Error on plugin activation
Mon Aug 03, 2015 9:27 pm
rapamatic offline
I'm getting an error when I first load the songs plugin. I don't have any bridges setup as devices (I know this is a common issue)... any idea what could be going on here?
Here's debug log:
Started plugin "Sonos 0.8.13"
  Sonos                           Your plugin version, v0.8.13, is current.
  Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Reference ZP IP:        10.0.0.55
  Sonos Debug                         Publish/Subscribe Port: 9999
  Sonos Debug                         HTTP Streaming IP:      auto
  Sonos Debug                         HTTP Streaming Port:    8888
  Sonos Debug                         Sound File Path:
  Sonos Debug                         Pandora:                False
  Sonos Debug                         Pandora User ID:
  Sonos Debug                         Pandora Email Address:
  Sonos Debug                         Pandora Password:       *****
  Sonos Debug                         SiriusXM:               False
  Sonos                           Saved Plugin Configuration
  Sonos Debug                     Loading Sonos Favorites...
  Sonos Debug                     zoneIP: 10.0.0.55, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 198, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1455, in getSonosFavorites
  File "./lib/elementtree/ElementTree.py", line 960, in XML
  File "./lib/elementtree/ElementTree.py", line 1242, in feed
<class 'xml.parsers.expat.ExpatError'>: syntax error: line 1, column 0
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Tue Aug 04, 2015 7:58 am
rapamatic offline
Re: Error on plugin activation
if it helps, i enabled xml debugging, since the error seemed related to that heres the full log:
Aug 4, 2015, 8:52:56 AM
  Sonos Debug                     Vaidating Plugin Configuration
  Sonos Debug                         Validation Succesful
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:Browse xmlns:ns0="urn:schemas-upnp-org:service:ContentDirectory:1"><InstanceID>0</InstanceID><ObjectID>FV:2</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter></Filter><StartingIndex>0</StartingIndex><RequestedCount>1000</RequestedCount><SortCriteria></SortCriteria></ns0:Browse></s:Body></s:Envelope>
  Sonos Debug                     1000
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result>&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;item id=&quot;FV:2/8&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;20 - E Street Radio&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;0&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-sonosapi-hls:*:*:*&quot;&gt;x-sonosapi-hls:r%3aestreetradio?sid=37&amp;amp;flags=288&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://www.siriusxm.com/cmds/displayLogo?channelKey=estreetradio&amp;amp;clientId=zingpartner&amp;amp;imageType=14&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;SiriusXM Station&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;00090120r%3aestreetradio&amp;quot; parentID=&amp;quot;00070044g%3arock&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;20 - E Street Radio&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON9479_ray@raykramer.com&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/9&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;26 - Classic Vinyl&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;1&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-sonosapi-hls:*:*:*&quot;&gt;x-sonosapi-hls:r%3aclassicvinyl?sid=37&amp;amp;flags=288&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://www.siriusxm.com/cmds/displayLogo?channelKey=classicvinyl&amp;amp;clientId=zingpartner&amp;amp;imageType=14&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;SiriusXM Station&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;00090120r%3aclassicvinyl&amp;quot; parentID=&amp;quot;00070044g%3arock&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;26 - Classic Vinyl&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON9479_ray@raykramer.com&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/1&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;97.1 | The Drive 97.1FM (Classic Rock)&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;2&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-sonosapi-stream:*:*:*&quot;&gt;x-sonosapi-stream:s28340?sid=254&amp;amp;flags=32&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://d1i6vahw24eb07.cloudfront.net/s28340q.gif&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;TuneIn Station&lt;/r:description&gt;&lt;r:r
1000
esMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;F00090020s28340&amp;quot; parentID=&amp;quot;L&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;97.1 | The Drive 97.1FM (Classic Rock)&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON65031_&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/2&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;97.9 | The Loop 97.9 (Classic Rock)&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;3&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-sonosapi-stream:*:*:*&quot;&gt;x-sonosapi-stream:s30824?sid=254&amp;amp;flags=32&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://d1i6vahw24eb07.cloudfront.net/s0q.gif&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;TuneIn Station&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;F00090020s30824&amp;quot; parentID=&amp;quot;L&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;97.9 | The Loop 97.9 (Classic Rock)&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON65031_&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/14&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Beach&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;4&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-cpcontainer:*:*:*&quot;&gt;x-rincon-cpcontainer:10060a6cspotify%3auser%3arapamatic2%3aplaylist%3a7IBnJO0c5jVjibvDpp71FX&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://spotify-static-resources.s3.amazonaws.com/imgstub/playlist_legacy.png&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Spotify Playlist&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;10060a6cspotify%3auser%3arapamatic2%3aplaylist%3a7IBnJO0c5jVjibvDpp71FX&amp;quot; parentID=&amp;quot;100a0664playlists&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Beach&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.playlistContainer&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/17&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Beatles&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;5&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-play
1000
list:*:*:*&quot;&gt;x-rincon-playlist:RINCON_B8E937296BB201400#A:ALBUMARTIST/Beatles&lt;/res&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Artist&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;A:ALBUMARTIST/Beatles&amp;quot; parentID=&amp;quot;A:ALBUMARTIST/Beatles&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Beatles&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.person.musicArtist&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;RINCON_AssociatedZPUDN&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/23&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Bruce Springsteen&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;6&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-playlist:*:*:*&quot;&gt;x-rincon-playlist:RINCON_B8E9372A04B601400#A:ALBUMARTIST/Bruce%20Springsteen&lt;/res&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Artist&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;A:ALBUMARTIST/Bruce%20Springsteen&amp;quot; parentID=&amp;quot;A:ALBUMARTIST/Bruce%20Springsteen&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Bruce Springsteen&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.person.musicArtist&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;RINCON_AssociatedZPUDN&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/0&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Chicago Public Radio&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;7&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-sonosapi-stream:*:*:*&quot;&gt;x-sonosapi-stream:s27410?sid=254&amp;amp;flags=32&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://d1i6vahw24eb07.cloudfront.net/s27410q.gif&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;TuneIn Station&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;F00090020s27410&amp;quot; parentID=&amp;quot;F00080064c57930%3alocal&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Chicago Public Radio&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON65031_&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/25&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Christmas&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;8&lt;/r:ordinal&gt;&lt;res pr
1000
otocolInfo=&quot;pandora.com-pndrradio:*:audio/x-pandora-radio:*&quot;&gt;pndrradio:209207638013087173?sn=1&lt;/res&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Pandora Radio Station&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;OOOX209207638013087173&amp;quot; parentID=&amp;quot;0&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Christmas&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3_ray@raykramer.com&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/21&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Happy&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;9&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;sonos.com-spotify:*:audio/x-spotify:*&quot;&gt;x-sonos-spotify:spotify%3atrack%3a6NPVjNh8Jhru9xOmyQigds?sid=12&amp;amp;flags=32&amp;amp;sn=5&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://o.scdn.co/image/cb7905340c132365bbaee3f17498f062858382e8&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;By Pharrell