Sonos Python 3 Beta
Thu Jun 08, 2023 9:35 am
Re: Sonos Python 3 Beta
ryanbuckner wrote:
I use Pandora with Sonos, but it's not critical to my Indigo integration.
Did you try Pandora with Version 2023.0.10?
Thu Jun 08, 2023 11:10 am
ryanbuckner offline
Pandora is working with Version 2023.0.10 for me
Thu Jun 08, 2023 12:03 pm
That is very positive news - thank you for the feedback! :D
Obviously there is no need for you to upgrade to v .11.
I will try and figure out a way forward which will look at trying to resolve the issue experienced by @Bleasel.
I think I may be able to find a way to turn Pandora ON and OFF; we'll see. :)
Thu Jun 08, 2023 7:11 pm
Bleasel offline
Thanks, 11 loaded and seems to be working although the following error line has come up in the log. Not sure what issue this creates.
Sonos Error 'HTTP Error 403: Forbidden' in module 'request.py', method 'http_error_default'
Failing statement [line 643]: 'raise HTTPError(req.full_url, code, msg, hdrs, fp)'
Fri Jun 09, 2023 7:50 am
ryanbuckner offline
More testing on version 10:
Testing the Sonos Play Toggle Function for 1 speaker. Currently not having any effect when launched from Action Group or control page regardless of source. No errors to the log.
I have also attempted to configure the plugin to turn on debugging and I'm not able to get the screen to show: (The errors are from the configure attempt, not the toggle)
Jun 9, 2023 at 9:43:09 AM
   Action Group                    Toggle Sonos Play Kitchen
   Error (client)                  timeout waiting for plugin response from com.ssi.indigoplugin.Sonos for request UiGetValues1
   Error (client)                  timeout waiting for plugin response from com.ssi.indigoplugin.Sonos for request CallPluginFunc
   Error (client)                  runConfigDialog() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
Jun 9, 2023 at 9:43:45 AM
   NOAA Weather                    'NOAA Weather' changed at 2023-06-09 08:52:00'.
Fri Jun 09, 2023 8:17 am
ryanbuckner wrote:
... Testing the Sonos Play Toggle Function for 1 speaker. Currently not having any effect when launched from Action Group or control page regardless of source. No errors to the log.
I have also attempted to configure the plugin to turn on debugging and I'm not able to get the screen to show: (The errors are from the configure attempt, not the toggle) ...
Thanks for the report :)
I have just tested both of these and it is working for me i.e. the play toggles and the dialogue displays.
I suspect your plugin is corrupted?
I have just uploaded v .12 to Github (see announcements), so please try with that. If it still fails, I'll dig deeper.
Sat Jun 10, 2023 8:32 am
ryanbuckner offline
v 12 appears to be working for me
Sat Jun 10, 2023 9:05 am
Good news - thanks for the feedback. :)
Tue Jun 13, 2023 8:14 pm
mclass offline
Me too! I held off, but in the end couldn't resist!
As a general comment, I found the installation tedious. It may help if a list of dependencies could be provided (with associated pip commands to allow preparation and avoid the current iterative process.
Thanks for your efforts in bringing the Python 3 version to fruition!!
mclass
Tue Jun 13, 2023 8:48 pm
ryanbuckner offline
mclass
Here's what I had to install - maybe add to the readme:
pip3.10 install boto3
pip3.10 install gTTS
pip3.10 install pyvona
pip3.10 install Twisted
pip3.10 install cryptography==38.0.4
pip3.10 install pandora
pip3.10 install xmltodict
Wed Jun 14, 2023 8:20 am
ryanbuckner wrote:
mclass
@mclass I found it tedious as well, hence the next version will list all the required missing packages or those requiring updates on the first startup of the plugin, so you won't have to keep doing plugin restarts.
@ryanbuckner I realise you had an issue related to cryptography (which is a package now included by default in Indigo as it uses it) but it isn't required by the plugin.
