Sonos v0.9.1 Errors
Sat Feb 13, 2016 4:26 pm
kennybroh offline
Sonos v0.9.1 Errors
Just upgraded to 0.9.1 from a version 8 plug-in. I haven't gotten email notifications and wasn't checking the forum.
I opened and saved the configuration, and set the processor to SoCo and reloaded the plug-n. Some of my players are not connected at the moment, but I am getting other errors:
 Feb 13, 2016, 5:29:07 PM
  Started plugin "Sonos 0.9.1"
  Sonos                           Your plugin version, v0.9.1, is current.
  Sonos                           Loaded Sonos Favorites... [0]
  Sonos                           Loaded Playlists... [2]
  Sonos                           Loaded RadioTime Favorite Stations... [6]
  Sonos                           Loaded Pandora Stations... [100]
  Sonos                           Loaded SiriusXM Stations.. [370]
  Sonos                           Adding ZonePlayer: 192.168.10.17, RINCON_000E58700BAC01400, Dining Room Left
  Sonos                           Adding ZonePlayer: 192.168.10.22, RINCON_000E58701D1A01400, Dining Room RIght
  Sonos                           Adding ZonePlayer: 192.168.10.97, RINCON_000E5852090C01400, Kitchen Sonos
  Sonos                           Adding ZonePlayer: 192.168.10.27, RINCON_000E582545D601400, Library Sonos
  Sonos                           Adding ZonePlayer: 192.168.10.176, RINCON_000E5824EF5A01400, MBR Sonos
  Error                           email scan authentication failed
  Sonos                           Adding ZonePlayer: 192.168.10.24, RINCON_000E582516DA01400, Nook Sonos
  Sonos                           Adding ZonePlayer: 192.168.10.12, RINCON_000E5828BB7801400, Theatre Sonos
  Sonos                           Serving HTTP Streamer on 192.168.10.43 [0.0.0.0], port 8888
  Received INSTEON                "master bedroom thermostat" temperature changed to 68.0
  Sonos                           ZonePlayer: Dining Room Left, Save Queue: Indigo_RINCON_000E58700BAC01400
  Sonos                           ZonePlayer: Dining Room RIght, Cannot Save Queue for Slave
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 381, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 776, in socoEvents
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2190, in copyStateFromMaster
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/shutil.py", line 95, in copy2
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/shutil.py", line 50, in copyfile
<type 'exceptions.IOError'>: [Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/images/Sonos/Dining Room (L)_art.jpg'
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Is there some setting I've missed?
Sat Feb 13, 2016 4:49 pm
kennybroh offline
Re: Sonos
Also, when I tried to play or pause one of the players, i got the following errors. The status in the Indigo device list says playing, but on the control page the variable says stopped.
  WebServer                       request to execute "MBR" control #79 from 127.0.0.1
  Sonos                           ZonePlayer: MBR Sonos, Pause
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 785, in socoEvents
<type 'exceptions.KeyError'>: 'audioIn'
And I get that error with every player and every action and it repeats every 10 seconds.,
Sun Feb 14, 2016 7:50 am
nlagaros offline
Re: Sonos v0.9.1 Errors
Are your Dining Room ZonePlayers setup as a stereo pair? If that is so, only one needs to be modeled in Indigo - and it has to be the master of the two. Please refer to the following to figure out which one it is: https://vulture.lagaros.com/wiki/pages/88T3o44/Devices.html.
I may also have some additional error handling to put in place -- will check that out as well.
Sun Feb 14, 2016 7:52 am
nlagaros offline
Re: Sonos
Would you check each one of your modeled ZonePlayers and make sure the speaker type is selected. (e.g. CONNECT, PLAY:1, PLAY:3, etc.).
Sun Feb 14, 2016 8:58 am
kennybroh offline
Bingo.
I disables communications for the slave dining room player, and then discovered I incorrectly defined the other dining room player as a Play 5 when it was a Play 3. I reloaded the plug in and no more errors. I wonder why the prior versions didn't bark at that.
But thanks. All good!
Wed Feb 17, 2016 7:45 am
jayh391 offline
Below is the log, the artist and other items is not picking up the value.