Williams&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;00030020spotify%3atrack%3a6NPVjNh8Jhru9xOmyQigds&amp;quot; parentID=&amp;quot;00030020spotify%3atrack%3a6NPVjNh8Jhru9xOmyQigds&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Happy&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/12&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Just Give Me a Reason&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;10&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;sonos.com-spotify:*:audio/x-spotify:*&quot;&gt;x-sonos-spotify:spotify%3atrack%3a1qHaLcG3LOeh6ZB8vii5ZZ?sid=12&amp;amp;flags=32&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://o.scdn.co/image/380fd3773e7f1bef6556371223f6a0e6e619067e&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;By P!nk&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;00030020spotify%3atrack%3a1qHaLcG3LOeh6ZB8vii5ZZ&amp;quot; parentID=&amp;quot;00030000spotify%3atrack%3a1qHaLcG3LOeh6ZB8vii5ZZ&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Just Give Me a Reason&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&a
1000
mp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/6&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Q104.3&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;11&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-sonosapi-stream:*:*:*&quot;&gt;x-sonosapi-stream:live_stations.1465?sid=6&amp;amp;flags=32&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://img.ccrd.clearchannel.com/media/mlib/2135/2012/05/default/waxq-fm_0_1335878692.png&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;iHeartRadio Station&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;10090020live_stations.1465&amp;quot; parentID=&amp;quot;100a0064my_stations.30589966&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Q104.3&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.audioBroadcast&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON1543_X_#Svc1543-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/3&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Ray&amp;apos;s NEW Eclectic&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;12&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-cpcontainer:*:*:*&quot;&gt;x-rincon-cpcontainer:10060a6cspotify%3auser%3arapamatic2%3aplaylist%3a0UcPwuUAv0Ntfla22lUyZC&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://spotify-static-resources.s3.amazonaws.com/imgstub/playlist_legacy.png&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Spotify Playlist&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;10060a6cspotify%3auser%3arapamatic2%3aplaylist%3a0UcPwuUAv0Ntfla22lUyZC&amp;quot; parentID=&amp;quot;100a0664playlists&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Ray&amp;amp;apos;s NEW Eclectic&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.playlistContainer&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/15&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Rock Your Body&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;13&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;sonos.com-spotify:*:audio/x-spotify:*&quot;&gt;x-sonos-spotify:spotify%3atrack%3a1AWQoqb9bSvzTjaLralEkT?sid=12&amp;amp;flags=32&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://o.scdn.co/image/b4096aab2a49b2f2fe2d0f1b483ac51183dba760&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;By Justin Timberlake&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&a
1000
mp;lt;item id=&amp;quot;00030020spotify%3atrack%3a1AWQoqb9bSvzTjaLralEkT&amp;quot; parentID=&amp;quot;00030020spotify%3atrack%3a1AWQoqb9bSvzTjaLralEkT&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Rock Your Body&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/28&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Say Hey (I Love You)&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;14&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-file-cifs:*:audio/mpeg:*&quot;&gt;x-file-cifs://MacPro/Music/Michael%20Franti%20%26%20Spearhead/All%20Rebel%20Rockers/06%20Say%20Hey%20(I%20Love%20You).mp3&lt;/res&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fMichael%2520Franti%2520%2526%2520Spearhead%2fAll%2520Rebel%2520Rockers%2f06%2520Say%2520Hey%2520(I%2520Love%2520You).mp3&amp;amp;v=47&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;By Michael Franti &amp;amp; Spearhead&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;S://MacPro/Music/Michael%20Franti%20%26%20Spearhead/All%20Rebel%20Rockers/06%20Say%20Hey%20(I%20Love%20You).mp3&amp;quot; parentID=&amp;quot;S://MacPro/Music/Michael%20Franti%20%26%20Spearhead/All%20Rebel%20Rockers/06%20Say%20Hey%20(I%20Love%20You).mp3&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Say Hey (I Love You)&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.item.audioItem.musicTrack&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;RINCON_AssociatedZPUDN&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/29&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;Sinatra: Best Of The Best&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;15&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-cpcontainer:*:*:*&quot;&gt;x-rincon-cpcontainer:0004006cspotify%3aalbum%3a2PinY54sX1Uty9C4oQSFdP&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://o.scdn.co/image/2f489bc917202b8214d18d8d9aadf7d74cfe4623&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Album by Frank Sinatra&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;0004006cspotify%3aalbum%3a2PinY54sX1Uty9C4oQSFdP&amp;quot; parentID=&amp;quot;00050064spotify%3aartist%3a1Mxqyy3pSjf8kZZL4QVxS0&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Sinatra: Best Of The Best&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.album.musicAlbum&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/22&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;
