Group Announcement Error
Sun Dec 06, 2015 9:58 pm
zini offline
Nick,
Just updated my Sonos plugin as I started using Sonos again and wanted to try to get your Group Announcement feature working. However, I'm not having much luck. I'm getting the following when I try (Google text to speech):
Dec 6, 2015, 10:55:59 PM
  Schedule                        new schedule 2
  Sonos                           Announcement: Check it out, I am talking!, Volume: 100
  Sonos                           remove zone from group: Family Room ZP
  Sonos                           Announcement Length: 1.836
  Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 175, in actionZP_announcementMP3
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1299, in actionAnnouncement
<type 'exceptions.TypeError'>: cannot concatenate 'str' and 'NoneType' objects
Any thoughts? Thanks.
Mark
Mon Dec 07, 2015 2:30 pm
nlagaros offline
Re: Group Announcement Error
Can you restart the plugin and post all the output. I suspect one of the configuration parameters has not been set.
Mon Dec 07, 2015 2:36 pm
zini offline
Sure thing! Here you go:
Dec 7, 2015, 3:34:56 PM
  Reloading plugin "Sonos 0.8.23"
  Stopping plugin "Sonos 0.8.23" (pid 84091)
  Sonos Error                     Error in plugin execution stopConcurrentThread:
  File "plugin.py", line 63, in stopConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 338, in stopConcurrentThread
  File "./lib/SonosEventLib.py", line 93, in ZMQ_Kill
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'close'
  Sonos Error                     Error in plugin execution _preShutdown:
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 135, in _preShutdown
  Stopped plugin "Sonos 0.8.23"
  Starting plugin "Sonos 0.8.23" (pid 87112)
  Started plugin "Sonos 0.8.23"
  Sonos                           Your plugin version, v0.8.23, is current.
  Sonos                           Saved Plugin Configuration
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 245, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1613, in getSonosFavorites
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1519, in restoreString
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'replace'
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mark
Mon Dec 07, 2015 2:45 pm
nlagaros offline
Is there any more than that?
Mon Dec 07, 2015 2:46 pm
zini offline
When I restarted the plugin, that's all that shows in the Event Log. Should there be more?
Thanks again for your help with this.
Mark
Mon Dec 07, 2015 2:49 pm
nlagaros offline
Yes there should be a heck of a lot more. can you turn debug mode on and try restarting it again (just the first debug checkbox).
Mon Dec 07, 2015 2:52 pm
zini offline
No problem. Here you go:
Dec 7, 2015, 3:50:44 PM
  Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Reference ZP IP:        http://192.168.1.14
  Sonos Debug                         Publish/Subscribe Port: 9999
  Sonos Debug                         Interface:              False
  Sonos Debug                         Network Interface:      en0
  Sonos Debug                         HTTP Streaming IP:      auto
  Sonos Debug                         HTTP Streaming Port:    8888
  Sonos Debug                         Sound File Path:
  Sonos Debug                         Pandora:                False
  Sonos Debug                         Pandora User ID:
  Sonos Debug                         Pandora Email Address:
  Sonos Debug                         Pandora Password:       *****
  Sonos Debug                         SiriusXM:               False
  Sonos Debug                         IVONA:                  True
  Sonos Debug                     Loading Sonos Favorites...
  Sonos Debug                     zoneIP: http://192.168.1.14, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
  Sonos Debug                     Method: runConcurrentThread
  Sonos Debug                     Running Concurrent Thread
  Stopping plugin "Sonos 0.8.23" (pid 87112)
  Sonos Debug                     Method: stopConcurrentThread
  Sonos Debug                     Stopping Concurrent Thread
  Sonos Debug                     Method: shutdown
  Starting plugin "Sonos 0.8.23" (pid 87168)
Mark
Mon Dec 07, 2015 2:59 pm
nlagaros offline
Do you have any Sonos Favorites configured in the Sonos application?
Mon Dec 07, 2015 3:06 pm
zini offline
Two favorites - one Pandora station and one TuneIn radio station.
Mark
Mon Dec 07, 2015 3:16 pm
nlagaros offline
In the plugin configuration, take the http:// out of the entry for reference ZonePlayer.
Sat Dec 12, 2015 12:37 pm
zini offline
Great! Thank you. That seemed to work. I am now able to get the announcements working.
I am seeing a new error though, during some actions, such as trying to mute the Sonos player, or to begin playing a favorite channel.
Here it is:
Action Group                    Sonos Favorite: Air Lounge
  Sonos                           Favorite Play: x-sonosapi-stream:s139956?sid=254&flags=32
  File "plugin.py", line 148, in actionZP_SonosFavorites
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1145, in actionDirect
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1012, in actionDirect
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'get'
Any thoughts as to what would be causing this? I wasn't getting this before. Thanks for all your help - this plugin is great.
Mark
Sat Jan 02, 2016 8:06 am
nlagaros offline
Two things:
1. Please try the latest version of the plugin I just posted (v0.8.32)
2. Turn on debug and post the logs when the plugin starts.
Here it is:
Fri Jan 08, 2016 10:23 am
jens offline
Whats this for error??
Trigger Dörr öppen bottenvåning
Sonos Announcement: FILE [door botten entre.mp3], Volume: 40
Sonos remove zone from group: Sonos Kontor
Sonos remove zone from group: Sonos Matrum
Sonos remove zone from group: Sonos Duchrum
Sonos remove zone from group: Sonos Sovrum Stort
fingscan props check old192.168.0.192 new192.168.0.046-double
Sonos Announcement Length: 1.6718125
Sonos ZonePlayer: Sonos Kontor, Play
Sonos add zone to group: Sonos Kontor->Sonos Matrum
Sonos add zone to group: Sonos Badrum->Sonos Matrum
Sonos add zone to group: Sonos Sovrum Stort->Sonos Matrum
Sonos Error UPNP Error: 500
Sun Jan 10, 2016 2:09 am
HowmaNoid offline
I'm also having issues getting the announcements working.
