kidney wrote:OK it's work in the terminal window....
On the indigo side i get it to work once after that, I have to manuallyy raise or lower the volume to unjam the player for it to work again.
here is the error
- Code: Select all
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Seek
Sonos Error UPNP Error: Restricted Object
Sonos Error Offending Command -> zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Seek
Sonos Debug Error Response: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>711</errorCode></UPnPError></detail></s:Fault></s:Body></s:Envelope>
Sonos Debug RINCON_000E5832D4C601400: Restore Relative Time: 0:00:00
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 202, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1526, in actionAnnouncement
<type 'exceptions.AttributeError'>: 'module' object has no attribute 'errorLog'
nlagaros wrote:Would you restart the plugin and give it a shot beginning to end. These errors occur when the plugin issues transport commands to a ZonePlayer that are not applicable at a particular time. For example, if there is nothing in the queue, the plugin cannot load a certain track in the queue. I did work in v0.8.33 that should have worked around this though.kidney wrote:OK it's work in the terminal window....
here is the error
- Code: Select all
Sonos Error IVONA Input: Justin
Sonos Error IVONA Input: 200
Sonos Error IVONA Input: medium
Sonos Error IVONA Input: this a test
Sonos Error IVONA Error: env: python2.7: No such file or directory
24:Server Plugin root# ln -sf /usr/local/bin/python2.7 /usr/bin/python2.7
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1646, in actionAnnouncement
<type 'exceptions.UnboundLocalError'>: local variable 'group_volume' referenced before assignment
nlagaros wrote:Would you try it one more time with the new version I posted (0.8.34)? It has better error handling and I should be able to clearly see what is missing.
Jan 14, 2016 1:19:10 PM
Action Group aaaa test sonos copy 1
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.152, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.152, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.163, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.163, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.161, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.161, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.151, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.151, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetMediaInfo
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetPositionInfo
Sonos Announcement: This a a test, Volume: 50
Sonos Debug Announcement: set standalone
Sonos remove zone from group: Sonos Chambre
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: BecomeCoordinatorOfStandaloneGroup
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetAVTransportURI
Sonos Debug Announcement: add announcement zones to group
Sonos Debug Sonos Action: Stop
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Stop
Sonos ZonePlayer: Sonos Chambre, Stop
Sonos Debug Announcement: set volume
Sonos Debug Sonos Action: Volume
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetVolume
Sonos ZonePlayer: Sonos Chambre, Current Volume: , New Volume: 50
Sonos Announcement Length: 1.01866666667
Sonos Debug Sonos Action: PlayMode NORMAL
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetPlayMode
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Play
Sonos ZonePlayer: Sonos Chambre, Play
Sonos Debug Restore States: RINCON_000E5832D4C601400:RINCON_000E5832D4C601400:Sonos Chambre
Sonos Debug 01:Q_Crossfade: False
Sonos Debug 02:Q_Repeat: False
Sonos Debug 03:Q_Shuffle: False
Sonos Debug 04:ZP_MUTE:
Sonos Debug 05:ZP_STATE:
Sonos Debug 06:ZP_VOLUME:
Sonos Debug 07:ZP_CurrentURI:
Sonos Debug 08:CurrentURI MetaData:
Sonos Debug 09:ZP_CurrentTrack:
Sonos Debug 10:GROUP_Coordinator: true
Sonos Debug 12:Relative Time: 0:00:00
Sonos Debug 13:ZonePlayerUUIDsInGroup: RINCON_000E5832D4C601400,RINCON_B8E93723C6B201400
Sonos Debug RINCON_000E5832D4C601400: Restore URI:
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /Queue, soapAction: RemoveAllTracks
Sonos ZonePlayer: Sonos Chambre, Clear Queue
Sonos add zone to group: Sonos Salon->Sonos Chambre
Sonos Debug zoneIP: 10.0.1.161, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetAVTransportURI
Sonos Debug RINCON_000E5832D4C601400: Restore Mute:
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetMute
Sonos Debug RINCON_000E5832D4C601400: Restore Volume:
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetCurrentTransportActions
Sonos Debug RINCON_000E5832D4C601400: Restore Track Number:
Sonos Debug Sonos Action: PlayMode REPEAT_ALL
Sonos Debug RINCON_000E5832D4C601400: Restore Play State:
Starting plugin "Sonos 0.8.35" (pid 43941)
Started plugin "Sonos 0.8.35"
Sonos Your plugin version, v0.8.35, is current.
