Sonos
Fri Feb 20, 2015 12:29 pm
nlagaros offline
Sonos v0.8.9 Update
v0.8.9 - 02/20/2015
  • Bug fix in "Add To Group" action.
  • Re-factored announcements code.
I appreciate everyone being patient. It has been a bear to step through the code trying to figure out what has been going on with announcements. I ended up re-writing most of the logic. I've tested with three ZonePlayers and it seems to be working as expected.
Tue Mar 24, 2015 12:30 pm
nlagaros offline
Sonos v0.8.10 Update
v0.8.10 - 03/24/2015
  • Re-factored Pandora code using "un-official API".
Pandora made changes to their site that seems to have blocked programmatic access to public station lists. This update will authenticate to the site, so you will have to edit the plugin configuration and enter your Pandora password.
Sat Mar 28, 2015 6:40 pm
edrabbit offline
Re: Sonos
Looks like the "Check for updates" menu action might not be working. 0.8.10 is out and I'm seeing:
Mar 28, 2015, 5:37:15 PM
Indigo Cocoa client connected
Sonos Manually checking for updates
Sonos Your plugin version, v0.8.8, is current.
Wed Apr 01, 2015 5:13 am
nlagaros offline
Sonos v0.8.11 Update
v0.8.11 - 04/01/2015
  • Added library to break up calls to Google TTS for announcements. This will allow for announcements over 100 characters.
  • Streamlined some of the announcement code to make less calls to the ZonePlayers.
  • Started implementing logic to play from Sonos Favorites [INCOMPLETE].
Thu Apr 02, 2015 7:27 am
nlagaros offline
Sonos v0.8.12 Update
v0.8.12 - 04/02/2015
  • Cleaned up Google TTS in order to support Python 2.5 (OS X 10.9 and below).
For all those that are not running Indigo on Yosemite, v0.8.11 will not work for you. This release strips out Python 2.6 requirements. Beyond this, the release is identical to v0.8.11.
Fri Apr 17, 2015 7:01 am
nlagaros offline
Sonos v0.8.13 Update
v0.8.13 - 04/17/2015
  • Bug fix for unicode support in group names.
Sun Aug 09, 2015 4:17 am
nlagaros offline
Re: Sonos
v0.8.14 - 08/09/2015
  • Google TTS fix.
Note: This version may not work with older installations of Indigo & OS X. I'm testing on OS X 10.10 with Indigo 6.
Mon Sep 07, 2015 12:22 am
gabbas offline
Re: Sonos
Thanks for writing the plugin. I tried installing it but got a few errors. Any suggestions please? I was running Indigo 6.1.0 on Mac OS 10.6.8, do I need a newer OS? This is what I was seeing:
  Sonos                           Your plugin version, v0.8.15, is current.
  Sonos Error                     There was an error reading the plugin preferences. Please check your configuration.
  Sonos                           Restarting Sonos Plugin...
  Sonos Error                     Error in plugin execution runConcurrentThread:
  File "plugin.py", line 58, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 192, in runConcurrentThread
  File "plugin.py", line 63, in stopConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 290, in stopConcurrentThread
  File "./lib/SonosEventLib.py", line 93, in ZMQ_Kill
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'close'
and then lots of
  Sonos Error                     plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I tried updating Indigo to 6.1.4, and now it's saying
  Sonos Error                     Error in plugin execution InitializeMain:
  File "plugin.py", line 9, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 32, in <module>
<type 'exceptions.ImportError'>: No module named internet
Does this look familiar to anyone?
Mon Sep 07, 2015 12:53 pm
jens offline
Re: Sonos
Is there any more than I, who do not get the TTS to work, worked yesterday :(
have 0.8.15 installed, everything else works super...
//Jens
Mon Sep 07, 2015 12:58 pm
jens offline
Re: Sonos
Have you put in right ip in refferens player??
//Jens
Sat Sep 12, 2015 1:13 pm
gabbas offline
Re: Sonos
At this point I can't even get far enough to create a device, because the "No module named internet" happens when I try to start the plugin. So when I try to create a device, Sonos isn't one of the device types in the menu.
Sat Sep 12, 2015 3:53 pm
Re: Sonos
Disable and delete the plugin and reinstall from scratch. Somehow your copy of the plugin is corrupted.
joe
Sun Oct 25, 2015 3:14 am
shapa offline
Re: Sonos
Google TTS is absolutely unreliable :()
File "plugin.py", line 172, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1112, in actionAnnouncement
File "./lib/gtts/tts.py", line 90, in save
File "./lib/gtts/tts.py", line 108, in write_to_fp
File "./lib/requests/models.py", line 837, in raise_for_status
<class 'requests.exceptions.HTTPError'>: 503 Server Error: Service Unavailable for url: http://translate.google.com/translate_t ... 1&ie=UTF-8
Sun Oct 25, 2015 4:14 am
jens offline
Re: Sonos
Why not use an MP3 file with speech instead, always works :D
use this software "Say It Save It v2.1"
//Jens
Sun Oct 25, 2015 10:09 am
haavarda offline
Re: Sonos
Mp3 files works fine for static messages, but not for dynamic. It you want a variable value spoken, this does not work with pre made MP3 files...
Håvard
