonePlayer.
Sun Nov 13, 2016 8:19 am
farberm offline
Re: Errors
Did not help with the error. Reentered all the values.
Nov 13, 2016, 9:18:06 AM
Sonos Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 344, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos-2.indigoPlugin/Contents/Server Plugin/Sonos.py", line 362, in checkEvents
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/_strptime.py", line 454, in _strptime_time
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/_strptime.py", line 325, in _strptime
ValueError: time data u'' does not match format '%a %b %d %H:%M:%S %Y'
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sonos SoCo Reactor Ignition...
Sun Nov 13, 2016 8:22 am
nlagaros offline
Re: Errors
The routing that is bombing should not trigger until 60 seconds after the plugin starts. Are you running in debug mode? I don't see any of the normal startup lines.
Sun Nov 13, 2016 8:24 am
nlagaros offline
Re: Errors
Does the plugin work at all? Are you getting any updates to your ZonePlayers? It looked like in one of your prior posts, it as about 3 hours before the plugin died -- question is what happened between startup and that time.
Sun Nov 13, 2016 8:29 am
farberm offline
Re: Errors
Here is the output in debug mode. I had turned it off. There is an error in the player that I have redefined as reference (See Adding Zone Player 192.168.1.30 - error. . During startup. and then the errors at the end.
Started plugin "Sonos 0.9.15"
Sonos Your plugin version, v0.9.15, is current.
Sonos Debug zoneIP: 192.168.1.31, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Debug Sonos Favorites: FV:2/16, Carly Simon, pndrradio:2445051497894555994?sn=1
Sonos Debug Sonos Favorites: FV:2/12, Classic Rocktopia, x-sonosapi-radio:channel%3a4e38561e77d9e74636000024%3a?sid=188&flags=8300&sn=13
Sonos Debug Sonos Favorites: FV:2/17, Colbie Caillat, pndrradio:214139991365431642?sn=1
Sonos Debug Sonos Favorites: FV:2/18, Country, pndrradio:85720898711761242?sn=1
Sonos Debug Sonos Favorites: FV:2/21, James Taylor, pndrradio:2679029470660833626?sn=1
Sonos Debug Sonos Favorites: FV:2/19, Janis Ian, pndrradio:214140652790395226?sn=1
Sonos Debug Sonos Favorites: FV:2/20, Jimmy Buffett, pndrradio:2592086628076532058?sn=1
Sonos Debug Sonos Favorites: FV:2/14, Seventies, x-sonosapi-radio:channel%3a53ab03d50d11407073164a12?sid=188&flags=8300&sn=13
Sonos Loaded Sonos Favorites... [8]
Sonos Loaded Playlists... [0]
Sonos Debug RadioTime Favorite Station: R:0/0/3, WCHL, x-sonosapi-stream:s27842?sid=254&flags=32
Sonos Loaded RadioTime Favorite Stations... [1]
Sonos Serving HTTP Streamer on 192.168.1.22 [0.0.0.0], port 9999
Sonos Debug Pandora: 85720683963396442, QuickMix,
Sonos Debug Pandora: 3292335991482397018, Carole King Radio,
Sonos Debug Pandora: 3238866491915546970, 70's Radio,
Sonos Debug Pandora: 3235566973484708186, Agnes Obel Radio,
Sonos Debug Pandora: 3235548694103896410, London Grammar Radio,
Sonos Debug Pandora: 3174870577262014810, 70s Rock Radio,
Sonos Debug Pandora: 3174866376783999322, Bachelorette Party Radio,
Sonos Debug Pandora: 3174622388281848154, Simon & Garfunkel Radio,