I'm running Indigo version 6.1.4 on OS X 10.11.2 the plugin version is 8.32
Here's the error I get when trying to generate an announcement action.
Sonos Announcement: "Testing Sonos Announce", Volume: 90, Line-In:
File "plugin.py", line 193, in actionZP_announcement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1296, in actionAnnouncement
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
Here's the startup output with debit turned on.
Starting plugin "Sonos 0.8.32" (pid 79625)
Started plugin "Sonos 0.8.32"
Sonos Error versionCheck: Unable to reach the version server.
Sonos Debug Reference ZP IP: 192.168.1.159
Sonos Debug Network Interface: en1
Sonos Debug HTTP Streaming IP: 192.169.1.123
Sonos Debug Sound File Path: /Users/admin/Documents
Sonos Debug SiriusXM: True
Sonos Debug IVONA: False
Sonos Debug zoneIP: 192.168.1.159, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Debug Loading Playlists...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:2" parentID="SQ:" restricted="true"><dc:title>Guardians Galaxy 0</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#2</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a776637649.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a277501238.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a738507211.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a298709875.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI></container><container id="SQ:1" parentID="SQ:" restricted="true"><dc:title>Guardians Galaxy I</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#1</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a690456025.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a141117.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a197055097.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3asong%253a41562342.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI></container><container id="SQ:0" parentID="SQ:" restricted="true"><dc:title>Party</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#0</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3alibrarytrack%253ai.1593602.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3alibrarytrack%253ai.1660422.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3alibrarytrack%253ai.1712154.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3alibrarytrack%253ai.1705486.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2</upnp:albumArtURI></container></DIDL-Lite></Result><NumberReturned>3</NumberReturned><TotalMatches>3</TotalMatches><UpdateID>3</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Playlist: SQ:2, Guardians Galaxy 0, file:///jffs/settings/savedqueues.rsq#2
Sonos Playlist: SQ:1, Guardians Galaxy I, file:///jffs/settings/savedqueues.rsq#1
Sonos Playlist: SQ:0, Party, file:///jffs/settings/savedqueues.rsq#0
Sonos Debug Loading RadioTime Favorite Stations...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"></DIDL-Lite></Result><NumberReturned>0</NumberReturned><TotalMatches>0</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos SiriusXM: 2|2|siriushits1|siriushits1|SiriusXM Hits 1
Sonos SiriusXM: 3|3|9389|9389|Venus
Sonos SiriusXM: 4|4|9406|9406|Pitbull's Globalization
Sonos SiriusXM: 5|5|siriusgold|siriusgold|50s on 5
Sonos SiriusXM: 6|6|60svibrations|60svibrations|60s on 6
Sonos SiriusXM: 7|7|totally70s|totally70s|70s on 7
Sonos SiriusXM: 8|8|big80s|big80s|80s on 8
Sonos SiriusXM: 9|9|8206|8206|90s on 9
Sonos SiriusXM: 10|10|8208|8208|Pop2K
Sonos SiriusXM: 13|13|9361|9361|Velvet
Sonos SiriusXM: 14|14|coffeehouse|coffeehouse|The Coffee House
Sonos SiriusXM: 15|15|thepulse|thepulse|The Pulse
Sonos SiriusXM: 16|16|starlite|starlite|The Blend
Sonos SiriusXM: 17|17|siriuslove|siriuslove|SiriusXM Love
Sonos SiriusXM: 18|18|9138|9138|SXM Limited Edition
Sonos SiriusXM: 300|300|9412|9412|Poptropolis
Sonos SiriusXM: 301|301|9415|9415|Road Trip Radio
Sonos SiriusXM: 302|302|9416|9416|The Covers Channel
Sonos SiriusXM: 158|158|rumbon|rumbon|Caliente
Sonos SiriusXM: 700|700|8372|8372|Neil Diamond Radio
Sonos SiriusXM: 703|703|9362|9362|Elevations
Sonos SiriusXM: 19|19|elvisradio|elvisradio|Elvis Radio
Sonos SiriusXM: 20|20|estreetradio|estreetradio|E Street Radio
Sonos SiriusXM: 21|21|undergroundgarage|undergroundgarage|Underground Garage
Sonos SiriusXM: 22|22|8370|8370|Pearl Jam Radio
Sonos SiriusXM: 23|23|gratefuldead|gratefuldead|Grateful Dead
Sonos SiriusXM: 24|24|radiomargaritaville|radiomargaritaville|Radio Margaritaville
Sonos SiriusXM: 25|25|classicrewind|classicrewind|Classic Rewind
Sonos SiriusXM: 26|26|classicvinyl|classicvinyl|Classic Vinyl
Sonos SiriusXM: 27|27|thevault|thevault|Deep Tracks
Sonos SiriusXM: 28|28|thespectrum|thespectrum|The Spectrum
Sonos SiriusXM: 29|29|jamon|jamon|Jam_ON
Sonos SiriusXM: 30|30|8207|8207|The Loft
Sonos SiriusXM: 31|31|9407|9407|Tom Petty Radio
Sonos SiriusXM: 32|32|thebridge|thebridge|The Bridge
Sonos SiriusXM: 33|33|firstwave|firstwave|1st Wave
Sonos SiriusXM: 34|34|90salternative|90salternative|Lithium
Sonos SiriusXM: 35|35|leftofcenter|leftofcenter|SiriusXMU
Sonos SiriusXM: 36|36|altnation|altnation|Alt Nation
Sonos SiriusXM: 37|37|octane|octane|Octane
Sonos SiriusXM: 38|38|buzzsaw|buzzsaw|Ozzy's Boneyard
Sonos SiriusXM: 39|39|hairnation|hairnation|Hair Nation
Sonos SiriusXM: 40|40|hardattack|hardattack|Liquid Metal
Sonos SiriusXM: 41|41|faction|faction|Faction
Sonos SiriusXM: 713|713|9363|9363|Jason Ellis
Sonos SiriusXM: 42|42|reggaerhythms|reggaerhythms|The Joint
Sonos SiriusXM: 310|310|9174|9174|SXM Rock Hall Radio
Sonos SiriusXM: 312|312|9352|9352|Petty's Buried Treasure
Sonos SiriusXM: 313|313|9175|9175|RockBar
Sonos SiriusXM: 314|314|9413|9413|SiriusXM Turbo
Sonos SiriusXM: 316|316|9176|9176|SiriusXM Comes Alive!
