Change volume issue
Sun Jul 17, 2016 8:05 am
Nine offline
Change volume issue
If I control the volume of my sonos soundbar there is from time to time this issue: changing the volume does only works the first time - every next attempt has no effect. The Log shows (trying to lower the volume from 14 three times to 8 ):
  Sonos                           ZonePlayer: Sonos:Playbar, Current Volume: 14, New Volume: 12
Nine
Mon Aug 15, 2016 11:34 am
Ramias offline
Re: Change volume issue
I may have a similar problem. This is in the logs after a restart of the Sonos Plugin recently:
  Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 117, in actionVolumeDown
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1041, in actionDirect
ValueError: invalid literal for int() with base 10: ''
  Sonos                           ZonePlayer: Sonos Bedroom, Current Volume: 52, New Volume: 50
  File "plugin.py", line 120, in actionVolumeUp
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1049, in actionDirect
  Sonos                           ZonePlayer: Sonos Basement, Current Volume: 100, New Volume: 100
  Schedule                        If Sonos Living Room is Playing Turn on LED (delayed action)
  Schedule                        If Sonos Bedroom is Playing Turn on LED (delayed action)
  Schedule                        Reset StartPlayingSonos variable (delayed action)
  Sonos Error                     UPNP Error: 500
  Sonos Error                     Offending Command -> zoneIP: 192.168.0.33, soapRoot: /MediaRenderer, soapBranch: /Queue, soapAction: SaveAsSonosPlaylist
  Sonos                           ZonePlayer: Sonos Living Room, Save Queue: Indigo_RINCON_000E588C8B6A01400
  Sonos                           LineIn: RINCON_000E588C8B6A01400, Audio Component:Living Room
  Sonos                           ZonePlayer: Sonos Office, Cannot Save Queue for Slave
  Trigger                         Sonos Patio Stopped
  Trigger                         Set Patio Mute Variable On
  Sonos                           ZonePlayer: Sonos Patio, Nothing in Queue to Save
Mon Aug 15, 2016 1:18 pm
nlagaros offline
What version of OS X and the plugin are you running? I am pretty sure that anything less than 10.7 of OS X is going to be an issue.
Nine
Mon Aug 15, 2016 1:20 pm
nlagaros offline
Can you tell me what version of OS X and the plugin you are running? Thanks.
Mon Aug 15, 2016 10:33 pm
Nine offline
Nine
I'm running 10.10.5 :roll:
Tue Aug 16, 2016 6:41 am
Ramias offline
Plugin .0.9.8
Indigo 6.1.10
OSX 10.11.6
Tue Aug 16, 2016 11:39 am
nlagaros offline
Please try the update I just posted and turn all debugging on from plugin start to when you run the volume action. That should tell us what is going on. Thanks.
Ramias wrote:
Plugin .0.9.8
Indigo 6.1.10
OSX 10.11.6
Fri Sep 16, 2016 7:27 pm
gsades offline
I have the exact same problem described by Nine. I'm running v.0.9.10 and here are the full logs obtained when tried to increase the volume 3 consecutive times:
  Sonos Debug                     zoneIP: 10.0.1.24, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:GetMediaInfo xmlns:ns0="urn:schemas-upnp-org:service:AVTransport:1"><InstanceID>0</InstanceID></ns0:GetMediaInfo></s:Body></s:Envelope>
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMediaInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><NrTracks>1</NrTracks><MediaDuration>NOT_IMPLEMENTED</MediaDuration><CurrentURI>x-rincon:RINCON_B8E937E3E2DE01400</CurrentURI><CurrentURIMetaData></CurrentURIMetaData><NextURI></NextURI><NextURIMetaData></NextURIMetaData><PlayMedium>NETWORK</PlayMedium><RecordMedium>NOT_IMPLEMENTED</RecordMedium><WriteStatus>NOT_IMPLEMENTED</WriteStatus></u:GetMediaInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.24, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:GetPositionInfo xmlns:ns0="urn:schemas-upnp-org:service:AVTransport:1"><InstanceID>0</InstanceID></ns0:GetPositionInfo></s:Body></s:Envelope>