Sonos Debug Pandora: 2710133778437288282, TNT (70s) Radio,
Sonos Debug Pandora: 2710131785572462938, Egg (70s) Radio,
Sonos Debug Pandora: 2687575154204782938, Crosby, Stills, Nash & Young Radio,
Sonos Debug Pandora: 2679029470660833626, James Taylor Radio,
Sonos Debug Pandora: 2592086628076532058, Jimmy Buffett Radio,
Sonos Debug Pandora: 2512137220610765146, The Jazzmasters Radio,
Sonos Debug Pandora: 2512114246830698842, Mayfield Singers Radio,
Sonos Debug Pandora: 2511267536977965402, Irvin Mayfield Radio,
Sonos Debug Pandora: 2446850934572757338, Sting, Steven Mercurio & The Royal Philharmonic Concert Orchest,
Sonos Debug Pandora: 2445051497894555994, Carly Simon Radio,
Sonos Debug Pandora: 2438612414204916058, John Legend Radio,
Sonos Debug Pandora: 2436209861039141210, Hillsong Music Radio,
Sonos Debug Pandora: 2418019106877518170, Relaxing Panpipes Radio,
Sonos Debug Pandora: 2418013205592453466, Tranquill Radio,
Sonos Debug Pandora: 2418012600002064730, Dark Tranquillity Radio,
Sonos Debug Pandora: 2418011887037493594, Sleep Good Radio,
Sonos Debug Pandora: 2415502273221931354, The Christmas Songs Players Radio,
Sonos Debug Pandora: 2415501036271350106, Holiday Music (Holiday) Radio,
Sonos Debug Pandora: 2410839691085132122, Low (Holiday) Radio,
Sonos Debug Pandora: 2399806736145494362, Mariah Carey (Holiday) Radio,
Sonos Debug Pandora: 2399804850654851418, Christmas Decorations Radio,
Sonos Debug Pandora: 2387399451800678746, Pentatonix (Holiday) Radio,
Sonos Debug Pandora: 2386638121602822490, Carly Simon & James Taylor Radio,
Sonos Debug Pandora: 2352565617762677082, Bread Radio,
Sonos Debug Pandora: 2326513621750427994, Thalia Radio,
Sonos Debug Pandora: 2295288586738250074, Mozart Piano Quartet Radio,
Sonos Debug Pandora: 2295287972557926746, Mozart La Para Radio,
Sonos Debug Pandora: 2292158101040312666, The Phantom Of The Opera (2011 Cast) Radio,
Sonos Debug Pandora: 2292156821140058458, The Phantom Of The Opera (Original 1986 London Cast) Radio,
Sonos Debug Pandora: 2231523376253022554, 80s New Wave/Punk Radio,
Sonos Debug Pandora: 2231520614589051226, Aerobics Radio,
Sonos Debug Pandora: 2230005771033817434, Enya Radio,
Sonos Debug Pandora: 2224374274339811674, Frank Sinatra & Paul Anka Radio,
Sonos Debug Pandora: 2224373862022951258, Frank Sinatra And Sextet Radio,
Sonos Debug Pandora: 2224372156920934746, Frank Sinatra Radio,
Sonos Debug Pandora: 2192763959286346074, Antonio Carlos Jobim Radio,
Sonos Debug Pandora: 2164833177075102042, Johnny Richter Radio,
Sonos Debug Pandora: 2112955783230173530, (Sittin' On) The Dock Of The Bay Radio,
Sonos Debug Pandora: 2100328523545358682, Sarah Brightman Radio,
Sonos Debug Pandora: 1747364164085133658, Passenger Radio,
Sonos Debug Pandora: 1747317048293896538, Macklemore & Ryan Lewis Radio,
Sonos Debug Pandora: 1747228198305444186, Krewella Radio,
Sonos Debug Pandora: 1744354839414616410, Merry Christmas (Holiday) Radio,
Sonos Debug Pandora: 1744353555219394906, U.S. Christmas Radio,
Sonos Debug Pandora: 1736038717577671002, Holiday Radio,
Sonos Debug Pandora: 1687747599950066010, The Moody Blues Radio,
