Got this weird error since upgrading to 0.9.8
Sun Jul 03, 2016 11:22 am
pereza1 offline
Did I forget to do prework prior to upgrading?...
Starting plugin "Sonos 0.9.8" (pid 95248)
Started plugin "Sonos 0.9.8"
Sonos Your plugin version, v0.9.8, is current.
Sonos Loaded Sonos Favorites... [18]
Sonos Loaded Playlists... [9]
Sonos Loaded RadioTime Favorite Stations... [0]
Sonos Serving HTTP Streamer on 192.168.109.200 [0.0.0.0], port 8888
Sonos Loaded Pandora Stations... [68]
Sonos [Sun Jul 3 10:14:01 2016] Processed plugin preferences.
Sonos Error Error in plugin execution startup:
File "plugin.py", line 36, in startup
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 260, in startup
File "./lib/twisted/internet/posixbase.py", line 387, in listenMulticast
File "./lib/twisted/internet/udp.py", line 175, in startListening
File "./lib/twisted/internet/udp.py", line 195, in _bindSocket
CannotListenError: Couldn't listen on any:1900: [Errno 48] Address already in use.
Mon Aug 15, 2016 1:26 pm
nlagaros offline
Re: Got this weird error since upgrading to 0.9.8
Is it possible you might have some other plugin or app that has locked port 1900? The Sonos plugin will try to open the socket in a shared mode.
Mon Oct 10, 2016 1:29 pm
Ramias offline
I am now getting this too when I restart the plugin.
Started plugin "Sonos 0.9.10"
  Sonos                           Your plugin version, v0.9.10, is current.
  Sonos                           Loaded Sonos Favorites... [14]
  Sonos                           Loaded Playlists... [5]
  Sonos                           Loaded RadioTime Favorite Stations... [2]
  Sonos                           Loaded Sound Files... [1]
  Sonos                           Serving HTTP Streamer on 192.168.0.X [0.0.0.0], port 8888
  Sonos                           Loaded Pandora Stations for ... [26]
  Sonos                           [Mon Oct 10 14:49:31 2016] Processed plugin preferences.
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 265, in startup
And from Terminal... Doesn't look like anything on port 1900.
sudo lsof -i -P | grep -i "listen"
launchd       1           root   19u  IPv4 0x3be3e58f21b0ba77      0t0    TCP *:445 (LISTEN)
launchd       1           root   20u  IPv6 0x3be3e58f1f01c307      0t0    TCP *:445 (LISTEN)
launchd       1           root   24u  IPv4 0x3be3e58f21b1836f      0t0    TCP *:5900 (LISTEN)
launchd       1           root   26u  IPv4 0x3be3e58f21b1836f      0t0    TCP *:5900 (LISTEN)
launchd       1           root   29u  IPv6 0x3be3e58f1c1f5307      0t0    TCP *:5900 (LISTEN)
launchd       1           root   31u  IPv4 0x3be3e58f21b0ba77      0t0    TCP *:445 (LISTEN)
launchd       1           root   37u  IPv6 0x3be3e58f167cd847      0t0    TCP *:22 (LISTEN)
launchd       1           root   38u  IPv4 0x3be3e58f167d036f      0t0    TCP *:22 (LISTEN)
launchd       1           root   40u  IPv6 0x3be3e58f167cd847      0t0    TCP *:22 (LISTEN)
launchd       1           root   42u  IPv4 0x3be3e58f167d036f      0t0    TCP *:22 (LISTEN)
launchd       1           root   45u  IPv6 0x3be3e58f1f01c307      0t0    TCP *:445 (LISTEN)
launchd       1           root   49u  IPv6 0x3be3e58f1c1f5307      0t0    TCP *:5900 (LISTEN)
hdhomerun   110     _HDHomeRun   12u  IPv4 0x3be3e58f167d155f      0t0    TCP *:49152 (LISTEN)
node        346           user   11u  IPv6 0x3be3e58f167cd307      0t0    TCP *:51826 (LISTEN)
node        346           user   14u  IPv6 0x3be3e58f1a167307      0t0    TCP *:62161 (LISTEN)
node        346           user   20u  IPv6 0x3be3e58f21a56307      0t0    TCP *:62537 (LISTEN)
node        346           user   24u  IPv6 0x3be3e58f21a55dc7      0t0    TCP *:62002 (LISTEN)
IndigoSer   385           user    7u  IPv4 0x3be3e58f1c450c67      0t0    TCP *:1176 (LISTEN)
IndigoPlu   422           user    8u  IPv4 0x3be3e58f1dabe55f      0t0    TCP mac.user.net:8177 (LISTEN)
Python      444           user    3u  IPv4 0x3be3e58f1dcf2c67      0t0    TCP *:8176 (LISTEN)
awacsd    43030           root    7u  IPv6 0x3be3e58f1c1f4dc7      0t0    TCP [ip v 6]:4488 (LISTEN)
kdc       43063           root    5u  IPv6 0x3be3e58f1a166dc7      0t0    TCP *:88 (LISTEN)
kdc       43063           root    7u  IPv4 0x3be3e58f1e38b74f      0t0    TCP *:88 (LISTEN)
Sonos     53782           user   18u  IPv4 0x3be3e58f21bb8e57      0t0    TCP *:3400 (LISTEN)
IndigoPlu 56338           user   10u  IPv4 0x3be3e58f21b9674f      0t0    TCP *:1400 (LISTEN)
IndigoPlu 56338           user   12u  IPv4 0x3be3e58f2905374f      0t0    TCP *:8888 (LISTEN)
Mon Oct 10, 2016 3:01 pm
nlagaros offline
You have some other application that is using port 1900 in a non-sharing mode.
Mon Oct 10, 2016 4:08 pm
Ramias offline
Yep. it was HDhomerun. Not sure how it was able to grab that port. It's been fine for a month now.
I think I have this resolved now. Thanks
Mon Oct 10, 2016 4:14 pm
nlagaros offline
Great... sorry for being absent... in London on business if any locals want to hunt me down for the shortage up updates.