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetPositionInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><Track>1</Track><TrackDuration>NOT_IMPLEMENTED</TrackDuration><TrackMetaData>NOT_IMPLEMENTED</TrackMetaData><TrackURI>x-rincon:RINCON_B8E937E3E2DE01400</TrackURI><RelTime>NOT_IMPLEMENTED</RelTime><AbsTime>NOT_IMPLEMENTED</AbsTime><RelCount>2147483647</RelCount><AbsCount>2147483647</AbsCount></u:GetPositionInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.27, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMediaInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><NrTracks>156</NrTracks><MediaDuration>NOT_IMPLEMENTED</MediaDuration><CurrentURI>x-rincon-queue:RINCON_B8E937BF15F201400#0</CurrentURI><CurrentURIMetaData></CurrentURIMetaData><NextURI></NextURI><NextURIMetaData></NextURIMetaData><PlayMedium>NETWORK</PlayMedium><RecordMedium>NOT_IMPLEMENTED</RecordMedium><WriteStatus>NOT_IMPLEMENTED</WriteStatus></u:GetMediaInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.27, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetPositionInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><Track>4</Track><TrackDuration>0:03:47</TrackDuration><TrackMetaData>&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;res protocolInfo=&quot;sonos.com-spotify:*:audio/x-spotify:*&quot; duration=&quot;0:03:47&quot;&gt;x-sonos-spotify:spotify%3atrack%3a1zHW5fzog024qJa6K2U7KA?sid=9&amp;amp;flags=8224&amp;amp;sn=1&lt;/res&gt;&lt;r:streamContent&gt;&lt;/r:streamContent&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1zHW5fzog024qJa6K2U7KA%3fsid%3d9%26flags%3d8224%26sn%3d1&lt;/upnp:albumArtURI&gt;&lt;dc:title&gt;Something In The Way You Move&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.musicTrack&lt;/upnp:class&gt;&lt;dc:creator&gt;Ellie Goulding&lt;/dc:creator&gt;&lt;upnp:album&gt;Something In The Way You Move&lt;/upnp:album&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</TrackMetaData><TrackURI>x-sonos-spotify:spotify%3atrack%3a1zHW5fzog024qJa6K2U7KA?sid=9&amp;flags=8224&amp;sn=1</TrackURI><RelTime>0:00:20</RelTime><AbsTime>NOT_IMPLEMENTED</AbsTime><RelCount>2147483647</RelCount><AbsCount>2147483647</AbsCount></u:GetPositionInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.25, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMediaInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><NrTracks>17</NrTracks><MediaDuration>NOT_IMPLEMENTED</MediaDuration><CurrentURI>x-rincon-queue:RINCON_B8E937E3E2DE01400#0</CurrentURI><CurrentURIMetaData></CurrentURIMetaData><NextURI></NextURI><NextURIMetaData></NextURIMetaData><PlayMedium>NETWORK</PlayMedium><RecordMedium>NOT_IMPLEMENTED</RecordMedium><WriteStatus>NOT_IMPLEMENTED</WriteStatus></u:GetMediaInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.25, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetPositionInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><Track>9</Track><TrackDuration>0:03:38</TrackDuration><TrackMetaData>&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;-1&quot; parentID=&quot;-1&quot; restricted=&quot;true&quot;&gt;&lt;res protocolInfo=&quot;sonos.com-http:*:audio/mp4:*&quot; duration=&quot;0:03:38&quot;&gt;x-sonos-http:song%3a419338939.mp4?sid=204&amp;amp;flags=8224&amp;amp;sn=2&lt;/res&gt;&lt;r:streamContent&gt;&lt;/r:streamContent&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a419338939.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2&lt;/upnp:albumArtURI&gt;&lt;dc:title&gt;Corps et cœur (Cuerpo y