USB Controlled relay
Thu Dec 16, 2021 11:32 am
berkinet offline
I need a very simple relay to operate a wired electric door latch. The connection to the door is available at the Indigo server location. So, all I need is a very basic relay. This one was low priced and looked like it would do the job. https://www.amazon.com/dp/B01CN7E0RQ
I can probably create a simple virtual device with a couple of shell scripts. But, I was wondering if anyone here had any experience with this or some similar product.
TIA
Thu Dec 16, 2021 1:32 pm
Re: USB Controlled relay
No experience with such things, but looks interesting.
You may have already seen it, but someone added a simple Python script in the review section so it looks like Indigo integration would be straight-forward (not including the script here in case it's not the way to go with this device).
Thu Dec 16, 2021 5:31 pm
berkinet offline
You may have already seen it, but someone added a simple Python script in the review section so it looks like Indigo integration would be straight-forward...
Thanks. Could you send me the link to that post. Not sure where the "review section" is :oops:
BTW, there sis a USB driver for the Mac as well as some VERY rudimentary software support at https://download948.mediafire.com/xjxqv ... S-1_EN.zip
Thu Dec 16, 2021 5:37 pm
The reviews of the product at Amazon you linked to. :D
Thu Dec 16, 2021 5:39 pm
berkinet offline
Doh. I figured you meant in the Indigo forums.
Thu Dec 16, 2021 5:58 pm
berkinet offline
I missed it on the first pass. I just needed to search the reviews for Python. So, it would be pretty easy to just pass an arg on the command line for on or off. Or, a similar shell script calling nc (netcat), or even
echo -n -e '\xA0\x01\x00\xA1' > /dev/ttyUSBfoo #on
echo -n -e '\xA0\x01\x01\xA2' > /dev/ttyUSBfoo #off
Too bad there does not seem to be a status command. In any case, I have ordered one and will report back as to how it works.
EDIT: There is a status query: FF :D
Tue Dec 21, 2021 11:51 pm
berkinet offline
Ok. I received the relay and it works. Though, it has limitations, although you can supposedly get a status from it, attempts to read from it return nothing. Other than that, it is really perfect for my application, releasing a door lock.
import serial
import time
ser = serial.Serial('/dev/cu.wchusbserialfd130', 9600)
ser.write(serial.to_bytes([0xA0, 0x01, 0x01, 0xA2]))
time.sleep(5.0)
ser.write(serial.to_bytes([0xA0, 0x01, 0x00, 0xA1]))