Sonos SiriusXM: 715|715|9139|9139|SXM Limited Edition 2
Sonos SiriusXM: 716|716|9353|9353|SXM Limited Edition 3
Sonos SiriusXM: 43|43|8124|8124|Backspin
Sonos SiriusXM: 44|44|hiphopnation|hiphopnation|Hip-Hop Nation
Sonos SiriusXM: 45|45|shade45|shade45|Shade 45
Sonos SiriusXM: 720|720|9397|9397|Sway's Universe
Sonos SiriusXM: 721|721|9398|9398|SXM Limited Edition 4
Sonos SiriusXM: 46|46|hotjamz|hotjamz|The Heat
Sonos SiriusXM: 47|47|9339|9339|SiriusXM FLY
Sonos SiriusXM: 48|48|heartandsoul|heartandsoul|Heart & Soul
Sonos SiriusXM: 49|49|soultown|soultown|Soul Town
Sonos SiriusXM: 50|50|8228|8228|The Groove
Sonos SiriusXM: 330|330|9364|9364|SiriusXM Silk
Sonos SiriusXM: 726|726|9399|9399|SXM Limited Edition 5
Sonos SiriusXM: 51|51|thebeat|thebeat|BPM
Sonos SiriusXM: 52|52|area33|area33|Electric Area
Sonos SiriusXM: 53|53|chill|chill|SiriusXM Chill
Sonos SiriusXM: 54|54|9145|9145|Studio 54 Radio
Sonos SiriusXM: 55|55|9365|9365|Utopia
Sonos SiriusXM: 340|340|9219|9219|Tiësto's Club Life Radio
Sonos SiriusXM: 730|730|9400|9400|SXM Limited Edition 6
Sonos SiriusXM: 56|56|newcountry|newcountry|The Highway
Sonos SiriusXM: 57|57|9340|9340|Y2Kountry
Sonos SiriusXM: 58|58|primecountry|primecountry|Prime Country
Sonos SiriusXM: 59|59|theroadhouse|theroadhouse|Willie's Roadhouse
Sonos SiriusXM: 60|60|outlawcountry|outlawcountry|Outlaw Country
Sonos SiriusXM: 61|61|bluegrass|bluegrass|Bluegrass Junction
Sonos SiriusXM: 350|350|9178|9178|Red White & Booze
Sonos SiriusXM: 741|741|8227|8227|The Village
Sonos SiriusXM: 742|742|9401|9401|SXM Limited Edition 7
Sonos SiriusXM: 63|63|spirit|spirit|The Message
Sonos SiriusXM: 64|64|praise|praise|Kirk Franklin's Praise
Sonos SiriusXM: 65|65|8229|8229|enLighten
Sonos SiriusXM: 745|745|9402|9402|SXM Limited Edition 8
Sonos SiriusXM: 66|66|jazzcafe|jazzcafe|Watercolors
Sonos SiriusXM: 67|67|purejazz|purejazz|Real Jazz
Sonos SiriusXM: 68|68|spa73|spa73|Spa
Sonos SiriusXM: 69|69|8215|8215|Escape
Sonos SiriusXM: 70|70|siriusblues|siriusblues|BB King's Bluesville
Sonos SiriusXM: 71|71|siriuslysinatra|siriuslysinatra|Siriusly Sinatra
Sonos SiriusXM: 72|72|broadwaysbest|broadwaysbest|On Broadway
Sonos SiriusXM: 73|73|8205|8205|40s Junction
Sonos SiriusXM: 750|750|8211|8211|Cinemagic
Sonos SiriusXM: 751|751|9179|9179|Krishna Das Yoga Radio
Sonos SiriusXM: 752|752|9403|9403|SXM Limited Edition 9
Sonos SiriusXM: 74|74|metropolitanopera|metropolitanopera|Met Opera Radio
Sonos SiriusXM: 76|76|symphonyhall|symphonyhall|Symphony Hall
Sonos SiriusXM: 755|755|siriuspops|siriuspops|SiriusXM Pops
Sonos SiriusXM: 756|756|9404|9404|SXM Limited Edition 10
Sonos SiriusXM: 761|761|9186|9186|Águila
Sonos SiriusXM: 762|762|9188|9188|Caricia
Sonos SiriusXM: 763|763|8225|8225|Viva
Sonos SiriusXM: 764|764|9187|9187|Latidos
Sonos SiriusXM: 765|765|9185|9185|Flow Nación
Sonos SiriusXM: 766|766|9189|9189|Luna
Sonos SiriusXM: 767|767|9190|9190|Rumbón
Sonos SiriusXM: 768|768|9191|9191|La Kueva
Sonos SiriusXM: 770|770|9372|9372|70s/80s Pop
Sonos SiriusXM: 771|771|9373|9373|80s/90s Pop
Sonos SiriusXM: 772|772|9374|9374|90s/2K Pop
Sonos SiriusXM: 773|773|9375|9375|Classic Rock Party
Sonos SiriusXM: 774|774|9376|9376|Rockin' Frat Party
Sonos SiriusXM: 775|775|9377|9377|Hip-Hop Party
Sonos SiriusXM: 776|776|9378|9378|Oldies Party
Sonos SiriusXM: 777|777|9379|9379|Pop Party Mix
Sonos SiriusXM: 778|778|9380|9380|Punk Party
Sonos SiriusXM: 779|779|9381|9381|New Wave Dance Party
Sonos SiriusXM: 780|780|9382|9382|The Girls Room
Sonos SiriusXM: 781|781|9343|9343|Holly
Sonos SiriusXM: 782|782|9342|9342|Holiday Traditions
Sonos SiriusXM: 783|783|9344|9344|Holiday Pops
