[solved] Error in plugin execution ExecuteAction:
Sat Jun 11, 2016 8:20 am
Nine offline
I get my first sonos today: a playbar 8) It's connected to my tv and my network > I have installed the newest sonos-plugin 0.9.8 and added the playbar in Indigo. But now I can't control them: trying to change volume or toggle mute does not work. The log says:
11.06.2016, 16:10:34
  Schedule                        new schedule
  Sonos Debug                     Sonos Action: Volume Up
  Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 120, in actionVolumeUp
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1049, in actionDirect
ValueError: invalid literal for int() with base 10: ''
11.06.2016, 16:11:37
  Trigger                         new trigger
  Sonos Debug                     Sonos Action: Mute Toggle
  File "plugin.py", line 96, in actionMuteToggle
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1000, in actionDirect
Did I miss something in the installation-process?!?
Nine
Sat Jun 11, 2016 8:22 am
Re: Error in plugin execution ExecuteAction:
Just a general remark. The error int() with base 10 comes in many cases from an empty parameter setting. Check the configs and make sure all parameters are set
Sat Jun 11, 2016 8:26 am
Nine offline
There is nothing left blank in my eyes... :roll:
Bildschirmfoto 2016-06-11 um 16.24.42.png (34.14 KiB) Viewed 2104 times
Bildschirmfoto 2016-06-11 um 16.24.27.png (231.03 KiB) Viewed 2104 times
Sat Jun 11, 2016 11:49 am
Nine offline
Restarted the plugin - and it works :roll:
Fri Jul 15, 2016 1:37 pm
adamfox offline
Re: [solved] Error in plugin execution ExecuteAction:
I'm in the same boat but a restart doesn't seem to solve my issue. Any ideas? Everything seems to be configured properly.
Mon Aug 15, 2016 1:31 pm
nlagaros offline
Are you getting any state updates for your ZonePlayers? Can you post the logs and I can have a look. Thanks.