Feb 17, 2016, 5:43:13 AM
Sonos Debug Updating Device: Office Sonos, State: ZP_STATE, Value: TRANSITIONING
Sonos Debug Updating Device: Office Sonos, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Office Sonos, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Office Sonos, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Office Sonos, State: ZP_CurrentTrack, Value: 1
Sonos Debug Updating Device: Office Sonos, State: ZP_CurrentTrackURI, Value: x-sonosapi-hls:r%3aclassicrewind?sid=37&flags=288
Sonos Debug Updating Device: Office Sonos, State: ZP_DURATION, Value: 0:00:00
Sonos Debug Updating Device: Office Sonos, State: ZP_TRACK, Value: x-sonosapi-hls:r:classicrewind?sid=37&flags=288
Sonos Debug Updating Device: Office Sonos, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_ARTIST, Value:
Sonos Debug Processing Cover Art: Office Sonos:/getaa?s=1&u=x-sonosapi-hls%3ar%253aclassicrewind%3fsid%3d37%26flags%3d288
Sonos Debug Updating Device: Office Sonos, State: ZP_ART, Value: http://10.5.6.141:1400/getaa?s=1&u=x-so ... lags%3d288
Sonos Debug Updating Device: Office Sonos, State: ZP_INFO, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_STATION, Value: 25 - Classic Rewind
Sonos Debug Updating Device: Office Sonos, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_NCREATOR, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_NART, Value:
Sonos Debug Updating Device: Office Sonos, State: ZP_INFO, Value: ZPSTR_CONNECTING
Sonos Debug Updating Device: Office Sonos, State: ZP_STATE, Value: PLAYING
Sonos Debug Processing Cover Art: Office Sonos:http://www.siriusxm.com/albumart/Live/1330/rollingstone_56904D92_m.jpg
Sonos Debug Updating Device: Office Sonos, State: ZP_ART, Value: http://www.siriusxm.com/albumart/Live/1 ... 4D92_m.jpg
Sonos Debug Updating Device: Office Sonos, State: ZP_INFO, Value: BR P|TYPE=SNG|TITLE Shattered|ARTIST Rolling Stones
Thanks Jay
Wed Feb 17, 2016 8:16 am
nlagaros offline
Do other sources (not SiriusXM) have the same issue?
Thanks Jay
Wed Feb 17, 2016 12:15 pm
jayh391 offline
Just Sirus XM
Any ideas?
Jay
Thanks Jay
Wed Feb 17, 2016 1:40 pm
nlagaros offline
Just to eliminate another issue I might have, can you restart the plugin and see if it populates those states. Thanks.
jayh391 wrote:
Just Sirus XM
Any ideas?
Jay
Thanks Jay
Wed Feb 17, 2016 3:37 pm
jayh391 offline
I have restarted the plugin, even restarted the computer. Same problem.
Jay
quote="nlagaros"]Just to eliminate another issue I might have, can you restart the plugin and see if it populates those states. Thanks.
jayh391 wrote:
Just Sirus XM
Any ideas?
Jay
Thanks Jay
[/quote]
Wed Feb 17, 2016 4:29 pm
nlagaros offline
That is helpful. I will try to replicate on my end. Hopefully a simple fix.
Thu Feb 18, 2016 9:00 pm
pmgendon offline
Great work with the plugin, I'll add my error to the list:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 286, in runConcurrentThread
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/os.py", line 150, in makedirs
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/os.py", line 157, in makedirs
<type 'exceptions.OSError'>: [Errno 13] Permission denied: '/Library/Application Support/Perceptive Automation/images'
I don't give admin rights to my normal user and I think this might be the cause.
hope you can help
pm
Fri Feb 19, 2016 10:06 pm
pmgendon offline
I solved my problem by changing the permissions to the perceptive automation folder. Now it works.
pm
Sat Feb 20, 2016 6:31 am
nlagaros offline
I see that Sirius has changed the way they send updates on what is playing. You see the ZP_INFO field has track & artist. I can probably parse that, repopulate ZP_INFO and a couple of other relevant states. Will be in the next version (v0.9.3).
jayh391 wrote:
Just Sirus XM
Any ideas?
Jay
Thanks Jay