Sonos SiriusXM: 784|784|9345|9345|Country Christmas
Sonos SiriusXM: 785|785|9348|9348|Navidad
Sonos SiriusXM: 786|786|9346|9346|Holiday Soul
Sonos SiriusXM: 787|787|9349|9349|Radio Hanukkah
Sonos SiriusXM: 80|80|espnradio|espnradio|ESPN Radio
Sonos SiriusXM: 81|81|8254|8254|ESPN Xtra
Sonos SiriusXM: 82|82|8213|8213|Mad Dog Sports Radio
Sonos SiriusXM: 83|83|9395|9395|Bleacher Report Radio
Sonos SiriusXM: 84|84|siriussportsaction|siriussportsaction|College Sports Nation
Sonos SiriusXM: 85|85|9341|9341|SiriusXM FC
Sonos SiriusXM: 207|86|9385|9385|SiriusXM NBA Radio
Sonos SiriusXM: 210|87|8368|8368|SXM Fantasy Sports Radio
Sonos SiriusXM: 88|88|siriusnflradio|siriusnflradio|SiriusXM NFL Radio
Sonos SiriusXM: 209|89|8333|8333|MLB Network Radio
Sonos SiriusXM: 90|90|siriusnascarradio|siriusnascarradio|SiriusXM NASCAR Radio
Sonos SiriusXM: 91|91|8185|8185|SXM NHL Network Radio
Sonos SiriusXM: 208|92|8186|8186|SiriusXM PGA TOUR Radio
Sonos SiriusXM: 93|93|8230|8230|SiriusXM Rush
Sonos SiriusXM: 157|157|espndeportes|espndeportes|ESPN Deportes
Sonos SiriusXM: 370|370|9180|9180|SportsCenter
Sonos SiriusXM: 800|800|9146|9146|NFL-ARI
Sonos SiriusXM: 801|801|9147|9147|NFL-ATL
Sonos SiriusXM: 802|802|9148|9148|NFL-BAL
Sonos SiriusXM: 803|803|9149|9149|NFL-BUF
Sonos SiriusXM: 804|804|9150|9150|NFL-CAR
Sonos SiriusXM: 805|805|9151|9151|NFL-CHI
Sonos SiriusXM: 806|806|9152|9152|NFL-CIN
Sonos SiriusXM: 807|807|9153|9153|NFL-CLE
Sonos SiriusXM: 808|808|9154|9154|NFL-DAL
Sonos SiriusXM: 809|809|9155|9155|NFL-DEN
Sonos SiriusXM: 810|810|9156|9156|NFL-DET
Sonos SiriusXM: 811|811|9157|9157|NFL-GB
Sonos SiriusXM: 812|812|9158|9158|NFL-HOU
Sonos SiriusXM: 813|813|9159|9159|NFL-IND
Sonos SiriusXM: 814|814|9160|9160|NFL-JAX
Sonos SiriusXM: 815|815|9161|9161|NFL-KC
Sonos SiriusXM: 816|816|9162|9162|NFL-MIA
Sonos SiriusXM: 817|817|9163|9163|NFL-MIN
Sonos SiriusXM: 818|818|9164|9164|NFL-NE
Sonos SiriusXM: 819|819|9165|9165|NFL-NO
Sonos SiriusXM: 820|820|9166|9166|NFL-NYG
Sonos SiriusXM: 821|821|9167|9167|NFL-NYJ
Sonos SiriusXM: 822|822|9168|9168|NFL-OAK
Sonos SiriusXM: 823|823|9169|9169|NFL-PHI
Sonos SiriusXM: 824|824|9170|9170|NFL-PIT
Sonos SiriusXM: 825|825|9171|9171|NFL-SD
Sonos SiriusXM: 826|826|9201|9201|NFL-SEA
Sonos SiriusXM: 827|827|9202|9202|NFL-SF
Sonos SiriusXM: 828|828|9203|9203|NFL-STL
Sonos SiriusXM: 829|829|9204|9204|NFL-TB
Sonos SiriusXM: 830|830|9205|9205|NFL-TEN
Sonos SiriusXM: 831|831|9206|9206|NFL-WAS
Sonos SiriusXM: 840|840|9231|9231|Arizona Diamondbacks
Sonos SiriusXM: 841|841|9232|9232|Atlanta Braves
Sonos SiriusXM: 842|842|9233|9233|Baltimore Orioles
Sonos SiriusXM: 843|843|9234|9234|Boston Red Sox
Sonos SiriusXM: 844|844|9235|9235|Chicago Cubs
Sonos SiriusXM: 845|845|9236|9236|Chicago White Sox
Sonos SiriusXM: 846|846|9237|9237|Cincinnati Reds
Sonos SiriusXM: 847|847|9238|9238|Cleveland Indians
Sonos SiriusXM: 848|848|9239|9239|Colorado Rockies
Sonos SiriusXM: 849|849|9240|9240|Detroit Tigers
Sonos SiriusXM: 850|850|9241|9241|Houston Astros
Sonos SiriusXM: 851|851|9242|9242|Kansas City Royals
Sonos SiriusXM: 852|852|9243|9243|Los Angeles Angels
Sonos SiriusXM: 853|853|9244|9244|Los Angeles Dodgers
Sonos SiriusXM: 854|854|9245|9245|Miami Marlins
Sonos SiriusXM: 855|855|9246|9246|Milwaukee Brewers
Sonos SiriusXM: 856|856|9247|9247|Minnesota Twins
Sonos SiriusXM: 857|857|9248|9248|New York Mets
Sonos SiriusXM: 858|858|9249|9249|New York Yankees
Sonos SiriusXM: 859|859|9250|9250|Oakland Athletics
Sonos SiriusXM: 860|860|9251|9251|Philadelphia Phillies
Sonos SiriusXM: 861|861|9252|9252|Pittsburgh Pirates
Sonos SiriusXM: 862|862|9253|9253|San Diego Padres
Sonos SiriusXM: 863|863|9254|9254|San Francisco Giants