Sonos Debug Getting Plugin Configuration Settings
Sonos Debug Reference ZP IP: 10.0.1.152
Sonos Debug Publish/Subscribe Port: 9999
Sonos Debug Interface: True
Sonos Debug Network Interface: en1
Sonos Debug HTTP Streaming IP: 10.0.1.1
Sonos Debug HTTP Streaming Port: 8888
Sonos Debug Sound File Path:
Sonos Debug Pandora: False
Sonos Debug Pandora Email Address:
Sonos Debug Pandora Password: *****
Sonos Debug SiriusXM: False
Sonos Debug IVONA: True
Sonos Saved Plugin Configuration
Sonos Debug zoneIP: 10.0.1.152, soapRoot: /MediaServer, soapBranch: /ContentDirectory, soapAction: Browse
Sonos Debug Sonos Favorites: FV:2/10, CKOI 96,9, x-sonosapi-stream:s24774?sid=254&flags=32
Sonos Debug Sonos Favorites: FV:2/9, Powerhitz.com - Hip Hop, x-sonosapi-stream:s49800?sid=254&flags=32
Sonos Loaded Sonos Favorites... [2]
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><container id="SQ:22" parentID="SQ:" restricted="true"><dc:title>House party</dc:title><res protocolInfo="file:*:audio/mpegurl:*">file:///jffs/settings/savedqueues.rsq#22</res><upnp:class>object.container.playlistContainer</upnp:class><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMACBOOKPRO-8B2A%2fMusic%2fiTunes%2fiTunes%2520Media%2fMusic%2fFlo%2520Rida%2fWhistle%2520-%2520Single%2f01%2520Whistle.m4a&amp;v=1640</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMACBOOKPRO-8B2A%2fMusic%2fiTunes%2fiTunes%2520Media%2fMusic%2fDon%2520Omar%2520%2526%2520Lucenzo%2fDanza%2520Kuduro%2520-%2520Single%2f01%2520Danza%2520Kuduro.m4a&amp;v=1640</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMACBOOKPRO-8B2A%2fMusic%2fiTunes%2fiTunes%2520Media%2fMusic%2fDavid%2520Guetta%2fOne%2520Love%2520(Bonus%2520Track%2520Version)%2f11%2520One%2520Love%2520(feat.%2520Estelle).m4a&amp;v=1640</upnp:albumArtURI><upnp:albumArtURI>/getaa?u=x-file-cifs%3a%2f%2fMACBOOKPRO-8B2A%2fMusic%2fiTunes%2fiTunes%2520Media%2fMusic%2fDavid%2520Guetta%2fOne%2520Love%2520(Bonus%2520Track%2520Version)%2f01%2520When%2520Love%2520Takes%2520Over%2520(feat.%2520Kelly%2520Rowland).m4a&amp;v=1640</upnp:albumArtURI></container></DIDL-Lite></Result><NumberReturned>1</NumberReturned><TotalMatches>1</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug Playlist: SQ:22, House party, file:///jffs/settings/savedqueues.rsq#22
Sonos Loaded Playlists... [1]
Sonos Debug ZP: <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:BrowseResponse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1"><Result><DIDL-Lite xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:upnp="urn:schemas-upnp-org:metadata-1-0/upnp/" xmlns:r="urn:schemas-rinconnetworks-com:metadata-1-0/" xmlns="urn:schemas-upnp-org:metadata-1-0/DIDL-Lite/"><item id="R:0/0/5" parentID="R:0/0" restricted="false"><dc:title>1 Power Hitz Hip Hop</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s49800?sid=254&amp;flags=32</res></item><item id="R:0/0/4" parentID="R:0/0" restricted="false"><dc:title>Jest FM</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s38926%3ap49010?sid=254&amp;flags=32</res></item><item id="R:0/0/6" parentID="R:0/0" restricted="false"><dc:title>Planète Jazz</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s47769?sid=254&amp;flags=32</res></item><item id="R:0/0/8" parentID="R:0/0" restricted="false"><dc:title>Powerhitz.com - Hip Hop</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s49800?sid=254&amp;flags=32</res></item><item id="R:0/0/7" parentID="R:0/0" restricted="false"><dc:title>VirtualDJ Radio - ClubZone - Channel 1</dc:title><upnp:class>object.item.audioItem.audioBroadcast</upnp:class><res protocolInfo="x-rincon-mp3radio:*:*:*">x-sonosapi-stream:s96756?sid=254&amp;flags=32</res></item></DIDL-Lite></Result><NumberReturned>5</NumberReturned><TotalMatches>5</TotalMatches><UpdateID>0</UpdateID></u:BrowseResponse></s:Body></s:Envelope>
Sonos Debug RadioTime Favorite Station: R:0/0/5, 1 Power Hitz Hip Hop, x-sonosapi-stream:s49800?sid=254&flags=32
