sonos errors 9.1 action group
Tue Feb 16, 2016 6:29 am
Seeker offline
I just noticed a scheduled action group to play a sonos channel gives me this error:
File "plugin.py", line 184, in actionZP_RT_FavStation
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1422, in actionDirect
<type 'exceptions.UnboundLocalError'>: local variable 'CoordinatorIP' referenced before assignment
everything else with the plugin seems to work fine, it's just this one action group that does not play.
any ideas?
Tue Feb 16, 2016 7:26 am
nlagaros offline
Re: sonos errors 9.1 action group
Is the ZonePlayer in this action part of a group?
Tue Feb 16, 2016 9:49 am
Seeker offline
You mean a stereo pair? No, this particular unit is a standalone zone.
Tue Feb 16, 2016 4:38 pm
Seeker offline
i think i misunderstood you. yes, the particular unit starts out as grouped with another unit. i think this is where the problem is.
Thu Feb 18, 2016 6:21 am
Seeker offline
Still not fully working, but most of the plugin functions work great. On one of my four zones, i get the error below when i use sonos action 'play radiotime favorite'. The first run below is on the problem zone. the next three are where i switch the action group to other zones. they work fine.
all zones are set to standalone.
Any ideas?
Feb 18, 2016, 6:16:28 AM
  Action Group                    sonos test
  Sonos Error                     Error in plugin execution ExecuteAction:
Feb 18, 2016, 6:17:34 AM
Feb 18, 2016, 6:18:22 AM
Feb 18, 2016, 6:18:50 AM
Feb 18, 2016, 6:19:16 AM
Thu Feb 18, 2016 6:48 am
nlagaros offline
I may have a logic bug, but suspect that events are not coming in when they should to update the required states. I'd like you to restart the plugin and try again -- but before you do that, can you tell me the values of these states for the problem ZonePlayer: ZP_LocalUID, GROUP_Name, ZoneGroupID
Any ideas?
Thu Feb 18, 2016 7:02 am
Seeker offline
The plugin restart fixed it temporarily.
here are the values from the problem zone (sonos bedroom play 1 new)
before restart
ZP_LocalUID=RINCON_B8E93780254001400
GROUP_Name=RINCON_B8E93780254001400:530
ZoneGroupID=RINCON_B8E93780254001400:530
after restart
GROUP_Name=RINCON_B8E93780254001400:531
ZoneGroupID=RINCON_B8E93780254001400:531
after plugin restart, the simple action group to play radio time on the bedroom unit works without error.
however, then i grouped the bedroom to the living room (living room master), rand an action to set bedroom to standalone. that worked, then when i try to play the bedroom unit i get the error.
sonos test action is play radio time fav on bedroom
sonos test copy is set bedroom unit to standalone
Sonos                           ZonePlayer: S2GR left, Save Queue: Indigo_RINCON_000E588D1EC601400
  Sonos                           LineIn: RINCON_000E588D1EC601400, Audio Component:GR (L)
  Sonos                           ZonePlayer: S3BA, Nothing in Queue to Save
  Sonos                           ZonePlayer: S4GAR, Save Queue: Indigo_RINCON_B8E93780254E01400
  Sonos                           ZonePlayer: sonos bedroom play1 new, Remove Playlist: Indigo_RINCON_B8E93780254001400
  Sonos                           ZonePlayer: sonos bedroom play1 new, Nothing in Queue to Save
  Sonos                           Loaded Playlists... [6]
Feb 18, 2016, 6:56:34 AM
Feb 18, 2016, 6:57:52 AM
Feb 18, 2016, 6:58:09 AM
  Sonos                           ZonePlayer: sonos bedroom play1 new, Cannot Save Queue for Slave
  Action Group                    sonos test copy
  Sonos                           remove zone from group: sonos bedroom play1 new
Feb 18, 2016, 6:58:40 AM
Thu Feb 18, 2016 7:05 am
nlagaros offline
So I understand. The zone was not grouped before the restart. You then grouped it with the Sonos app and ungrouped it with Indigo. This is when failure occurred?
before restart
after restart
Thu Feb 18, 2016 7:28 am
Seeker offline
Yes
Thu Feb 18, 2016 7:32 am
nlagaros offline
And I consistently replicate the issue on my end. I will investigate. In the meanwhile, if you are desperate to get back to a working state, you can switch the event processor back to Coherence in the main plugin configuration.
Thu Feb 18, 2016 7:53 am
Seeker offline
Awesome! Thanks
Thu Feb 18, 2016 6:43 pm
Seeker offline
Nick, I just checked this when I got home and mine was set to use coherence. That was how it defaulted when I upgraded, I guess. I switched it to the soco and get the same results. So I get the same behavior with either processor selected.
Sat Feb 20, 2016 6:25 am
nlagaros offline
Would you try downloading the new version of the plugin (v0.9.2) that I just posted. I think it will correct most of what is going on. Thanks.
Sat Feb 20, 2016 6:40 am
Seeker offline
Thanks.
Installed 9.2, a quick test of the problem actions (ungroup, play radio time) work fine now. also did a quick test of other functions and all seems normal. using soco processor. I'll play around some more today, but it looks like this issue is fixed! Thanks again!!
Sat Feb 20, 2016 6:45 am
nlagaros offline
Awesome!
Seeker wrote:
Thanks.
