- Code: Select all
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 204, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1573, in getSiriusXM
File "./lib/elementtree/ElementTree.py", line 859, in parse
File "./lib/elementtree/ElementTree.py", line 584, in parse
File "./lib/elementtree/ElementTree.py", line 1251, in close
<class 'xml.parsers.expat.ExpatError'>: no element found: line 39, column 333130
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I don't think there were any updates to either the plugin or my Sonos system, and I can still play Sonos stations fine through the Sonos app. It just stopped working, so I'm a little perplexed. Prior to the traceback other types of channels (Favorites, Playlists, RadioTime) load correctly.