Sonos Debug RadioTime Favorite Station: R:0/0/4, Jest FM, x-sonosapi-stream:s38926%3ap49010?sid=254&flags=32
Sonos Debug RadioTime Favorite Station: R:0/0/6, Planète Jazz, x-sonosapi-stream:s47769?sid=254&flags=32
Sonos Debug RadioTime Favorite Station: R:0/0/8, Powerhitz.com - Hip Hop, x-sonosapi-stream:s49800?sid=254&flags=32
Sonos Debug RadioTime Favorite Station: R:0/0/7, VirtualDJ Radio - ClubZone - Channel 1, x-sonosapi-stream:s96756?sid=254&flags=32
Sonos Loaded RadioTime Favorite Stations... [5]
Sonos Debug IVONA: 0|English, American|Salli
Sonos Debug IVONA: 1|English, American|Joey
Sonos Debug IVONA: 2|Danish|Naja
Sonos Debug IVONA: 3|Danish|Mads
Sonos Debug IVONA: 4|German|Marlene
Sonos Debug IVONA: 5|German|Hans
Sonos Debug IVONA: 6|English, Australian|Nicole
Sonos Debug IVONA: 7|English, Australian|Russell
Sonos Debug IVONA: 8|English, British|Amy
Sonos Debug IVONA: 9|English, British|Brian
Sonos Debug IVONA: 10|English, British|Emma
Sonos Debug IVONA: 11|English, Welsh|Gwyneth
Sonos Debug IVONA: 12|English, Welsh|Geraint
Sonos Debug IVONA: 13|Welsh|Gwyneth
Sonos Debug IVONA: 14|Welsh|Geraint
Sonos Debug IVONA: 15|English, Indian|Raveena
Sonos Debug IVONA: 16|English, American|Chipmunk
Sonos Debug IVONA: 17|English, American|Eric
Sonos Debug IVONA: 18|English, American|Ivy
Sonos Debug IVONA: 19|English, American|Jennifer
Sonos Debug IVONA: 20|English, American|Justin
Sonos Debug IVONA: 21|English, American|Kendra
Sonos Debug IVONA: 22|English, American|Kimberly
Sonos Debug IVONA: 23|Spanish, Castilian|Conchita
Sonos Debug IVONA: 24|Spanish, Castilian|Enrique
Sonos Debug IVONA: 25|Spanish, American|Penelope
Sonos Debug IVONA: 26|Spanish, American|Miguel
Sonos Debug IVONA: 27|French, Canadian|Chantal
Sonos Debug IVONA: 28|French|Celine
Sonos Debug IVONA: 29|French|Mathieu
Sonos Debug IVONA: 30|Icelandic|Dora
Sonos Debug IVONA: 31|Icelandic|Karl
Sonos Debug IVONA: 32|Italian|Carla
Sonos Debug IVONA: 33|Italian|Giorgio
Sonos Debug IVONA: 34|Norweigian|Liv
Sonos Debug IVONA: 35|Dutch|Lotte
Sonos Debug IVONA: 36|Dutch|Ruben
Sonos Debug IVONA: 37|Polish|Agnieszka
Sonos Debug IVONA: 38|Polish|Jacek
Sonos Debug IVONA: 39|Polish|Ewa
Sonos Debug IVONA: 40|Polish|Jan
Sonos Debug IVONA: 41|Polish|Maja
Sonos Debug IVONA: 42|Portuguese, Brazilian|Vitoria
Sonos Debug IVONA: 43|Portuguese, Brazilian|Ricardo
Sonos Debug IVONA: 44|Portuguese|Cristiano
Sonos Debug IVONA: 45|Portuguese|Ines
Sonos Debug IVONA: 46|Romanian|Carmen
Sonos Debug IVONA: 47|Russian|Maxim
Sonos Debug IVONA: 48|Russian|Tatyana
Sonos Debug IVONA: 49|Swedish|Astrid
Sonos Debug IVONA: 50|Turkish|Filiz
Sonos Loaded IVONA Voices... [51]
Sonos Debug ZonePlayer: Sonos Bathroom, Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.154
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos Bathroom, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos Bathroom, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos Bathroom, State: Q_Number, Value: 0
Sonos Debug Updating Device: Sonos Bathroom, State: Q_ObjectID, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_ZoneName, Value: Bathroom
Sonos Debug Updating Device: Sonos Bathroom, State: ZP_LocalUID, Value: RINCON_000E5832F14601400
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Sonos Bathroom, State: ZoneGroupName, Value: Bathroom
Sonos Debug Updating Device: Sonos Bathroom, State: ZoneGroupID, Value: RINCON_000E5832F14601400:193
Sonos Debug Updating Device: Sonos Bathroom, State: ZonePlayerUUIDsInGroup, Value: RINCON_000E5832F14601400
Sonos Debug Updating Device: Sonos Bathroom, State: GROUP_Coordinator, Value: true
Sonos Adding ZonePlayer: 10.0.1.154, RINCON_000E5832F14601400, Sonos Bathroom
Sonos Debug ZonePlayer: Sonos Garage, Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.163