@ryanbuckner You should do an upgrade of cryptography to the latest version (at least v 41.0.1) to fix a security issue via the command:
pip3.10 install --upgrade cryptography
The package requirements for next version (not yet released) are:
boto3==1.26.138
gTTS==2.3.2
ifaddr==0.2.0
lxml==4.9.2
mutagen==1.46.0
# OPTIONAL pandora==1.5.0
pyvona==1.2.1
Twisted==22.10.0
xmltodict==0.13.0
Wed Jun 14, 2023 7:46 pm
ryanbuckner offline
Done. Thanks!
Sat Jun 17, 2023 3:16 pm
ryanbuckner offline
errors after a Mac server reboot:
Sonos Error                     Error in plugin execution InitializeMain:
  File "plugin.py", line 23, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/reactor.py", line 38, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/default.py", line 55, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/default.py", line 49, in _getInstallFunction
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/selectreactor.py", line 18, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/posixbase.py", line 16, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/tcp.py", line 38, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/internet/_newtls.py", line 18, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/twisted/protocols/tls.py", line 42, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/OpenSSL/__init__.py", line 8, in <module>
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/OpenSSL/crypto.py", line 3268, in <module>
type: module 'lib' has no attribute 'OpenSSL_add_all_algorithms'
Sun Jun 18, 2023 10:36 am
ryanbuckner wrote:
errors after a Mac server reboot: ...
Looks like there is an issue with OpenSSL and Twisted (maybe triggered by the cryptography update?).
Interestingly, I don't have the OpenSSL package on my system and don't have the problem.
From your report, I am unclear as to whether the Sonos plugin has stopped working because of this error or not?
Can you do the command:
pip3.10 freeze
in a terminal window. This will list all the packages and their versions and may aid trying to figure what is going on.
Mon Jun 19, 2023 8:30 am
ryanbuckner offline
here's what I have:
affine==2.4.0
aiodns==3.0.0
aiofiles==23.1.0
aioharmony==0.2.9
aiohttp==3.8.4
aiosignal==1.2.0
anyio==3.6.1
async-generator==1.10
async-timeout==4.0.2
attrs==21.4.0
Automat==22.10.0
beautifulsoup4==4.11.1
bimmer-connected==0.13.6
bitarray==2.6.1
boto3==1.26.144
botocore==1.29.144
bs4==0.0.1
certifi==2022.5.18.1
cffi==1.15.0
chacha20poly1305-reuseable==0.0.4
charset-normalizer==2.0.12
click==8.1.2
click-plugins==1.1.1
cligj==0.7.2
constantly==15.1.0
cryptography==41.0.1
cycler==0.11.0
dateparser==1.1.1
dictdiffer==0.9.0
fake-useragent==0.1.11
Flask==2.1.1
fonttools==4.32.0
frozenlist==1.3.0
Geometry==0.0.23
geos==0.2.3
gTTS==2.3.2
h11==0.12.0
html5lib==1.1
htmldate==1.2.1
httpcore==0.15.0
httptools==0.5.0
httpx==0.24.1
hyperlink==21.0.0
idna==3.3
ifaddr==0.2.0
imageio==2.30.0