c72
&lt;dc:title&gt;Takako Nishizaki Plays Suzuki Evergreens, Vol. 1&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;16&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-cpcontainer:*:*:*&quot;&gt;x-rincon-cpcontainer:0004006cspotify%3aalbum%3a7Df8y0VuRQFjakK7V95akg&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://o.scdn.co/image/1d40d737bcf93dcf25bfdd81b3fd8b1d4869eabc&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Album by Takako Nishizaki&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;0004006cspotify%3aalbum%3a7Df8y0VuRQFjakK7V95akg&amp;quot; parentID=&amp;quot;00020000album:suzuki&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;Takako Nishizaki Plays Suzuki Evergreens, Vol. 1&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.album.musicAlbum&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;item id=&quot;FV:2/26&quot; parentID=&quot;FV:2&quot; restricted=&quot;false&quot;&gt;&lt;dc:title&gt;W Dzień Bożego Narodzenia&lt;/dc:title&gt;&lt;upnp:class&gt;object.itemobject.item.sonos-favorite&lt;/upnp:class&gt;&lt;r:ordinal&gt;17&lt;/r:ordinal&gt;&lt;res protocolInfo=&quot;x-rincon-cpcontainer:*:*:*&quot;&gt;x-rincon-cpcontainer:0004006cspotify%3aalbum%3a72xyEqDj1Z1cNj1YtHFZz7&lt;/res&gt;&lt;upnp:albumArtURI&gt;http://o.scdn.co/image/230571721650bc8ddb2ccd7bda41e72366df5493&lt;/upnp:albumArtURI&gt;&lt;r:type&gt;instantPlay&lt;/r:type&gt;&lt;r:description&gt;Album by Michał Bajor&lt;/r:description&gt;&lt;r:resMD&gt;&amp;lt;DIDL-Lite xmlns:dc=&amp;quot;http://purl.org/dc/elements/1.1/&amp;quot; xmlns:upnp=&amp;quot;urn:schemas-upnp-org:metadata-1-0/upnp/&amp;quot; xmlns:r=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot; xmlns=&amp;quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&amp;quot;&amp;gt;&amp;lt;item id=&amp;quot;0004006cspotify%3aalbum%3a72xyEqDj1Z1cNj1YtHFZz7&amp;quot; parentID=&amp;quot;00020000album:bozego narodzenie&amp;quot; restricted=&amp;quot;true&amp;quot;&amp;gt;&amp;lt;dc:title&amp;gt;W Dzień Bożego Narodzenia&amp;lt;/dc:title&amp;gt;&amp;lt;upnp:class&amp;gt;object.container.album.musicAlbum&amp;lt;/upnp:class&amp;gt;&amp;lt;desc id=&amp;quot;cdudn&amp;quot; nameSpace=&amp;quot;urn:schemas-rinconnetworks-com:metadata-1-0/&amp;quot;&amp;gt;SA_RINCON3079_X_#Svc3079-0-Token&amp;lt;/desc&amp;gt;&amp;lt;/item&amp;gt;&amp;lt;/DIDL-Lite&amp;gt;&lt;/r:resMD&gt;&lt;/item&gt;&lt;/DIDL-Lite&gt;</Result><NumberReturned>18</NumberReturned><TotalMatches>18</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
0
  Sonos Debug                     Method: runConcurrentThread
  Sonos Debug                     Running Concurrent Thread
Thu Aug 13, 2015 9:35 am
rapamatic offline
This still isn't working for me. Is there a better way to get this resolved - email Nick directly?
From what I can tell, the error is occurring when it tries to grab the favorites from my sonos. One by one I tried deleting every favorite (so that I have none now), but the error messages stayed the same....
Fri Aug 14, 2015 5:44 am
nlagaros offline
Apologies for the delay. I just posted an update (0.8.15) that disables the SonosFavorites functionality. It was not code complete, so no purpose in having it around. Let me know if this resolves the issue. Thanks.
Fri Aug 14, 2015 6:17 am
rapamatic offline
No worries man - I know this isn't your day job :)
now it looks like a problem getting the playlists. Here's the log again. I will try checking playlists next. What sort of stuff could be a problem there? Special characters in names?
-Ray
  Sonos Debug                     Method: shutdown
  Stopped plugin "Sonos"
  Upgrading plugin "Sonos" to newer version 0.8.15 (previous version moved to trash)
  Loading plugin "Sonos 0.8.15"
  Starting plugin "Sonos 0.8.15" (pid 16716)
  Started plugin "Sonos 0.8.15"
  Sonos                           Your plugin version, v0.8.15, is current.
  Sonos Debug                         Reference ZP IP:        10.0.0.63
  Sonos Debug                         Pandora:                True
  Sonos Debug                         Pandora User ID:        ray6633
  Sonos Debug                         Pandora Email Address:  ray@raykramer.com
  Sonos Debug                         SiriusXM:               True
  Sonos Debug                     Loading Playlists...