Sonos Debug Updating Device: Sonos Garage, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos Garage, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos Garage, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos Garage, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos Garage, State: Q_Number, Value: 0
Sonos Debug Updating Device: Sonos Garage, State: Q_ObjectID, Value:
Sonos Debug Updating Device: Sonos Garage, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos Garage, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Sonos Garage, State: ZP_ZoneName, Value: Garage
Sonos Debug Updating Device: Sonos Garage, State: ZP_LocalUID, Value: RINCON_B8E93723C95E01400
Sonos Debug zoneIP: 10.0.1.163, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Sonos Garage, State: ZoneGroupName, Value: Garage
Sonos Debug Updating Device: Sonos Garage, State: ZoneGroupID, Value: RINCON_B8E93723C95E01400:25
Sonos Debug Updating Device: Sonos Garage, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E93723C95E01400
Sonos Debug Updating Device: Sonos Garage, State: GROUP_Coordinator, Value: true
Sonos Adding ZonePlayer: 10.0.1.163, RINCON_B8E93723C95E01400, Sonos Garage
Sonos Debug ZonePlayer: Sonos Kitchen, Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.152
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos Kitchen, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos Kitchen, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos Kitchen, State: Q_Number, Value: 0
Sonos Debug Updating Device: Sonos Kitchen, State: Q_ObjectID, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_ZoneName, Value: Kitchen
Sonos Debug Updating Device: Sonos Kitchen, State: ZP_LocalUID, Value: RINCON_000E583305BE01400
Sonos Debug zoneIP: 10.0.1.152, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Sonos Kitchen, State: ZoneGroupName, Value: Kitchen
Sonos Debug Updating Device: Sonos Kitchen, State: ZoneGroupID, Value: RINCON_000E583305BE01400:1438
Sonos Debug Updating Device: Sonos Kitchen, State: ZonePlayerUUIDsInGroup, Value: RINCON_000E583305BE01400
Sonos Debug Updating Device: Sonos Kitchen, State: GROUP_Coordinator, Value: true
Sonos Adding ZonePlayer: 10.0.1.152, RINCON_000E583305BE01400, Sonos Kitchen
Sonos Debug ZonePlayer: Sonos Living Room, Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.161
Sonos Debug Updating Device: Sonos Living Room, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos Living Room, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos Living Room, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos Living Room, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos Living Room, State: Q_Number, Value: 0
Sonos Debug Updating Device: Sonos Living Room, State: Q_ObjectID, Value:
Sonos Debug Updating Device: Sonos Living Room, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos Living Room, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Sonos Living Room, State: ZP_ZoneName, Value: Living Room
Sonos Debug Updating Device: Sonos Living Room, State: ZP_LocalUID, Value: RINCON_B8E93723C6B201400
Sonos Debug zoneIP: 10.0.1.161, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Sonos Living Room, State: ZoneGroupName, Value: Living Room
Sonos Debug Updating Device: Sonos Living Room, State: ZoneGroupID, Value: RINCON_000E583305BE01400:1432
Sonos Debug Updating Device: Sonos Living Room, State: ZonePlayerUUIDsInGroup, Value: RINCON_B8E93723C6B201400
Sonos Debug Updating Device: Sonos Living Room, State: GROUP_Coordinator, Value: true
Sonos Adding ZonePlayer: 10.0.1.161, RINCON_B8E93723C6B201400, Sonos Living Room
Sonos Debug ZonePlayer: Sonos Master Bedroom, Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.153
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos Master Bedroom, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos Master Bedroom, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos Master Bedroom, State: Q_Number, Value: 0