incremental==22.10.0
itsdangerous==2.1.2
janus==1.0.0
Jinja2==3.1.2
jmespath==1.0.1
json-checker==2.0.0
kiwisolver==1.4.2
lazy_loader==0.2
llvmlite==0.40.0
lxml==4.9.2
MarkupSafe==2.1.1
matplotlib==3.5.1
mediafile==0.11.0
miniaudio==1.55
multidict==6.0.2
mutagen==1.46.0
networkx==3.1
numba==0.57.0
numpy==1.22.3
oauthlib==3.2.0
outcome==1.1.0
packaging==21.3
pandas==1.4.2
pandora==1.5.0
Pillow==9.1.0
protobuf==4.21.12
pyadtpulse==1.0.2
pyasn1==0.4.8
pyasn1-modules==0.2.8
pyatv==0.10.3
pycares==4.2.1
pycparser==2.21
pycryptodome==3.14.1
PyJWT==2.3.0
pyobjc==8.4.1
pyobjc-core==8.4.1
pyobjc-framework-Accounts==8.4.1
pyobjc-framework-AddressBook==8.4.1
pyobjc-framework-AdSupport==8.4.1
pyobjc-framework-AppleScriptKit==8.4.1
pyobjc-framework-AppleScriptObjC==8.4.1
pyobjc-framework-ApplicationServices==8.4.1
pyobjc-framework-AudioVideoBridging==8.4.1
pyobjc-framework-AuthenticationServices==8.4.1
pyobjc-framework-AutomaticAssessmentConfiguration==8.4.1
pyobjc-framework-Automator==8.4.1
pyobjc-framework-AVFoundation==8.4.1
pyobjc-framework-AVKit==8.4.1
pyobjc-framework-BusinessChat==8.4.1
pyobjc-framework-CalendarStore==8.4.1
pyobjc-framework-CFNetwork==8.4.1
pyobjc-framework-CloudKit==8.4.1
pyobjc-framework-Cocoa==8.4.1
pyobjc-framework-Collaboration==8.4.1
pyobjc-framework-ColorSync==8.4.1
pyobjc-framework-Contacts==8.4.1
pyobjc-framework-ContactsUI==8.4.1
pyobjc-framework-CoreAudio==8.4.1
pyobjc-framework-CoreAudioKit==8.4.1
pyobjc-framework-CoreBluetooth==8.4.1
pyobjc-framework-CoreData==8.4.1
pyobjc-framework-CoreHaptics==8.4.1
pyobjc-framework-CoreLocation==8.4.1
pyobjc-framework-CoreMedia==8.4.1
pyobjc-framework-CoreMediaIO==8.4.1
pyobjc-framework-CoreMIDI==8.4.1
pyobjc-framework-CoreML==8.4.1
pyobjc-framework-CoreMotion==8.4.1
pyobjc-framework-CoreServices==8.4.1
pyobjc-framework-CoreSpotlight==8.4.1
pyobjc-framework-CoreText==8.4.1
pyobjc-framework-CoreWLAN==8.4.1
pyobjc-framework-CryptoTokenKit==8.4.1
pyobjc-framework-DeviceCheck==8.4.1
pyobjc-framework-DictionaryServices==8.4.1
pyobjc-framework-DiscRecording==8.4.1
pyobjc-framework-DiscRecordingUI==8.4.1
pyobjc-framework-DiskArbitration==8.4.1
pyobjc-framework-DVDPlayback==8.4.1
pyobjc-framework-EventKit==8.4.1
pyobjc-framework-ExceptionHandling==8.4.1
pyobjc-framework-ExecutionPolicy==8.4.1
pyobjc-framework-ExternalAccessory==8.4.1
pyobjc-framework-FileProvider==8.4.1
pyobjc-framework-FileProviderUI==8.4.1
pyobjc-framework-FinderSync==8.4.1
pyobjc-framework-FSEvents==8.4.1
pyobjc-framework-GameCenter==8.4.1
pyobjc-framework-GameController==8.4.1
pyobjc-framework-GameKit==8.4.1
pyobjc-framework-GameplayKit==8.4.1
pyobjc-framework-ImageCaptureCore==8.4.1
pyobjc-framework-IMServicePlugIn==8.4.1
pyobjc-framework-InputMethodKit==8.4.1
pyobjc-framework-InstallerPlugins==8.4.1
pyobjc-framework-InstantMessage==8.4.1
pyobjc-framework-Intents==8.4.1
pyobjc-framework-IOSurface==8.4.1
pyobjc-framework-iTunesLibrary==8.4.1
pyobjc-framework-LatentSemanticMapping==8.4.1