Sonos Debug Pandora: 1597268457387897178, Carolina Beach Music Radio,
Sonos Debug Pandora: 1597264248319947098, Urethra Franklin Radio,
Sonos Debug Pandora: 1434366304970256730, Third Eye Blind Radio,
Sonos Debug Pandora: 798661439505740122, Crosby, Stills, Nash & Young Radio,
Sonos Debug Pandora: 764556465712836954, Amos Lee Radio,
Sonos Debug Pandora: 521702139870490970, Christopher Cross Radio,
Sonos Debug Pandora: 521701414021017946, The Commodores Radio,
Sonos Debug Pandora: 224208623067902298, Pop / Rock,
Sonos Debug Pandora: 224183325710528858, If You Love Me Like You Say Radio,
Sonos Debug Pandora: 224183183976608090, Still Called The Blues Radio,
Sonos Debug Pandora: 214140949143138650, America Radio,
Sonos Debug Pandora: 214140652790395226, Janis Ian Radio,
Sonos Debug Pandora: 214139991365431642, Colbie Caillat Radio,
Sonos Debug Pandora: 214139823861707098, Coldplay Radio,
Sonos Debug Pandora: 214139695012688218, Viva La Vida Radio,
Sonos Debug Pandora: 214138887558836570, Nickelback Radio,
Sonos Debug Pandora: 214138324918120794, The Eagles Radio,
Sonos Debug Pandora: 214137727917666650, Lady Gaga Radio,
Sonos Debug Pandora: 214137139507147098, Adult Contemporary,
Sonos Debug Pandora: 214131328416395610, Train Radio,
Sonos Debug Pandora: 85721018970845530, Texas Blues,
Sonos Debug Pandora: 85720907301695834, Traditional Country,
Sonos Debug Pandora: 85720898711761242, Country Pop,
Sonos Debug Pandora: 85720868646990170, Contemporary Country,
Sonos Debug Pandora: 85720808517448026, New Orleans/Classic Jazz,
Sonos Debug Pandora: 85720787042611546, Big Band / Swing,
Sonos Loaded Pandora Stations for ... [80]
Sonos Debug IVONA: 0|English, American|Salli
Sonos Debug IVONA: 1|English, American|Joey
Sonos Debug IVONA: 2|Danish|Naja
Sonos Debug IVONA: 3|Danish|Mads
Sonos Debug IVONA: 4|German|Marlene
Sonos Debug IVONA: 5|German|Hans
Sonos Debug IVONA: 6|English, Australian|Nicole
Sonos Debug IVONA: 7|English, Australian|Russell
Sonos Debug IVONA: 8|English, British|Amy
Sonos Debug IVONA: 9|English, British|Brian
Sonos Debug IVONA: 10|English, British|Emma
Sonos Debug IVONA: 11|English, Welsh|Gwyneth
Sonos Debug IVONA: 12|English, Welsh|Geraint
Sonos Debug IVONA: 13|Welsh|Gwyneth
Sonos Debug IVONA: 14|Welsh|Geraint
Sonos Debug IVONA: 15|English, Indian|Raveena
Sonos Debug IVONA: 16|English, American|Chipmunk
Sonos Debug IVONA: 17|English, American|Eric
Sonos Debug IVONA: 18|English, American|Ivy
Sonos Debug IVONA: 19|English, American|Jennifer
Sonos Debug IVONA: 20|English, American|Justin
Sonos Debug IVONA: 21|English, American|Kendra
Sonos Debug IVONA: 22|English, American|Kimberly
Sonos Debug IVONA: 23|Spanish, Castilian|Conchita
Sonos Debug IVONA: 24|Spanish, Castilian|Enrique
Sonos Debug IVONA: 25|Spanish, American|Penelope
Sonos Debug IVONA: 26|Spanish, American|Miguel
Sonos Debug IVONA: 27|French, Canadian|Chantal
Sonos Debug IVONA: 28|French|Celine
Sonos Debug IVONA: 29|French|Mathieu
Sonos Debug IVONA: 30|Icelandic|Dora
Sonos Debug IVONA: 31|Icelandic|Karl
Sonos Debug IVONA: 32|Italian|Carla
Sonos Debug IVONA: 33|Italian|Giorgio