Sonos Debug Updating Device: Sonos Master Bedroom, State: Q_ObjectID, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_ZoneName, Value: Master Bedroom
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZP_LocalUID, Value: RINCON_000E5832D4C601400
Sonos Debug zoneIP: 10.0.1.153, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZoneGroupName, Value: Master Bedroom
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZoneGroupID, Value: RINCON_000E5832D4C601400:432
Sonos Debug Updating Device: Sonos Master Bedroom, State: ZonePlayerUUIDsInGroup, Value: RINCON_000E5832D4C601400
Sonos Debug Updating Device: Sonos Master Bedroom, State: GROUP_Coordinator, Value: true
Sonos Adding ZonePlayer: 10.0.1.153, RINCON_000E5832D4C601400, Sonos Master Bedroom
Sonos Debug ZonePlayer: Sonos Media Room, Enabled: True
Sonos Debug Resetting States for zone: 10.0.1.151
Sonos Debug Updating Device: Sonos Media Room, State: ZP_ALBUM, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_ART, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_ARTIST, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_CREATOR, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_CurrentURI, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_DURATION, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_INFO, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_MUTE, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_STATE, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_STATION, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_TRACK, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_VOLUME, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_VOLUME_FIXED, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_ZoneName, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_LocalUID, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_AIName, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_AIPath, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_NALBUM, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_NART, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_NARTIST, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_NTRACK, Value:
Sonos Debug Updating Device: Sonos Media Room, State: Q_Crossfade, Value: off
Sonos Debug Updating Device: Sonos Media Room, State: Q_Repeat, Value: off
Sonos Debug Updating Device: Sonos Media Room, State: Q_Shuffle, Value: off
Sonos Debug Updating Device: Sonos Media Room, State: Q_Number, Value: 0
Sonos Debug Updating Device: Sonos Media Room, State: Q_ObjectID, Value:
Sonos Debug Updating Device: Sonos Media Room, State: GROUP_Coordinator, Value:
Sonos Debug Updating Device: Sonos Media Room, State: GROUP_Name, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_CurrentTrack, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_CurrentTrackURI, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZoneGroupID, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZoneGroupName, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZonePlayerUUIDsInGroup, Value:
Sonos Debug Updating Device: Sonos Media Room, State: ZP_ZoneName, Value: Media Room
Sonos Debug Updating Device: Sonos Media Room, State: ZP_LocalUID, Value: RINCON_000E58250C5601400
Sonos Debug zoneIP: 10.0.1.151, soapRoot: /ZonePlayer, soapBranch: /ZoneGroupTopology, soapAction: GetZoneGroupAttributes
Sonos Debug Updating Device: Sonos Media Room, State: ZoneGroupName, Value: Media Room
Sonos Debug Updating Device: Sonos Media Room, State: ZoneGroupID, Value: RINCON_000E58250C5601400:98
Sonos Debug Updating Device: Sonos Media Room, State: ZonePlayerUUIDsInGroup, Value: RINCON_000E58250C5601400
Sonos Debug Updating Device: Sonos Media Room, State: GROUP_Coordinator, Value: true
Sonos Adding ZonePlayer: 10.0.1.151, RINCON_000E58250C5601400, Sonos Media Room
Sonos Subscribing on port: 9999
Sonos SonosEvents INFO: Publishing on port: 9999
Sonos Event Ignition...
