Physical switches for LIFX lights
Thu Mar 15, 2018 2:53 am
colinpartridge offline
I'm looking at putting LIFX downlighters into a kitchen refurb but the one stumbling block I have is the lack of a dedicated Physical switch to control on/off and dimming in particular, as per the Philips Hue remote. I can obviously use a normal light switch to power them on and off, but then I lose any automated control I might want when they are powered down. Any clever thoughts on the most reliable way to achieve this?
Colin
Thu Mar 15, 2018 6:50 am
Re: Physical switches for LIFX lights
If there's already a switch in place that controls those lights, why use LIFX bulbs? Put in a controllable switch and use normal bulbs instead.
Thu Mar 15, 2018 7:04 am
The intention is to change the colour temperature of the lights during the day, day light temp during the day and then warm white in the evening, followed by party mode!
Colin
Thu Mar 15, 2018 7:05 am
Maybe because the LIFX bulbs are coloured lamps and can give themed effects. :)
Thu Mar 15, 2018 8:10 am
Would the existing light switch only be controlling the LIFX downlighters, in which case you could potentially use the light switch to control a Fibaro relay (or similar) - the realy wouldn't switch off the bulbs but just record that the switch had been pressed. The z-wave request could be used as a trigger to turn the LIFX lamps on and off?
Alternatively you could use something like a ZRC90 to control the LIFX bulbs, which is what I do. :)
However, you really need to be able to physically switch the LIFX bulbs on and off (just in case they get into a bad state), so will probably need a separate switch that could do this. :)
Thu Mar 15, 2018 8:22 am
Swancoat offline
Just an Insteon switch or something with no load attached and only acting as a button. Or any other kind of keypad, really.
http://nerdhome.jimdo.com
Thu Mar 15, 2018 8:54 am
I was thinking along those lines already, but using a qubino which has 3 switch inputs. What I need to be careful about is reliability and have a failsafe method of switching them to their default state if the z-wave network or my indigo server goes down.
Cheers
colin
Thu Mar 15, 2018 8:55 am
Sadly the Insteon route isn't available to me as I'm in the UK.
Fri Apr 06, 2018 1:28 am
noel1983 offline
Personally I would use a fibaro dimmer module in behind momentary switches.
That way you get the local switching thats directly connected to the lights so in case of indigo going down etc your lights still work.
You can press and hold to dim so you keep local dimming control and you’ll always have remote/automated control via zwave.
So long as you have space for a dimmer module behind the switches then you’re good.
May have to consider how many circuits you have but this to me would seem the best option for what you’re looking for.
Fri Apr 06, 2018 3:55 am
The Lifx units are wi-fi devices so whilst the on/off can be controlled by a physical switch the dimming is done via the network. I've currently removed the Lifx Units from the kitchen and reverted to just dimmable LEDs units to simplify things and I'm trying out a Qubino Dimmer unit with those.
Colin
Fri Apr 06, 2018 4:00 am
noel1983 offline
Aaah I see.
Are there any colour dimmable LED bulbs out there that can have switch control of on/off/dim but app/automation control of colour? That I'm guessing is what you're really after?
Alternatively if there's particular 'scenes' or dim settings you want then how about a normal switch for the on/off then some kind of scene controller near the lightswitch or in a more convenient position?
Fri Apr 06, 2018 4:24 am
noel1983 wrote:
Aaah I see.
The Philips Hue system works well from that respect with its own physical remote control, with the ability to dim as well. I would use the hue downlights but they are not bright enough for working lights. I'm not that bothered by the colour aspect but it is nice to be able to control the white colour temperature.
Colin
Fri Apr 06, 2018 1:18 pm
jh71283 offline
colinpartridge wrote:
noel1983 wrote:
Aaah I see.
Colin
Have you tried the GU10 white ambiance lights from hue? They are brighter imo than the coloured ones.
Fri Apr 06, 2018 2:28 pm
noel1983 wrote:
Aaah I see.
Colin
I haven't tried them, no. I was going by their spec which quote 250 Lumen as opposed to the spec on the LIFX downlighter at 800 lumens, they need to be bright as they are the main working lights in the kitchen.