Sonos Debug IVONA: 34|Norweigian|Liv
Sonos Debug IVONA: 35|Dutch|Lotte
Sonos Debug IVONA: 36|Dutch|Ruben
Sonos Debug IVONA: 37|Polish|Agnieszka
Sonos Debug IVONA: 38|Polish|Jacek
Sonos Debug IVONA: 39|Polish|Ewa
Sonos Debug IVONA: 40|Polish|Jan
Sonos Debug IVONA: 41|Polish|Maja
Sonos Debug IVONA: 42|Portuguese, Brazilian|Vitoria
Sonos Debug IVONA: 43|Portuguese, Brazilian|Ricardo
Sonos Debug IVONA: 44|Portuguese|Cristiano
Sonos Debug IVONA: 45|Portuguese|Ines
Sonos Debug IVONA: 46|Romanian|Carmen
Sonos Debug IVONA: 47|Russian|Maxim
Sonos Debug IVONA: 48|Russian|Tatyana
Sonos Debug IVONA: 49|Swedish|Astrid
Sonos Debug IVONA: 50|Turkish|Filiz
Sonos Loaded IVONA Voices... [51]
Sonos [Sun Nov 13 09:23:57 2016] Processed plugin preferences.
Sonos SSDP Listener Started...
Sonos Debug ZonePlayer: Sonos - Living Room Playbar, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.33
Sonos Debug zoneIP: 192.168.1.33, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.33, RINCON_B8E937709B6C01400, Sonos - Living Room Playbar
Sonos Debug ZonePlayer: Sonos Attic Bedroom, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.36
Sonos Debug zoneIP: 192.168.1.36, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.36, RINCON_000E583712C001400, Sonos Attic Bedroom
Sonos Debug ZonePlayer: Sonos Kitchen, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.34
Sonos Debug zoneIP: 192.168.1.34, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.34, RINCON_000E58D4B44801400, Sonos Kitchen
Sonos Debug ZonePlayer: Sonos Master Bedroom, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.35
Sonos Debug zoneIP: 192.168.1.35, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.35, RINCON_000E58148DFA01400, Sonos Master Bedroom
Sonos Debug ZonePlayer: Sonos Office, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.37
Sonos Debug zoneIP: 192.168.1.37, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.37, RINCON_000E58D9D19C01400, Sonos Office
Sonos Debug ZonePlayer: Sonos Pool, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.31
Sonos Debug zoneIP: 192.168.1.31, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.31, RINCON_000E58A92C4E01400, Sonos Pool
Sonos Debug ZonePlayer: Sonos Theater Room, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.30
Sonos Error exception in deviceStartComm(Sonos Theater Room): HTTPConnectionPool(host='192.168.1.30', port=1400): Max retries exceeded [/size][/size]with url: /status/zp (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x5e60830>: Failed to establish a new connection: [Errno 61] Connection refused',))
Sonos Debug ZonePlayer: Sonos Workout Room, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.32
Sonos Debug zoneIP: 192.168.1.32, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Adding ZonePlayer: 192.168.1.32, RINCON_000E58122B2001400, Sonos Workout Room
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
Sonos Debug Processing Cover Art: Sonos - Living Room Playbar:http://cont-1.p-cdn.com/images/public/rovi/albumart/1/1/9/5/602527625911_500W_500H.jpg
Sonos Debug Update all states to slave ZonePlayers...