Sonos Serving HTTP Streamer on 10.0.1.1 [0.0.0.0], port 8888
Jan 17, 2016 1:22:16 AM
Sonos Announcement: this a test, Volume: 50
Sonos remove zone from group: Sonos Master Bedroom
Sonos remove zone from group: Sonos Bathroom
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: BecomeCoordinatorOfStandaloneGroup
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetAVTransportURI
Sonos ZonePlayer: Sonos Master Bedroom, Stop
Sonos ZonePlayer: Sonos Master Bedroom, Current Volume: , New Volume: 50
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetVolume
Sonos ZonePlayer: Sonos Bathroom, Current Volume: , New Volume: 50
Sonos Announcement Length: 0.940333333333
Sonos ZonePlayer: Sonos Master Bedroom, Play
Sonos Debug Restore States: RINCON_000E5832D4C601400:RINCON_000E5832D4C601400:Sonos Master Bedroom
Sonos ZonePlayer: Sonos Master Bedroom, Clear Queue
Sonos Debug Restore States: RINCON_000E5832F14601400:RINCON_000E5832F14601400:Sonos Bathroom
Sonos Debug 13:ZonePlayerUUIDsInGroup: RINCON_000E5832F14601400
Sonos Debug RINCON_000E5832F14601400: Restore URI:
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /Queue, soapAction: RemoveAllTracks
Sonos ZonePlayer: Sonos Bathroom, Clear Queue
Sonos Debug RINCON_000E5832F14601400: Restore Mute:
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /RenderingControl, soapAction: SetMute
Sonos Debug RINCON_000E5832F14601400: Restore Volume:
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: GetCurrentTransportActions
Sonos Debug RINCON_000E5832F14601400: Restore Track Number:
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Seek
Sonos Error Offending Command -> zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Seek
Sonos Debug RINCON_000E5832F14601400: Restore Relative Time: 0:00:00
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: SetPlayMode
Sonos Debug RINCON_000E5832F14601400: Restore Play State:
Sonos Debug zoneIP: 10.0.1.154, soapRoot: /MediaRenderer, soapBranch: /AVTransport, soapAction: Stop
Sonos ZonePlayer: Sonos Bathroom, Stop
nlagaros wrote:In the plugin configuration, you specify en1 as the interface of your Indigo server that is on the same network as your ZonePlayers. Is this the case? From this log, I see that there are no updates being received. This is why the announcement is not working as expected.
WARN coherence Jan 17 10:13:37 Coherence UPnP framework version 0.6.6.2 starting... (coherence/base.py:283)
Unhandled error in Deferred:
Unhandled Error
Failure: twisted.internet.error.MulticastJoinError: ('\xef\xff\xff\xfa', '\x18\xc8\xf1%', 49, "Can't assign requested address")
WARN webserver Jan 17 10:13:37 WebServer on port 59252 ready (coherence/base.py:124)
./lib/coherence/extern/louie.py:44: UserWarning: extern.louie will soon be deprecated in favor of coherence.dispatcher.
warnings.warn("extern.louie will soon be deprecated in favor of coherence.dispatcher.")
10.0.1.153 - - [17/Jan/2016 10:13:46] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 10:15:43] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 10:16:49] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 10:17:50] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 10:17:51] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 10:26:58] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:31:47] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:31:49] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:32:05] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:34:06] "GET /announcement.mp3 HTTP/1.1" 200 -
WARN event_protocol Jan 17 10:43:07 response with error code '412' received upon our 'subscribe' request (coherence/upnp/core/event.py:233)
WARN event_protocol Jan 17 10:43:08 response with error code '412' received upon our 'subscribe' request (coherence/upnp/core/event.py:233)
WARN event_protocol Jan 17 10:43:09 response with error code '412' received upon our 'subscribe' request (coherence/upnp/core/event.py:233)
10.0.1.152 - - [17/Jan/2016 10:44:05] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:52:05] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:55:50] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:56:26] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [17/Jan/2016 10:59:10] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 11:28:32] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.161 - - [17/Jan/2016 11:41:36] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.153 - - [17/Jan/2016 19:48:27] "GET /announcement.mp3 HTTP/1.1" 200 -
WARN device Jan 17 20:55:37 service has no uri for eventing (coherence/upnp/core/device.py:279)
10.0.1.152 - - [18/Jan/2016 06:30:02] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [18/Jan/2016 06:30:03] "GET /announcement.mp3 HTTP/1.1" 200 -
10.0.1.152 - - [18/Jan/2016 07:30:03] "GET /announcement.mp3 HTTP/1.1" 200 -
WARN device Jan 18 07:31:37 service has no uri for eventing (coherence/upnp/core/device.py:279)
nlagaros wrote:The log you posted on startup - there should be a little bit more that dumps what is in a file called coherence.log. It is in the plugin directory and may give us a hint as to what is going on. Would you be able to show me that file. Thanks.
