Sonos
Sun Jul 20, 2014 12:00 pm
Re: Sonos
Hello - receiving an error when trying to unpack the most current version.
Dave
Sun Jul 20, 2014 12:44 pm
ckeyes888 offline
Re: Sonos
6.18 will unzip on my 10.5 machine but not install.
On the 10.8 it won't unzip...error 22 again.
Carl
Sun Jul 20, 2014 4:50 pm
nlagaros offline
Re: Sonos
Please download the new package from the wiki. I think I've dealt with the zip issues.
Dave
Sun Jul 20, 2014 5:24 pm
Re: Sonos
Looks like that did the trick.
Sun Jul 20, 2014 5:59 pm
ckeyes888 offline
Re: Sonos
On 10.5 it installs fine but I'm still not able to play a mp3 announcement.
No error in in the log but I see this error in the Sonos app.
Again, the Sonos app will play the file just fine.
Carl
Sun Jul 20, 2014 6:24 pm
ckeyes888 offline
Re: Sonos
Just tried 6.18 on a 10.8 machine and get this error:
Action Group                    Sonos Announce MP3 Test
  Sonos Error                     Error in plugin execution ExecuteAction:
  File "plugin.py", line 162, in actionZP_announcementMP3
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 898, in actionAnnouncement
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 884, in actionStates
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 255, in SOAPSend
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 860, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 732, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 699, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/httplib.py", line 683, in connect
<class 'socket.timeout'>: timed out
The plugin did create the mp3 file in this version...just won't play it.
The Sonos app will play it fine.
Carl
Sun Jul 20, 2014 11:52 pm
Bleasel offline
Re: Sonos
Upgraded plugin to 0.6.18, other than zone name, no states recognised (also no error message in log)
Reinstalled 0.6.17 and all states recognised
Cheers
Mac OS 10.9.4
Indigo 6.0.13
Mon Jul 21, 2014 12:30 am
ckeyes888 offline
Re: Sonos
One other issue the album art in 6,18 isn't being updated. Odd that I went back to 6.16, where it was working,
and no go on art with that version either. Tried a full reboot as well.
EDIT: My bad. I'd replaced the sonos_art.jpg file with a custom one that somehow it's permission was set to read only.
Art works fine now.
Carl
Mon Jul 21, 2014 6:12 pm
Indy_Larry offline
Re: Sonos
Hey Nick,
I after updating the Sonos Plugin on my 10.7.5 server I'm seeing the following errors
File "plugin.py", line 9, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 39, in <module>
File "./lib/zmq/__init__.py", line 35, in <module>
<type 'exceptions.ImportError'>: dlopen(./lib/zmq/utils/initthreads.so, 2): Library not loaded: /usr/local/lib/libzmq.1.dylib
Referenced from: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/lib/zmq_10.6/utils/initthreads.so
Reason: image not found
Stopping plugin "Sonos 0.6.18" (pid 78246)
Stopped plugin "Sonos 0.6.18"
Error plugin "Sonos 0.6.18" (pid 78246) failed to start -- restarting in 20 seconds
Thanks for all of you work and help with this Plugin.
Larry
Insteon, Z Wave, Hue, Sonos
Mon Jul 21, 2014 7:48 pm
ckeyes888 offline
Re: Sonos
+1 on that. Really appreciate, as I'm sure all users do, all your help with it!
Carl
Sun Jul 27, 2014 4:36 am
haavarda offline
Re: Sonos
Has there any movement on this? I am waiting eagerly because my announcement system is down due to some error in this plugin.
There has been done some great work on this, so I hope these small issues can be fixed!
Håvard
Håvard
Sat Aug 02, 2014 6:24 am
nlagaros offline
Re: Sonos
Seems like one of the ZonePlayers is not responding. It should not be tied to the newer version I posted. Are you still unable to play the Group Announcement file? The error reporting on the Sonos App doesn't make sense if you are then able to play the mp3.
Carl
Sat Aug 02, 2014 6:26 am
nlagaros offline
Re: Sonos
Have you installed the prerequisite libraries? If not, they are on my wiki page. You need the Sonos-ZeroMQ libraries as well as command line tools for your version of OS X.
Indy_Larry wrote:
Hey Nick,
nlagaros offline
Re: Sonos
I think I fixed the issue with the radio station flipping back after the group announcement. Can you please download the latest version and give this another try. Thanks.
Håvard
Sat Aug 02, 2014 11:48 pm
haavarda offline
Re: Sonos
Håvard
The new version works. I can restore play back, and it loads the line in again.
Thanks for the update!
Håvard
Håvard
