Bounty for iAqualink plugin
Mon Sep 26, 2022 4:02 pm
roquej offline
Indigo is the center of my home automation strategy. However, I am struggling to control my pool, which is important for the family.
As a workaround, I use Home Assistance with the iAqualink integration, Node-Red, and MQTT to link back to Indigo virtual devices. It works, but it's touchy.
To make the family happy, I am willing to offer a bounty to get a plugin created. There seem to be open-source libraries (https://pypi.org/project/iaqualink/) for iAqualink.
Any takers?
Thank you!
JP
Sat Oct 22, 2022 6:26 pm
ryanbuckner offline
Re: Bounty for iAqualink plugin
You likely don't have many responses because the developer would need to have an iAqualink. I think the only solution is for you to buy me a pool and I'll build your plugin.
Sat Oct 22, 2022 6:32 pm
I'll look into using iAqualink for the new house (construction starting after the new year). If I go that way, then I'll do a plugin. Until then, all I have is the Pentair system with the serial interface.
Sat Oct 22, 2022 6:34 pm
Keep in mind that's a cloud interface, so no control if you loose internet or the cloud servers are down.
Mon Oct 24, 2022 8:57 am
roquej offline
Understood the online part, and that is not an issue.
keeping my fingers crossed!
JP
Fri Jan 20, 2023 7:08 pm
billorav offline
I have delayed the upgrading to 2022.2 since I'm not sure I will have connectivity to our older Jandy pool/spa controller with the change to Python 3. I use the older Jandy Aqualink plugin that in the store, it says it requires "5.1.3 thru v2022.2". I'm running 2021.1 and have a new Mac mini sitting in the box ready to change things out but the hot tub / pool controls are really important to us. I have experimented a little with the Pentair Pool plug in but have not tried to communicate with the old Aqua Link RS serial interphase with 2022.2 yet. I would be interested in supporting a updated plugin (from you) since Yergey's plugins (Jandy Aqualink) last version updated was in 2012. Here is a control page of what we use to control the Jandy system. Thanks.
Sun Apr 23, 2023 8:07 am
hamw offline
I'd also be interested in the iAqualink plugin...
Fri Apr 28, 2023 9:01 am
pgershon offline
I dont think I am up to the development side for this, but I believe much of the Jandy-side work has been done, Look at this to AqualinkD
https://github.com/sfeakes/AqualinkD
Fri Apr 28, 2023 10:34 am
hamw offline
Thanks for posting. I did look at that, but there is no way that I have the ability to integrate it… :-)
Would be great if someone could pick it up.
Fri Apr 28, 2023 10:44 pm
rhanson offline
They have an API for both HTTP and MQTT (they are the same it appears).
https://github.com/sfeakes/AqualinkD/wiki#api-v20
On that page, you'll see examples of how to run commands. They use curl as an example, and you can take those lines and adapt them to become Script Actions in Indigo.
For example, you could make an Action Group for "Pool pump on", and it would contain a script action. This is what they show (using curl) to turn on the pump:
curl -X PUT -d '{"value":"1"}'  "localhost/api/Filter_Pump/set"
And in Indigo, you'd just do this in a script action:
import requests
cmd_data = {"value": "1"}
r = requests.put("http://localhost/api/Filter_Pump/set", data=cmd_data)
(I've omitted error checking, but if something went wrong, it might appear in red in your indigo log.)
It would take a little while to bang out the handful of action groups that you need, and then you'd have them for your automations.