Sonos SiriusXM: 864|864|9255|9255|Seattle Mariners
Sonos SiriusXM: 865|865|9256|9256|St. Louis Cardinals
Sonos SiriusXM: 866|866|9257|9257|Tampa Bay Rays
Sonos SiriusXM: 867|867|9258|9258|Texas Rangers
Sonos SiriusXM: 868|868|9259|9259|Toronto Blue Jays
Sonos SiriusXM: 869|869|9260|9260|Washington Nationals
Sonos SiriusXM: 880|880|9266|9266|Atlanta Hawks
Sonos SiriusXM: 881|881|9268|9268|Boston Celtics
Sonos SiriusXM: 882|882|9267|9267|Brooklyn Nets
Sonos SiriusXM: 883|883|9269|9269|Charlotte Hornets
Sonos SiriusXM: 884|884|9270|9270|Chicago Bulls
Sonos SiriusXM: 885|885|9271|9271|Cleveland Cavaliers
Sonos SiriusXM: 886|886|9272|9272|Dallas Mavericks
Sonos SiriusXM: 887|887|9273|9273|Denver Nuggets
Sonos SiriusXM: 888|888|9274|9274|Detroit Pistons
Sonos SiriusXM: 889|889|9275|9275|Golden State Warriors
Sonos SiriusXM: 890|890|9276|9276|Houston Rockets
Sonos SiriusXM: 891|891|9277|9277|Indiana Pacers
Sonos SiriusXM: 892|892|9278|9278|Los Angeles Clippers
Sonos SiriusXM: 893|893|9279|9279|Los Angeles Lakers
Sonos SiriusXM: 894|894|9280|9280|Memphis Grizzlies
Sonos SiriusXM: 895|895|9281|9281|Miami Heat
Sonos SiriusXM: 896|896|9282|9282|Milwaukee Bucks
Sonos SiriusXM: 897|897|9283|9283|Minnesota Timberwolves
Sonos SiriusXM: 898|898|9284|9284|New Orleans Pelicans
Sonos SiriusXM: 899|899|9285|9285|New York Knicks
Sonos SiriusXM: 900|900|9286|9286|Oklahoma City Thunder
Sonos SiriusXM: 901|901|9287|9287|Orlando Magic
Sonos SiriusXM: 902|902|9288|9288|Philadelphia 76ers
Sonos SiriusXM: 903|903|9289|9289|Phoenix Suns
Sonos SiriusXM: 904|904|9290|9290|Portland Trail Blazers
Sonos SiriusXM: 905|905|9292|9292|Sacramento Kings
Sonos SiriusXM: 906|906|9291|9291|San Antonio Spurs
Sonos SiriusXM: 907|907|9293|9293|Toronto Raptors
Sonos SiriusXM: 908|908|9294|9294|Utah Jazz
Sonos SiriusXM: 909|909|9295|9295|Washington Wizards
Sonos SiriusXM: 920|920|9296|9296|NHL-ANA
Sonos SiriusXM: 921|921|9394|9394|NHL-ARI
Sonos SiriusXM: 922|922|9297|9297|NHL-BOS
Sonos SiriusXM: 923|923|9298|9298|NHL-BUF
Sonos SiriusXM: 924|924|9299|9299|NHL-CAR
Sonos SiriusXM: 925|925|9300|9300|NHL-CBJ
Sonos SiriusXM: 926|926|9301|9301|NHL-CGY
Sonos SiriusXM: 927|927|9302|9302|NHL-CHI
Sonos SiriusXM: 928|928|9303|9303|NHL-COL
Sonos SiriusXM: 929|929|9304|9304|NHL-DAL
Sonos SiriusXM: 930|930|9305|9305|NHL-DET
Sonos SiriusXM: 931|931|9306|9306|NHL-EDM
Sonos SiriusXM: 932|932|9307|9307|NHL-FLA
Sonos SiriusXM: 933|933|9308|9308|NHL-LA
Sonos SiriusXM: 934|934|9309|9309|NHL-MIN
Sonos SiriusXM: 935|935|9310|9310|NHL-MON
Sonos SiriusXM: 936|936|9311|9311|NHL-NJ
Sonos SiriusXM: 937|937|9312|9312|NHL-NSH
Sonos SiriusXM: 938|938|9313|9313|NHL-NYI
Sonos SiriusXM: 939|939|9314|9314|NHL-NYR
Sonos SiriusXM: 940|940|9315|9315|NHL-OTT
Sonos SiriusXM: 941|941|9316|9316|NHL-PHI
Sonos SiriusXM: 942|942|9318|9318|NHL-PIT
Sonos SiriusXM: 943|943|9319|9319|NHL-SJ
Sonos SiriusXM: 944|944|9320|9320|NHL-STL
Sonos SiriusXM: 945|945|9321|9321|NHL-TB
Sonos SiriusXM: 946|946|9322|9322|NHL-TOR
Sonos SiriusXM: 947|947|9323|9323|NHL-VAN
Sonos SiriusXM: 948|948|9324|9324|NHL-WAS
Sonos SiriusXM: 949|949|9325|9325|NHL-WPG
Sonos SiriusXM: 960|960|9220|9220|Sports 960
Sonos SiriusXM: 961|961|9221|9221|Sports 961
Sonos SiriusXM: 962|962|9222|9222|Sports 962
Sonos SiriusXM: 963|963|9223|9223|Sports 963
Sonos SiriusXM: 964|964|9224|9224|Sports 964
Sonos SiriusXM: 965|965|9225|9225|Sports 965
Sonos SiriusXM: 966|966|9226|9226|Sports 966
Sonos SiriusXM: 967|967|9227|9227|Sports 967
Sonos SiriusXM: 968|968|9228|9228|Sports 968
Sonos SiriusXM: 969|969|9229|9229|Sports 969
Sonos SiriusXM: 970|970|9207|9207|Deportes en Vivo 970