  Sonos Debug                     zoneIP: 10.0.0.63, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
  Sonos Debug                     <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><ns0:Browse xmlns:ns0="urn:schemas-upnp-org:service:ContentDirectory:1"><InstanceID>0</InstanceID><ObjectID>SQ:</ObjectID><BrowseFlag>BrowseDirectChildren</BrowseFlag><Filter></Filter><StartingIndex>0</StartingIndex><RequestedCount>1000</RequestedCount><SortCriteria></SortCriteria></ns0:Browse></s:Body></s:Envelope>
  Sonos Debug                     1000
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result>&lt;DIDL-Lite xmlns:dc=&quot;http://purl.org/dc/elements/1.1/&quot; xmlns:upnp=&quot;urn:schemas-upnp-org:metadata-1-0/upnp/&quot; xmlns:r=&quot;urn:schemas-rinconnetworks-com:metadata-1-0/&quot; xmlns=&quot;urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/&quot;&gt;&lt;container id=&quot;SQ:8&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Angry Rock&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#8&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fBruce%2520Springsteen%2fI%2520Don&amp;apos;t%2520Wanna%2520Go%2520Home%2f1-04%2520Trapped.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLed%2520Zeppelin%2fI%2f02%2520Babe%2520I&amp;apos;m%2520Gonna%2520Leave%2520You.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fBilly%2520Joel%2fThe%2520Complete%2520Hits%2520Collection%2f2-07%2520Pressure.MP3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLed%2520Zeppelin%2fBBC%2520Sessions%2f1-06%2520What%2520Is%2520%2526%2520What%2520Should%2520Never%2520Be.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:11&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Christmas&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#11&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f06.%2520Norah%2520Jones%2520-%2520It%2520Came%2520Upon%2520a%2520Midnight%2520Clear.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f09%2520Silver%2520Bells.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f106%2520White%2520Christmas.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f5-14%2520Shepherds,%2520In%2520The%2520Field%2520Abiding.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:1&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Dominikas Muzak&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#1&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1VQozjsttylAZVgi7jpDlT%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a72np30cEzvqzxAUG5mrhyT%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4QNpBfC0zvjKqPJcyqBy9W%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a2SwkHQpyK3Tq11RtJjQhJY%3fsid%3d12%26flags%3d8224%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:9&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;French&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#9&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253
1000
a5dH5ezJJ7453aGwrcNOdjA%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a3aIKoEFOhLjsgm7mVvVrBq%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a48tg36RXz3rIivfYL91Qiq%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4ltnVLnXEmJU0czaCcqBNo%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:2&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Fun&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#2&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fThe%2520Beatles%2fAbbey%2520Road%2f01%2520Come%2520Together.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fThe%2520Beatles%2fThe%2520Beatles%2f1-04%2520Ob-La-Di,%2520Ob-La-Da.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a69dyvGwVjGsK2CE9qf3Wi4%3fsid%3d12%26flags%3d8224%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0iA3xXSkSCiJywKyo1UKjQ%3fsid%3d12%26flags%3d8224%26sn%3d7&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:6&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Fun Misia Music&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#6&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fCompilations%2fPitch%2520Perfect%2520(Original%2520Motion%2520Picture%2520Soundtrack)%2f04%2520Cups.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:10&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Inga Music&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#10&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1E1dmVzEB3uXL0oEVNi93k%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a5oZnJHikOrrJA6B7pZD4Ks%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4MAnc32ccPQOy5aUL8ee3o%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a7MKhSg9PM52aeTJuEEYShC%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:16&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Nursery Rhymes&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#16&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1pX06KpGgu6KA1mGrJ4XUK%3fsid%3d12%26flags%3d8224%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0DglcPkQ6yRdTdZaIKXubl%3fsid%3d12%26flags%3d8224%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0JcjXs3LaeFcgibHYAnhFA%3fsid%3d12%26flags%3d8224%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0ODl52Es33FHPbuAcgNDzR%3fsid%3d12
1000