pyobjc-framework-LaunchServices==8.4.1
pyobjc-framework-libdispatch==8.4.1
pyobjc-framework-LinkPresentation==8.4.1
pyobjc-framework-LocalAuthentication==8.4.1
pyobjc-framework-MapKit==8.4.1
pyobjc-framework-MediaAccessibility==8.4.1
pyobjc-framework-MediaLibrary==8.4.1
pyobjc-framework-MediaPlayer==8.4.1
pyobjc-framework-MediaToolbox==8.4.1
pyobjc-framework-Metal==8.4.1
pyobjc-framework-MetalKit==8.4.1
pyobjc-framework-MetalPerformanceShaders==8.4.1
pyobjc-framework-ModelIO==8.4.1
pyobjc-framework-MultipeerConnectivity==8.4.1
pyobjc-framework-NaturalLanguage==8.4.1
pyobjc-framework-NetFS==8.4.1
pyobjc-framework-Network==8.4.1
pyobjc-framework-NetworkExtension==8.4.1
pyobjc-framework-NotificationCenter==8.4.1
pyobjc-framework-OpenDirectory==8.4.1
pyobjc-framework-OSAKit==8.4.1
pyobjc-framework-OSLog==8.4.1
pyobjc-framework-PencilKit==8.4.1
pyobjc-framework-Photos==8.4.1
pyobjc-framework-PhotosUI==8.4.1
pyobjc-framework-PreferencePanes==8.4.1
pyobjc-framework-PushKit==8.4.1
pyobjc-framework-Quartz==8.4.1
pyobjc-framework-QuickLookThumbnailing==8.4.1
pyobjc-framework-SafariServices==8.4.1
pyobjc-framework-SceneKit==8.4.1
pyobjc-framework-ScreenSaver==8.4.1
pyobjc-framework-ScriptingBridge==8.4.1
pyobjc-framework-SearchKit==8.4.1
pyobjc-framework-Security==8.4.1
pyobjc-framework-SecurityFoundation==8.4.1
pyobjc-framework-SecurityInterface==8.4.1
pyobjc-framework-ServiceManagement==8.4.1
pyobjc-framework-Social==8.4.1
pyobjc-framework-SoundAnalysis==8.4.1
pyobjc-framework-Speech==8.4.1
pyobjc-framework-SpriteKit==8.4.1
pyobjc-framework-StoreKit==8.4.1
pyobjc-framework-SyncServices==8.4.1
pyobjc-framework-SystemConfiguration==8.4.1
pyobjc-framework-SystemExtensions==8.4.1
pyobjc-framework-UserNotifications==8.4.1
pyobjc-framework-VideoSubscriberAccount==8.4.1
pyobjc-framework-VideoToolbox==8.4.1
pyobjc-framework-Vision==8.4.1
pyobjc-framework-WebKit==8.4.1
pyOpenSSL==22.0.0
pyparsing==3.0.7
PySocks==1.7.1
python-dateutil==2.8.2
python-dotenv==0.20.0
pytz==2022.1
pytz-deprecation-shim==0.1.0.post0
pyvona==1.2.1
PyWavelets==1.4.1
rasterio==1.3.7
regex==2022.3.2
requests==2.27.1
requests-oauthlib==1.3.1
rfc3986==1.5.0
s3transfer==0.6.1
samsungtv==1.0.0
samsungtvws==2.5.0
sanic==22.6.1
sanic-routing==22.3.0
sanic-session==0.8.0
scikit-image==0.20.0
scipy==1.8.0
selenium==4.1.3
Shapely==1.8.1.post1
six==1.16.0
slixmpp==1.8.2
sniffio==1.2.0
snuggs==1.4.7
sortedcontainers==2.4.0
soupsieve==2.3.2
srptools==1.0.1
tifffile==2023.4.12
transitions==0.9.0
trio==0.20.0
trio-websocket==0.9.2
tweepy==3.10.0
Twisted==22.10.0
typing_extensions==4.5.0
tzdata==2022.1
tzlocal==4.2
ujson==5.7.0
urllib3==1.26.9
user-agent==0.1.10
uvloop==0.17.0
wakeonlan==2.1.0
webdriver-manager==3.7.0
webencodings==0.5.1
websocket-client==1.3.2
websockets==10.4
Werkzeug==2.1.1
wsproto==1.1.0
xarray==2023.5.0
xmltodict==0.13.0
yarl==1.7.2
zeroconf==0.47.1
zope.interface==6.0
Page 4 of 15 1, 2, 3, 4, 5, 6, 7 ... 15