Corazón)&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem.musicTrack&lt;/upnp:class&gt;&lt;dc:creator&gt;Mecano&lt;/dc:creator&gt;&lt;upnp:album&gt;Ana, José, Nacho&lt;/upnp:album&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</TrackMetaData><TrackURI>x-sonos-http:song%3a419338939.mp4?sid=204&amp;flags=8224&amp;sn=2</TrackURI><RelTime>0:00:08</RelTime><AbsTime>NOT_IMPLEMENTED</AbsTime><RelCount>2147483647</RelCount><AbsCount>2147483647</AbsCount></u:GetPositionInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.22, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMediaInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><NrTracks>0</NrTracks><MediaDuration>NOT_IMPLEMENTED</MediaDuration><CurrentURI></CurrentURI><CurrentURIMetaData></CurrentURIMetaData><NextURI></NextURI><NextURIMetaData></NextURIMetaData><PlayMedium>NONE</PlayMedium><RecordMedium>NOT_IMPLEMENTED</RecordMedium><WriteStatus>NOT_IMPLEMENTED</WriteStatus></u:GetMediaInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.22, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetPositionInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><Track>0</Track><TrackDuration>0:00:00</TrackDuration><TrackMetaData></TrackMetaData><TrackURI></TrackURI><RelTime>0:00:00</RelTime><AbsTime>NOT_IMPLEMENTED</AbsTime><RelCount>2147483647</RelCount><AbsCount>2147483647</AbsCount></u:GetPositionInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.141, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMediaInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><NrTracks>0</NrTracks><MediaDuration>NOT_IMPLEMENTED</MediaDuration><CurrentURI>x-rincon-queue:RINCON_5CAAFD78AFE401400#0</CurrentURI><CurrentURIMetaData></CurrentURIMetaData><NextURI></NextURI><NextURIMetaData></NextURIMetaData><PlayMedium>NETWORK</PlayMedium><RecordMedium>NOT_IMPLEMENTED</RecordMedium><WriteStatus>NOT_IMPLEMENTED</WriteStatus></u:GetMediaInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.141, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetMediaInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><NrTracks>1</NrTracks><MediaDuration>NOT_IMPLEMENTED</MediaDuration><CurrentURI>x-sonos-htastream:RINCON_B8E9377BE34901400:spdif</CurrentURI><CurrentURIMetaData>&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;spdif-input&quot; parentID=&quot;0&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;RINCON_B8E9377BE34901400&lt;/dc:title&gt;&lt;upnp:class&gt;object.item.audioItem&lt;/upnp:class&gt;&lt;res protocolInfo=&quot;spdif&quot;&gt;x-sonos-htastream:RINCON_B8E9377BE34901400:spdif&lt;/res&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</CurrentURIMetaData><NextURI></NextURI><NextURIMetaData></NextURIMetaData><PlayMedium>NETWORK</PlayMedium><RecordMedium>NOT_IMPLEMENTED</RecordMedium><WriteStatus>NOT_IMPLEMENTED</WriteStatus></u:GetMediaInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetPositionInfoResponse xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><Track>1</Track><TrackDuration>NOT_IMPLEMENTED</TrackDuration><TrackMetaData>NOT_IMPLEMENTED</TrackMetaData><TrackURI>x-sonos-htastream:RINCON_B8E9377BE34901400:spdif</TrackURI><RelTime>NOT_IMPLEMENTED</RelTime><AbsTime>NOT_IMPLEMENTED</AbsTime><RelCount>2147483647</RelCount><AbsCount>2147483647</AbsCount></u:GetPositionInfoResponse></s:Body></s:Envelope>
  Sonos Debug                     zoneIP: 10.0.1.26, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
  Sonos Debug                     zoneIP: 10.0.1.26, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
  Sonos Debug                     Sonos Action: Volume Up
  Sonos Debug                     zoneIP: 10.0.1.21, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetVolume
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:SetVolume xmlns:ns0="urn:schemas-upnp-org:service:RenderingControl:1"><InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>13</DesiredVolume></ns0:SetVolume></s:Body></s:Envelope>
  Sonos Debug                     <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:SetVolumeResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"></u:SetVolumeResponse></s:Body></s:Envelope>
  Sonos                           ZonePlayer: lg.so.pb, Current Volume: 11, New Volume: 13
  Trigger                         Subir volumen PB
Fri Sep 16, 2016 11:38 pm
nlagaros offline
It looks like you have a trigger running that is continuously saving the states of all ZonePlayers? I'm wondering if all of those calls are interfering. Is it possible to turn that off for the sake of debugging this issue?