Sonos SiriusXM: 971|971|9208|9208|Deportes en Vivo 971
Sonos SiriusXM: 972|972|9209|9209|Deportes en Vivo 972
Sonos SiriusXM: 973|973|9210|9210|Deportes en Vivo 973
Sonos SiriusXM: 974|974|9211|9211|Deportes en Vivo 974
Sonos SiriusXM: 975|975|9212|9212|Deportes en Vivo 975
Sonos SiriusXM: 976|976|9213|9213|Deportes en Vivo 976
Sonos SiriusXM: 977|977|9214|9214|Deportes en Vivo 977
Sonos SiriusXM: 978|978|9215|9215|Deportes en Vivo 978
Sonos SiriusXM: 979|979|9216|9216|Deportes en Vivo 979
Sonos SiriusXM: 980|980|9261|9261|Deportes en Vivo 980
Sonos SiriusXM: 981|981|9262|9262|Deportes en Vivo 981
Sonos SiriusXM: 982|982|9326|9326|Deportes en Vivo 982
Sonos SiriusXM: 983|983|9327|9327|Deportes en Vivo 983
Sonos SiriusXM: 984|984|9328|9328|Deportes en Vivo 984
Sonos SiriusXM: 985|985|9329|9329|Deportes en Vivo 985
Sonos SiriusXM: 986|986|9330|9330|Deportes en Vivo 986
Sonos SiriusXM: 987|987|9331|9331|Deportes en Vivo 987
Sonos SiriusXM: 988|988|9332|9332|Deportes en Vivo 988
Sonos SiriusXM: 989|989|9333|9333|Deportes en Vivo 989
Sonos SiriusXM: 990|990|9334|9334|Deportes en Vivo 990
Sonos SiriusXM: 991|991|9335|9335|Deportes en Vivo 991
Sonos SiriusXM: 992|992|9336|9336|Deportes en Vivo 992
Sonos SiriusXM: 993|993|9337|9337|Deportes en Vivo 993
Sonos SiriusXM: 994|994|9338|9338|Deportes en Vivo 994
Sonos SiriusXM: 100|100|howardstern100|howardstern100|Howard 100
Sonos SiriusXM: 101|101|howardstern101|howardstern101|Howard 101
Sonos SiriusXM: 112|112|cnbc|cnbc|CNBC
Sonos SiriusXM: 113|113|9369|9369|FOX Business
Sonos SiriusXM: 114|114|foxnewschannel|foxnewschannel|FOX News Channel
Sonos SiriusXM: 115|115|9410|9410|FOX News Headlines 24/7
Sonos SiriusXM: 116|116|cnn|cnn|CNN
Sonos SiriusXM: 117|117|cnnheadlinenews|cnnheadlinenews|HLN
Sonos SiriusXM: 118|118|8367|8367|MSNBC
Sonos SiriusXM: 119|119|bloombergradio|bloombergradio|Bloomberg Radio
Sonos SiriusXM: 120|120|bbcworld|bbcworld|BBC World Service
Sonos SiriusXM: 121|121|8183|8183|SiriusXM Insight
Sonos SiriusXM: 122|122|nprnow|nprnow|NPR Now
Sonos SiriusXM: 123|123|8239|8239|PRX Public Radio
Sonos SiriusXM: 147|147|9367|9367|RURAL Radio
Sonos SiriusXM: 155|155|cnnespanol|cnnespanol|CNN en Español
Sonos SiriusXM: 169|169|cbcradioone|cbcradioone|CBC Radio One
Sonos SiriusXM: 455|455|8237|8237|C-SPAN Radio
Sonos SiriusXM: 124|124|indietalk|indietalk|POTUS Politics
Sonos SiriusXM: 125|125|siriuspatriot|siriuspatriot|SiriusXM Patriot
Sonos SiriusXM: 126|126|8238|8238|SiriusXM Urban View
Sonos SiriusXM: 127|127|siriusleft|siriusleft|SiriusXM Progress
Sonos SiriusXM: 450|450|9370|9370|FOX News Talk
Sonos SiriusXM: 796|796|9355|9355|TheBlaze Radio Network
Sonos SiriusXM: 797|797|8235|8235|SiriusXM Patriot Plus
Sonos SiriusXM: 798|798|9137|9137|SiriusXM Progress Plus
Sonos SiriusXM: 77|77|9366|9366|KIDZ BOP Radio
Sonos SiriusXM: 78|78|8216|8216|Kids Place Live
Sonos SiriusXM: 79|79|radiodisney|radiodisney|Radio Disney
Sonos SiriusXM: 94|94|9408|9408|SiriusXM Comedy Greats
Sonos SiriusXM: 95|95|9356|9356|Comedy Central Radio
Sonos SiriusXM: 96|96|thefoxxhole|thefoxxhole|The Foxxhole
Sonos SiriusXM: 97|97|bluecollarcomedy|bluecollarcomedy|Comedy Roundup
Sonos SiriusXM: 98|98|laughbreak|laughbreak|Laugh USA
Sonos SiriusXM: 99|99|rawdog|rawdog|Raw Dog Comedy Hits
Sonos SiriusXM: 168|168|8259|8259|Canada Laughs
Sonos SiriusXM: 400|400|9181|9181|Carlin's Corner
Sonos SiriusXM: 102|102|9409|9409|Radio Andy
Sonos SiriusXM: 206|103|8184|8184|Opie Radio
Sonos SiriusXM: 105|105|9351|9351|EW Radio
Sonos SiriusXM: 106|106|siriusoutq|siriusoutq|OutQ Gay Radio
Sonos SiriusXM: 108|108|9390|9390|Today Show Radio
Sonos SiriusXM: 109|109|siriusstars|siriusstars|SiriusXM Stars