%26flags%3d8224%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:7&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Parental Music&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#7&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4ee9T3dZWIWd0CN9OLd0XU%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a3n48U0zZ0zshC2nrfpkGRb%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0Us5iTKJ0dtKm8NhNJ9Jbr%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1XxbLf0gpRvncAKgk8bVo2%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:15&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Parents Party Music&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#15&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-http%3atrack%253a61466311.mp3%3fsid%3d160%26flags%3d32%26sn%3d6&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a2cR1IO5R2tPfVjqowRqcGP%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a7zNslH4HCHeIqIYayKDGbD%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a43rqTHs9mC1QttFTA5n2kF%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:13&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Polish Kids&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#13&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f08%2520Dobosz.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f03%2520Jag%25c3%25b3dki.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f01%2520Panie%2520Janie.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f10%2520Wlaz%25c5%2582%2520Kotek%2520Na%2520P%25c5%2582otek.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:12&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Polskie koledy&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#12&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0kB7OIR7noxOyLnoMEHbRI%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a79PQT7jrYg0bfZWGKYF2jp%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a3hC2hmUGpTWEiRwqD9wE4R%3fsid%3d12%26flags%3d32%26sn%3d5&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a7H4Vn67y6148h8SLtOMh2O%3fsid%3d12%26flags%3d32%26sn%3d5&lt;
e27
/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:3&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Sleepy Time&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#3&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a5dTiP2PseGIV7Js43tgXeS%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:5&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Softer &amp;amp; Calmer&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#5&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4nOi8Y22QaxmAEkIrpb5Fv%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:4&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Sonos Playlist  1&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#4&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fThe%2520Beatles%2fHelp!%2f01%2520Help!.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fBruce%2520Springsteen%2fWe%2520Shall%2520Overcome%2520-%2520The%2520Seeger%2520Sessions%2f04%2520O%2520Mary%2520Don&amp;apos;t%2520You%2520Weep.mp3&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4Y69TZQsfn0rdebpHdfAu7%3fsid%3d12%26flags%3d32&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fThe%2520Beatles%2fHelp!%2f01%2520Help!.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;container id=&quot;SQ:14&quot; parentID=&quot;SQ:&quot; restricted=&quot;true&quot;&gt;&lt;dc:title&gt;Suzuki&lt;/dc:title&gt;&lt;res protocolInfo=&quot;file:*:audio/mpegurl:*&quot;&gt;file:///jffs/settings/savedqueues.rsq#14&lt;/res&gt;&lt;upnp:class&gt;object.container.playlistContainer&lt;/upnp:class&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f01%2520Twinkle,%2520Twinkle,%2520Little%2520Star%2520(Variation%2520A)%2520%255bS.%2520Suzuki%255d.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f15%2520Allegretto%2520%255bS.%2520Suzuki%255d.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f30%2520Song%2520Of%2520The%2520Wind%2520%257bPiano%2520Accompaniment%257d.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;upnp:albumArtURI&gt;/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f44%2520Gavotte%2520%257bPiano%2520Accompaniment%257d.m4a&amp;amp;v=66&lt;/upnp:albumArtURI&gt;&lt;/container&gt;&lt;/DIDL-Lite&gt;</Result><NumberReturned>16</NumberReturned><TotalMatches>16</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
0
  Sonos Debug                     ZP: 1000
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:8" parentID="SQ:" restricted="true"><dc:title>Angry Rock</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#8</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fBruce%2520Springsteen%2fI%2520Don't%2520Wanna%2520Go%2520Home%2f1-04%2520Trapped.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLed%2520Zeppelin%2fI%2f02%2520Babe%2520I'm%2520Gonna%2520Leave%2520You.mp3&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fBilly%2520Joel%2fThe%2520Complete%2520Hits%2520Collection%2f2-07%2520Pressure.MP3&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLed%2520Zeppelin%2fBBC%2520Sessions%2f1-06%2520What%2520Is%2520%2526%2520What%2520Should%2520Never%2520Be.mp3&amp;amp;v=66</upnp:albumArtURI></container><container id="SQ:11" parentID="SQ:" restricted="true"><dc:title>Christmas</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#11</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f06.%2520Norah%2520Jones%2520-%2520It%2520Came%2520Upon%2520a%2520Midnight%2520Clear.mp3&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f09%2520Silver%2520Bells.mp3&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f106%2520White%2520Christmas.mp3&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fChristmas%2520Backup%2520Nov12%25202014%2f5-14%2520Shepherds,%2520In%2520The%2520Field%2520Abiding.mp3&amp;amp;v=66</upnp:albumArtURI></container><container id="SQ:1" parentID="SQ:" restricted="true"><dc:title>Dominikas Muzak</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#1</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1VQozjsttylAZVgi7jpDlT%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a72np30cEzvqzxAUG5mrhyT%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4QNpBfC0zvjKqPJcyqBy9W%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a2SwkHQpyK3Tq11RtJjQhJY%3fsid%3d12%26flags%3d8224%26sn%3d5</upnp:albumArtURI></container><container id="SQ:9" parentID="SQ:" restricted="true"><dc:title>French</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#9</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253