Fri Sep 16, 2016 11:50 pm
gsades offline
That's right. I included a save states command in the trigger as one of the actions to be tried to solve this issue. Now is deleted and the log shows the following:
Fri Sep 16, 2016 11:53 pm
nlagaros offline
Ok.. let's keep going. Do you have all the debugging options turned on? Include SocoEvents if you have not already. It is the last one on the config screen.
Sat Sep 17, 2016 12:02 am
gsades offline
Yes, all of them are selected... but this is weird.
Before answering this post, just to be sure, I went to double check that. And in the sake to be super sure I reloaded the plugin and rerun the test to see if anything changed in the log. Not only the output was different this time, but also the device behavior. Now it seems to be working!!! I did not change anything, but at least by the log info (it's 1am now and I can't go "live" to test this if I want to remain married), it may be fixed.
Here are the logs:
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:SetVolume xmlns:ns0="urn:schemas-upnp-org:service:RenderingControl:1"><InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>15</DesiredVolume></ns0:SetVolume></s:Body></s:Envelope>
  Sonos                           ZonePlayer: lg.so.pb, Current Volume: 13, New Volume: 15
  Sonos Debug                     [Sat Sep 17 00:55:59 2016] [lg.so.pb] [SoCo RenderingControl] {'volume': {'LF': '100', 'RF': '100', 'Master': '15'}}
  Sonos Debug                         Updating Device: lg.so.pb, State: ZP_VOLUME, Value: 15
  Sonos Debug                     [Sat Sep 17 00:55:59 2016] [lg.so.pb] [SoCo GroupRenderingControl] {u'group_volume_changeable': '1', u'group_mute': '0', u'group_volume': '15'}
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:SetVolume xmlns:ns0="urn:schemas-upnp-org:service:RenderingControl:1"><InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>17</DesiredVolume></ns0:SetVolume></s:Body></s:Envelope>
  Sonos                           ZonePlayer: lg.so.pb, Current Volume: 15, New Volume: 17
  Sonos Debug                     [Sat Sep 17 00:56:00 2016] [lg.so.pb] [SoCo RenderingControl] {'volume': {'LF': '100', 'RF': '100', 'Master': '17'}}
  Sonos Debug                         Updating Device: lg.so.pb, State: ZP_VOLUME, Value: 17
  Sonos Debug                     [Sat Sep 17 00:56:00 2016] [lg.so.pb] [SoCo GroupRenderingControl] {u'group_volume_changeable': '1', u'group_mute': '0', u'group_volume': '17'}
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:SetVolume xmlns:ns0="urn:schemas-upnp-org:service:RenderingControl:1"><InstanceID>0</InstanceID><Channel>Master</Channel><DesiredVolume>19</DesiredVolume></ns0:SetVolume></s:Body></s:Envelope>
  Sonos                           ZonePlayer: lg.so.pb, Current Volume: 17, New Volume: 19
  Sonos Debug                     [Sat Sep 17 00:56:02 2016] [lg.so.pb] [SoCo RenderingControl] {'volume': {'LF': '100', 'RF': '100', 'Master': '19'}}
  Sonos Debug                         Updating Device: lg.so.pb, State: ZP_VOLUME, Value: 19
  Sonos Debug                     [Sat Sep 17 00:56:02 2016] [lg.so.pb] [SoCo GroupRenderingControl] {u'group_volume_changeable': '1', u'group_mute': '0', u'group_volume': '19'}
Sat Sep 17, 2016 12:12 am
nlagaros offline
Strange - it seems somehow the subscriptions to ZonePlayer events stopped. Next version will have an auto-resubscribe if it detects ZonePlayers have not been responsive...
Here are the logs:
Sat Sep 17, 2016 12:14 am
gsades offline
Thank you for caring. And thanks A LOT for your work and this excellent plugin.
Wed Sep 21, 2016 1:18 am
RAID5 offline
I just upgraded to El Capitain (10.11.6) on my Mac Mini Late 2009 and after the upgrade this plugin works alot better!
RAID5 "A happy Swede addicted to automation"
