Did that and restarted plugin.
Reloading plugin "Sonos 0.6.20"
Stopping plugin "Sonos 0.6.20" (pid 2935)
Sonos Debug Method: stopConcurrentThread
Sonos Debug Stopping device: Sonos PLAY3
Sonos Debug Method: shutdown
Z-Wave received "Bevegelsessensor Stue" status update is off
Stopped plugin "Sonos 0.6.20"
Starting plugin "Sonos 0.6.20" (pid 2952)
Sonos OSTYPE: 13
Sonos Subscribing on port: 9999
Started plugin "Sonos 0.6.20"
Sonos Your plugin version, v0.6.20, is current.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Reference ZP IP: 192.168.0.127
Sonos Debug Publish/Subscribe Port: 9999
Sonos Debug Pandora: False
Sonos Debug Pandora User ID:
Sonos Debug Pandora Email Address:
Sonos Debug SiriusXM: False
Sonos Debug SMB Path:
Sonos Saved Plugin Configuration
Sonos Debug Loading Playlists...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"></DIDL-Lite></Result><NumberReturned>0</NumberReturned><TotalMatches>0</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug Loading RadioTime Favorite Stations...
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"></DIDL-Lite></Result><NumberReturned>0</NumberReturned><TotalMatches>0</TotalMatches><UpdateID>8</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug ZonePlayer: Sonos PLAY3, Enabled: True
Sonos Debug Resetting States for zone: 192.168.0.127
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos PLAY3, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos PLAY3, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos PLAY3, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos PLAY3, State: ZonePlayerUUIDsInGroup, Value:
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 146, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 225, in initZones
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/encodings/utf_8.py", line 16, in decode
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xf8' in position 2: ordinal not in range(128)
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sonos Debug Method: runConcurrentThread
Sonos Debug Running Concurrent Thread
Sonos Debug Vaidating Plugin Configuration
Sonos Debug Validation Succesful
Same error as far as I can tell...