1000
a5dH5ezJJ7453aGwrcNOdjA%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a3aIKoEFOhLjsgm7mVvVrBq%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a48tg36RXz3rIivfYL91Qiq%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4ltnVLnXEmJU0czaCcqBNo%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI></container><container id="SQ:2" parentID="SQ:" restricted="true"><dc:title>Fun</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#2</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fThe%2520Beatles%2fAbbey%2520Road%2f01%2520Come%2520Together.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fThe%2520Beatles%2fThe%2520Beatles%2f1-04%2520Ob-La-Di,%2520Ob-La-Da.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a69dyvGwVjGsK2CE9qf3Wi4%3fsid%3d12%26flags%3d8224%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0iA3xXSkSCiJywKyo1UKjQ%3fsid%3d12%26flags%3d8224%26sn%3d7</upnp:albumArtURI></container><container id="SQ:6" parentID="SQ:" restricted="true"><dc:title>Fun Misia Music</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#6</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fCompilations%2fPitch%2520Perfect%2520(Original%2520Motion%2520Picture%2520Soundtrack)%2f04%2520Cups.m4a&amp;amp;v=66</upnp:albumArtURI></container><container id="SQ:10" parentID="SQ:" restricted="true"><dc:title>Inga Music</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#10</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1E1dmVzEB3uXL0oEVNi93k%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a5oZnJHikOrrJA6B7pZD4Ks%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4MAnc32ccPQOy5aUL8ee3o%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a7MKhSg9PM52aeTJuEEYShC%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI></container><container id="SQ:16" parentID="SQ:" restricted="true"><dc:title>Nursery Rhymes</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#16</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1pX06KpGgu6KA1mGrJ4XUK%3fsid%3d12%26flags%3d8224%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0DglcPkQ6yRdTdZaIKXubl%3fsid%3d12%26flags%3d8224%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0JcjXs3LaeFcgibHYAnhFA%3fsid%3d12%26flags%3d8224%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0ODl52Es33FHPbuAcgNDzR%3fsid%3d12
1000
%26flags%3d8224%26sn%3d5</upnp:albumArtURI></container><container id="SQ:7" parentID="SQ:" restricted="true"><dc:title>Parental Music</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#7</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4ee9T3dZWIWd0CN9OLd0XU%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a3n48U0zZ0zshC2nrfpkGRb%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0Us5iTKJ0dtKm8NhNJ9Jbr%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a1XxbLf0gpRvncAKgk8bVo2%3fsid%3d12%26flags%3d32</upnp:albumArtURI></container><container id="SQ:15" parentID="SQ:" restricted="true"><dc:title>Parents Party Music</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#15</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-http%3atrack%253a61466311.mp3%3fsid%3d160%26flags%3d32%26sn%3d6</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a2cR1IO5R2tPfVjqowRqcGP%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a7zNslH4HCHeIqIYayKDGbD%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a43rqTHs9mC1QttFTA5n2kF%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI></container><container id="SQ:13" parentID="SQ:" restricted="true"><dc:title>Polish Kids</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#13</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f08%2520Dobosz.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f03%2520Jag%25c3%25b3dki.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f01%2520Panie%2520Janie.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fLulek.TV%2fPiosenki%2520Lulka%2520I%2520R%25c3%25b3zi%2f10%2520Wlaz%25c5%2582%2520Kotek%2520Na%2520P%25c5%2582otek.m4a&amp;amp;v=66</upnp:albumArtURI></container><container id="SQ:12" parentID="SQ:" restricted="true"><dc:title>Polskie koledy</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#12</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a0kB7OIR7noxOyLnoMEHbRI%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a79PQT7jrYg0bfZWGKYF2jp%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a3hC2hmUGpTWEiRwqD9wE4R%3fsid%3d12%26flags%3d32%26sn%3d5</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a7H4Vn67y6148h8SLtOMh2O%3fsid%3d12%26flags%3d32%26sn%3d5<
e27