Sonos Debug zoneIP: 192.168.1.33, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos ZonePlayer: Sonos - Living Room Playbar, Nothing in Queue to Save
Sonos Debug Processing Cover Art: Sonos Attic Bedroom:None
Sonos Debug zoneIP: 192.168.1.36, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos ZonePlayer: Sonos Attic Bedroom, Nothing in Queue to Save
Sonos Debug Processing Cover Art: Sonos Kitchen:None
Sonos LineIn: RINCON_000E583712C001400, Audio Component:Attic Bedroom
Sonos Debug zoneIP: 192.168.1.34, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos ZonePlayer: Sonos Kitchen, Nothing in Queue to Save
Sonos LineIn: RINCON_000E58D4B44801400, Audio Component:Kitchen
Sonos Debug Processing Cover Art: Sonos Master Bedroom:http://mediaserver-cont-sv3-2-v4v6.pandora.com/images/public/rovi/albumart/9/2/0/4/888837584029_500W_500H.jpg
Sonos Debug zoneIP: 192.168.1.35, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos ZonePlayer: Sonos Master Bedroom, Nothing in Queue to Save
Sonos Debug Processing Cover Art: Sonos Office:None
Sonos LineIn: RINCON_000E58148DFA01400, Mic:Master Bedroom
Sonos Debug zoneIP: 192.168.1.37, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos ZonePlayer: Sonos Office, Nothing in Queue to Save
Sonos Debug Processing Cover Art: Sonos Pool:None
Sonos LineIn: RINCON_000E58D9D19C01400, Audio Component:Office
Sonos ZonePlayer: Sonos Pool, Nothing in Queue to Save
Sonos LineIn: RINCON_000E58A92C4E01400, Audio Component:Pool
Sonos Debug Processing Cover Art: Sonos Workout Room:None
Sonos Debug zoneIP: 192.168.1.32, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos ZonePlayer: Sonos Workout Room, Nothing in Queue to Save
Sonos LineIn: RINCON_000E58122B2001400, Audio Component:Workout Room
Nov 13, 2016, 9:24:30 AM
Sonos Debug [Sun Nov 13 09:24:30 2016] Received ALIVE message from ZonePlayer: Sonos Workout Room
Sonos Debug [Sun Nov 13 09:24:34 2016] Received ALIVE message from ZonePlayer: Sonos Master Bedroom
Sonos Debug [Sun Nov 13 09:24:35 2016] Received ALIVE message from ZonePlayer: Sonos Attic Bedroom
Sonos Debug [Sun Nov 13 09:24:36 2016] Received ALIVE message from ZonePlayer: Sonos Office
Sonos Debug [Sun Nov 13 09:24:39 2016] Received ALIVE message from ZonePlayer: Sonos Pool
Sonos Debug [Sun Nov 13 09:24:40 2016] Received ALIVE message from ZonePlayer: Sonos Kitchen
Sonos Debug [Sun Nov 13 09:24:43 2016] Received ALIVE message from ZonePlayer: Sonos - Living Room Playbar
Nov 13, 2016, 9:24:58 AM
Sonos Debug Processing Cover Art: Sonos Master Bedroom:http://mediaserver-cont-sv5-1-v4v6.pandora.com/images/public/rovi/albumart/1/2/1/9/075596059121_500W_500H.jpg
Sun Nov 13, 2016 8:31 am
farberm offline
Re: Errors
Eror appears fairly quickly after starting.
Sun Nov 13, 2016 8:33 am
nlagaros offline
Re: Errors
Thinking more. Can you check the Indigo device GUI and tell me what the value for the the alive state is. Should look something like the attached.
Sun Nov 13, 2016 8:37 am
farberm offline
Re: Errors
alive state appears blank ""
Screen Shot 2016-11-13 at 9.35.16 AM.png (27.83 KiB) Viewed 3417 times
Sun Nov 13, 2016 8:40 am
farberm offline
Re: Errors
All of my other players states are showing dates for alive etc. Just the theater Room (192.168.1.30) does not show anything.
nlagaros offline
Re: Errors
Ahhh.. what is the story with the Theater Room ZonePlayer. Is it turned off? If so, you need to disable it in Indigo.
Sun Nov 13, 2016 8:42 am
farberm offline
Re: Errors
No it is turned on?
farberm offline
Re: Errors
Maybe I need to reboot it?
