Group announcement issue
Sat Oct 31, 2015 11:48 am
marceltrapman offline
Hi, when setting a group announcement I only see one empty entry in the checkboxes for the group to select.
I actually have one group setup but it looks as though the plugin does not recognise it..
I have attached part of the error log that is relevant (I hope)...
31 Oct 2015 18:31:12
Schedule new trigger (delayed action)
31 Oct 2015 18:32:07
Z-Wave received "Front Door Bell" status update is on
Trigger Front Door Bell Ringing
Trigger new trigger
Sonos Announcement: The doorbell, Volume: 40, Line-In:
Sonos Error Error in plugin execution ExecuteAction:
File "plugin.py", line 169, in actionZP_announcement
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1071, in actionAnnouncement
<type 'exceptions.ValueError'>: invalid literal for int() with base 10: ''
Z-Wave received "Front Door Bell" status update is off
31 Oct 2015 18:34:58
Trigger Front door bell Sonos Kitchen
Sonos Announcement: There is somebody at the door, Volume: 40
File "plugin.py", line 172, in actionZP_announcementMP3
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1119, in actionAnnouncement
<type 'exceptions.IndexError'>: list index out of range
Schedule Front door bell Sonos Kitchen (delayed action)
31 Oct 2015 18:35:54
Disabling plugin "Sonos 0.8.15"
Stopping plugin "Sonos 0.8.15" (pid 5400)
Sonos Error Error in plugin execution stopConcurrentThread:
File "plugin.py", line 63, in stopConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 290, in stopConcurrentThread
File "./lib/SonosEventLib.py", line 93, in ZMQ_Kill
<type 'exceptions.AttributeError'>: 'NoneType' object has no attribute 'close'
Sonos Error Error in plugin execution _preShutdown:
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 135, in _preShutdown
Stopped plugin "Sonos 0.8.15"
Enabling plugin "Sonos 0.8.15"
Starting plugin "Sonos 0.8.15" (pid 5532)
Started plugin "Sonos 0.8.15"
Sonos Your plugin version, v0.8.15, is current.
Sonos Saved Plugin Configuration
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 58, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 200, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1479, in getPlaylistsDirect
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 429, in SOAPSend
File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/socket.py", line 348, in read
<class 'socket.error'>: [Errno 54] Connection reset by peer
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
31 Oct 2015 18:36:26
Sonos remove zone from group: Sonos Kitchen
Sonos Announcement Length: 1.656
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 1158, in actionAnnouncement
<type 'exceptions.TypeError'>: cannot concatenate 'str' and 'NoneType' objects
Sun Nov 08, 2015 11:51 am
nlagaros offline
Re: Group announcement issue
Please download the latest version of the plugin and try again. If it fails, turn on debugging and send me the output on plugin startup. Hopefully something simple.