/upnp:albumArtURI></container><container id="SQ:3" parentID="SQ:" restricted="true"><dc:title>Sleepy Time</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#3</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a5dTiP2PseGIV7Js43tgXeS%3fsid%3d12%26flags%3d32</upnp:albumArtURI></container><container id="SQ:5" parentID="SQ:" restricted="true"><dc:title>Softer &amp;amp; Calmer</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#5</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4nOi8Y22QaxmAEkIrpb5Fv%3fsid%3d12%26flags%3d32</upnp:albumArtURI></container><container id="SQ:4" parentID="SQ:" restricted="true"><dc:title>Sonos Playlist  1</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#4</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fThe%2520Beatles%2fHelp!%2f01%2520Help!.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fBruce%2520Springsteen%2fWe%2520Shall%2520Overcome%2520-%2520The%2520Seeger%2520Sessions%2f04%2520O%2520Mary%2520Don't%2520You%2520Weep.mp3&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?s=1&amp;amp;u=x-sonos-spotify%3aspotify%253atrack%253a4Y69TZQsfn0rdebpHdfAu7%3fsid%3d12%26flags%3d32</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro-6%2fMusic%2fMusic%2fThe%2520Beatles%2fHelp!%2f01%2520Help!.m4a&amp;amp;v=66</upnp:albumArtURI></container><container id="SQ:14" parentID="SQ:" restricted="true"><dc:title>Suzuki</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#14</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f01%2520Twinkle,%2520Twinkle,%2520Little%2520Star%2520(Variation%2520A)%2520%255bS.%2520Suzuki%255d.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f15%2520Allegretto%2520%255bS.%2520Suzuki%255d.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f30%2520Song%2520Of%2520The%2520Wind%2520%257bPiano%2520Accompaniment%257d.m4a&amp;amp;v=66</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMacPro%2fMusic%2fCompilations%2fSuzuki%2520Violin%2520School,%2520Volume%25201%2520(Revised)%2f44%2520Gavotte%2520%257bPiano%2520Accompaniment%257d.m4a&amp;amp;v=66</upnp:albumArtURI></container></DIDL-Lite></Result><NumberReturned>16</NumberReturned><TotalMatches>16</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
0
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 200, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1481, in getPlaylistsDirect
  File "./lib/elementtree/ElementTree.py", line 960, in XML
  File "./lib/elementtree/ElementTree.py", line 1242, in feed
<class 'xml.parsers.expat.ExpatError'>: syntax error: line 1, column 0
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Fri Aug 14, 2015 6:52 am
nlagaros offline
Re: Error on plugin activation
Has the plugin worked for you at all? Can you give me your configuration: as in what Zoneplayers you have configured in Indigo.
-Ray
  Sonos Debug                     Getting Plugin Configuration Settings
  Sonos Debug                         Publish/Subscribe Port: 9999
  Sonos Debug                         HTTP Streaming IP:      auto
  Sonos Debug                         HTTP Streaming Port:    8888
  Sonos Debug                         Sound File Path:
  Sonos Debug                         Pandora Password:       *****
  Sonos                           Saved Plugin Configuration
  Sonos Debug                     1000
1000
1000
e27
0
1000
1000
e27
0
Fri Aug 14, 2015 7:42 am
rapamatic offline
The plugin never worked for me.
I have several Play:5s, one Play:1, one sound bar, and one Connect Amp on my system. I am using SonosNet. I only put one Play:5 into Indigo (I believe I had tried adding them all in when I first used the plugin, but as part of my attempts to fix the errors, I took out all but one sonos).
I do notice that some of my playlists have Polish songs in them, with Polish accented characters (like Ł, ł, or Ż). Could that be the issue?
Fri Aug 14, 2015 1:12 pm
nlagaros offline
This is pretty crazy. The XML messages look pretty messed up. I don't think there is any special character issue. I've dealt with that about a dozen times over the past two years. So you have one Play 5 configured (assume your ZonePlayer hardware is upgraded to the latest firmware?) And that one Play:5 has the address 10.0.0.63? I don't know where the "1000" at the beginning of the XML is coming from. That is what is screwing things up.
Fri Aug 14, 2015 1:19 pm
rapamatic offline
Yeah, I just have the one Play 5 configured in Indigo now.
On the firmware front, I am involved in Sonos' beta testing program. I am running an alpha firmware on my setup. I wouldn't imagine that alpha (or beta) firmware would send out non-standard xml, but maybe that's the issue?
Fri Aug 14, 2015 1:24 pm
nlagaros offline
It is possible.. basically i see my request count for list items (1000) prepended with a carriage return to each XML message. Do you have any device without the alpha firmware to try?
Fri Aug 14, 2015 1:47 pm
rapamatic offline
Unfortunately, all my devices are on the alpha firmware. I can see if there is a way to downgrade to the latest public release. I just hope this isn't a sign of things to come in future public releases.
Fri Aug 14, 2015 2:49 pm
nlagaros offline
Is there any particularly new functionality in the alpha version? Just want to know before I make a couple of changes. I may be able to filter out the offending characters.
Sat Aug 15, 2015 4:29 pm
rapamatic offline
Just wanted to pass along an update in case anyone else has a similar issue. After emailing with Nick, it seems the issue is related to having many playlists with Spotify songs in them - it looks like it makes the response messages from Sonos so long they are broken up into parts. Nick is working to figure out how to put them back together.
Later tonight I'll try to purge the Sonos playlists by recreating them as Spotify playlists. I'll advise if this is a workaround in the meantime.