Sonos SiriusXM: 110|110|doctorradio|doctorradio|Doctor Radio
Sonos SiriusXM: 111|111|9359|9359|Business Radio
Sonos SiriusXM: 128|128|9392|9392|Joel Osteen Radio
Sonos SiriusXM: 146|146|roaddogtrucking|roaddogtrucking|Road Dog Trucking
Sonos SiriusXM: 148|148|radioclassics|radioclassics|RadioClassics
Sonos SiriusXM: 790|790|9405|9405|SXM Limited Edition 11
Sonos SiriusXM: 791|791|8369|8369|Vivid Radio
Sonos SiriusXM: 794|794|0000|0000|SiriusXM Preview
Sonos SiriusXM: 129|129|thecatholicchannel|thecatholicchannel|The Catholic Channel
Sonos SiriusXM: 130|130|ewtnglobal|ewtnglobal|EWTN Radio
Sonos SiriusXM: 131|131|8307|8307|Family Talk
Sonos SiriusXM: 470|470|9414|9414|El Paisa
Sonos SiriusXM: 11|11|8241|8241|KIIS-Los Angeles
Sonos SiriusXM: 12|12|8242|8242|Z100/NY
Sonos SiriusXM: 141|141|9129|9129|HUR Voices
Sonos SiriusXM: 142|142|9130|9130|HBCU
Sonos SiriusXM: 143|143|9131|9131|BYUradio
Sonos SiriusXM: 144|144|9132|9132|Korea Today
Sonos SiriusXM: 152|152|9135|9135|En Vivo
Sonos SiriusXM: 153|153|9134|9134|Cristina Radio
Sonos SiriusXM: 154|154|9133|9133|American Latino Radio
Sonos SiriusXM: 162|162|cbcradio3|cbcradio3|CBC Radio 3
Sonos SiriusXM: 163|163|8245|8245|Ici Musique Chansons
Sonos SiriusXM: 165|165|9358|9358|Multicultural Radio
Sonos SiriusXM: 166|166|rockvelours|rockvelours|Ici FrancoCountry
Sonos SiriusXM: 167|167|9172|9172|Canada Talks
Sonos SiriusXM: 170|170|premiereplus|premiereplus|Ici Première
Sonos SiriusXM: 171|171|bandeapart|bandeapart|CBC Country
Sonos SiriusXM: 172|172|8248|8248|Canada 360 by AMI
Sonos SiriusXM: 173|173|8244|8244|The Verge
Sonos SiriusXM: 174|174|8246|8246|Influence Franco
Sonos SiriusXM: 758|758|icebergradio|icebergradio|Iceberg
Sonos SiriusXM: 759|759|energie2|energie2|Attitude Franco
Sonos Debug ZonePlayer: Office - Sonos Play 3, Enabled: True
Sonos Debug Resetting States for zone: 192.168.1.220
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ART, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_INFO, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_STATE, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_STATION, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_AIName, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NART, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Office - Sonos Play 3, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Office - Sonos Play 3, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Office - Sonos Play 3, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: GROUP_Name, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ZoneName, Value: Office
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_LocalUID, Value: RINCON_B8E937DE7F8001400
Sonos Debug zoneIP: 192.168.1.220, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZoneGroupName, Value: Office
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZoneGroupID, Value: RINCON_B8E937DE7F8001400:3
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E937DE7F8001400
Sonos Adding ZonePlayer: RINCON_B8E937DE7F8001400
Sonos Subscribing on port: 9999
Sonos SonosEvents INFO: Publishing on port: 9999
Sonos Event Ignition...
Sonos Debug SonosEvents: WARN coherence Jan 10 00:08:34 Coherence UPnP framework version 0.6.6.2 starting... (coherence/base.py:283)
Sonos Debug SonosEvents: WARN webserver Jan 10 00:08:34 WebServer on port 52948 ready (coherence/base.py:124)
Sonos Debug SonosEvents: ./lib/coherence/extern/louie.py:44: UserWarning: extern.louie will soon be deprecated in favor of coherence.dispatcher.
Sonos Debug SonosEvents: warnings.warn("extern.louie will soon be deprecated in favor of coherence.dispatcher.")
