LIFX Mini Color - Not Discovered by Indigo App
Thu Jul 12, 2018 2:37 pm
pspottswood offline
I just purchased 3 LIFX MINI Color bulbs. Unlike my LIFX BR30, A19, and + BR30, the MINIs are not discovered in Indigo after installation. They are on my network and can be seen and controlled by other applications (the LIFX App and the LifeStyle for LIFX App.
The Indigo App indicates that they are supported hardware. Why are they not being discovered within the Indigo app?
FYI: The LIFX App reports them as Model "LIFX Mini2 C"
Fri Jul 13, 2018 7:12 am
Re: LIFX Mini Color - Not Discovered by Indigo App
Please download and install this interim pre-release version [5.0.8] and see if it now works: LIFX Controlller - 5.0.8 Release
Hopefully this will fix your problem - if it does I will update the plugin in the Plugin Store. :)
Fri Jul 13, 2018 7:15 am
pspottswood offline
Yes. That fixed the problem. Thank you very much for the quick response and solution.
Fri Jul 13, 2018 11:56 am
Glad it's fixed and thanks for the feedback. :)
I have now uploaded version 5.0.9 to the plugin store - it is identical to 5.0.8 (apart from the number). I was having a few problems trying to do the updated and needed to bump the number. :)
