Hi all,
I am using SKY Go from abroad and I would like to stream it from the iMac to a Chomecast device connected to my TV, therefore I would need to automate following tasks
- shut down Ethernet interface and bring up WiFi (Chromecast works only via same WiFi network) --> this can be done via shell script
- connect to a VPN Service (my father's network) which is in Italy so that I can use Sky Go Italy --> this I was not able to do it via AppleScript
- Open automatically an URL in Chrome --> I did this via AppleScript and it works; only automatic login to Sky Website is missing (sometimes I am kicked out, do not know why)
- Cast the tab to Chromecast --> I do not know if this is possible via AppleScript.
Then I would create an Action inside Indigo which makes everything, but without the VPN part is useless.
Do you have something similar?
Marco