Sonos Debug SonosEvents: Unhandled Error
Sonos Debug SonosEvents: Traceback (most recent call last):
Sonos Debug SonosEvents: File "./lib/twisted/python/log.py", line 69, in callWithContext
Sonos Debug SonosEvents: return context.call({ILogContext: newCtx}, func, *args, **kw)
Sonos Debug SonosEvents: File "./lib/twisted/python/context.py", line 118, in callWithContext
Sonos Debug SonosEvents: return self.currentContext().callWithContext(ctx, func, *args, **kw)
Sonos Debug SonosEvents: File "./lib/twisted/python/context.py", line 81, in callWithContext
Sonos Debug SonosEvents: return func(*args,**kw)
Sonos Debug SonosEvents: File "./lib/twisted/internet/selectreactor.py", line 146, in _doReadOrWrite
Sonos Debug SonosEvents: why = getattr(selectable, method)()
Sonos Debug SonosEvents: --- <exception caught here> ---
Sonos Debug SonosEvents: File "./lib/twisted/internet/udp.py", line 130, in doRead
Sonos Debug SonosEvents: self.protocol.datagramReceived(data, addr)
Sonos Debug SonosEvents: File "./lib/coherence/upnp/core/msearch.py", line 44, in datagramReceived
Sonos Debug SonosEvents: headers['server'],
Sonos Debug SonosEvents: exceptions.KeyError: 'server'
Sonos Debug SonosEvents: Unhandled error in Deferred:
Sonos Debug SonosEvents: File "./lib/coherence/upnp/core/utils.py", line 507, in handleResponse
Sonos Debug SonosEvents: self.factory.page(response)
Sonos Debug SonosEvents: File "./lib/coherence/upnp/core/utils.py", line 561, in page
Sonos Debug SonosEvents: self.deferred.callback((page, self.response_headers))
Sonos Debug SonosEvents: File "./lib/twisted/internet/defer.py", line 361, in callback
Sonos Debug SonosEvents: self._startRunCallbacks(result)
Sonos Debug SonosEvents: File "./lib/twisted/internet/defer.py", line 455, in _startRunCallbacks
Sonos Debug SonosEvents: self._runCallbacks()
Sonos Debug SonosEvents: File "./lib/twisted/internet/defer.py", line 542, in _runCallbacks
Sonos Debug SonosEvents: current.result = callback(current.result, *args, **kw)
Sonos Debug SonosEvents: File "./lib/coherence/upnp/core/service.py", line 330, in gotPage
Sonos Debug SonosEvents: tree = utils.parse_xml(self.scpdXML, 'utf-8').getroot()
Sonos Debug SonosEvents: File "./lib/coherence/upnp/core/utils.py", line 55, in parse_xml
Sonos Debug SonosEvents: return et_parse_xml(data,encoding)
Sonos Debug SonosEvents: File "./lib/coherence/extern/et.py", line 143, in parse_xml
Sonos Debug SonosEvents: p.close()
Sonos Debug SonosEvents: File "./lib/elementtree/ElementTree.py", line 1251, in close
Sonos Debug SonosEvents: self._parser.Parse("", 1) # end of data
Sonos Debug SonosEvents: xml.parsers.expat.ExpatError: mismatched tag: line 65, column 4
Sonos Debug SonosEvents: File "./lib/coherence/upnp/core/device.py", line 516, in gotPage
Sonos Debug SonosEvents: tree = utils.parse_xml(data, 'utf-8').getroot()
Sonos Debug SonosEvents: xml.parsers.expat.ExpatError: not well-formed (invalid token): line 1, column 12
Sonos Serving HTTP Streamer on 192.169.1.123 [0.0.0.0], port 8888
Sonos Debug Event: RINCON_B8E937DE7F8001400|RCS^Volume|44^Mute|0^Bass|5^Treble|0^Loudness|1^OutputFixed|0^HeadphoneConnected|0^SpeakerSize|4^SubGain|0^SubCrossover|0^SubPolarity|0^SubEnabled|1^PresetNameList|FactoryDefaults
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_VOLUME, Value: 44
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_MUTE, Value: 0
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_VOLUME_FIXED, Value: 0
Sonos Debug Event: RINCON_B8E937DE7F8001400|AVT^AVTransportURI|x-rincon-queue:RINCON_B8E937DE7F8001400#0^SleepTimerGeneration|0^AlarmRunning|0^SnoozeRunning|0^TransportState|PAUSED_PLAYBACK^CurrentPlayMode|NORMAL^CurrentCrossfadeMode|0^CurrentTrackDuration|0:04:36^CurrentTrack|10^CurrentTrackURI|x-sonos-http:song%3a19652131.mp4?sid=204&flags=8224&sn=2^EnqueuedTransportURI|file:///jffs/settings/savedqueues.rsq#1^station|None^albumArtURI|/getaa?s=1&u=x-sonos-http%3asong%253a19652131.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2^title|Escape (The Pina Colada Song)^creator|Rupert Holmes^album|Partners In Crime^albumArtist|None^next_albumArtURI|/getaa?s=1&u=x-sonos-http%3asong%253a254340117.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2^next_title|O-O-H Child^next_creator|The Five Stairsteps^next_album|The First Family of Soul: The Best of the Five Stairsteps (Remastered)^next_albumArtist|None^info|None
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CurrentURI, Value: x-rincon-queue:RINCON_B8E937DE7F8001400#0
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_STATE, Value: PAUSED
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_DURATION, Value: 0:04:36
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CurrentTrack, Value: 10
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CurrentTrackURI, Value: x-sonos-http:song%3a19652131.mp4?sid=204&flags=8224&sn=2
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_STATION, Value: None
Sonos Debug Processing Cover Art: Office - Sonos Play 3:/getaa?s=1&u=x-sonos-http%3asong%253a19652131.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ART, Value: http://192.168.1.159:1400/getaa?s=1&u=x ... 4%26sn%3d2
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_TRACK, Value: Escape (The Pina Colada Song)
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_CREATOR, Value: Rupert Holmes
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ALBUM, Value: Partners In Crime
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_ARTIST, Value: None
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NART, Value: /getaa?s=1&u=x-sonos-http%3asong%253a254340117.mp4%3fsid%3d204%26flags%3d8224%26sn%3d2
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NTRACK, Value: O-O-H Child
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NCREATOR, Value: The Five Stairsteps
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NALBUM, Value: The First Family of Soul: The Best of the Five Stairsteps (Remastered)
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_NARTIST, Value: None
Sonos Debug Updating Device: Office - Sonos Play 3, State: ZP_INFO, Value: None
Sonos Debug Event: RINCON_B8E937DE7F8001400|AVT^TransportState|PAUSED_PLAYBACK
Sonos Debug Event: RINCON_B8E937DE7F8001400|GM^GroupCoordinatorIsLocal|true
Sonos Debug Updating Device: Office - Sonos Play 3, State: GROUP_Coordinator, Value: true
Sonos Debug Update all states to slave ZonePlayers...
Sonos Debug Event: RINCON_B8E937DE7F8001400|GM^LocalGroupUUID|RINCON_B8E937DE7F8001400:3
Sonos Debug Updating Device: Office - Sonos Play 3, State: GROUP_Name, Value: RINCON_B8E937DE7F8001400:3
Any help you can give to get this working would be very welcome!
H
Sun Jan 10, 2016 7:13 am
nlagaros offline
This was happening when the plugin was restoring the state of zones after the announcement and sent some illegal actions (seek, play). I just posted a new version (v0.8.33) that has a ton of error handling and a bit more smarts around this. Please give it a try.
