Norwegian powermeter-data
Wed Mar 07, 2018 11:07 am
thomas_ja27 offline
Hello! :)
The authorities have decided that all of Norway will get new smart powermeters in 2018, I have got this fitted recently.
The meter has Mbus connection. I have connected the meter to the Indigo server with USB with a converter.
I have received a program that decodes the data from OBIS codes that the meter sends out.
Is there a way to get this data from terminal and into Indigo? is not so good at programming. It is "Act_Pow_P_Q1_Q4" as shown in the picture that is most interesting to get into indigo.
The data is updated every 2 seconds.
Wed Mar 07, 2018 11:48 am
Re: Norwegian powermeter-data
I’m sure its doable to get that whole data into variable/states, but I’m hoping someone like davel17 pops along.
Wed Mar 07, 2018 11:53 am
Colorado4Wheeler offline
That looks like a standard JSON dictionary to me. That means super simple to translate that to an Indigo plugin so long as it either can call us when it updates or if we have an easy API method to ask it questions. The data is solid though.
Wed Mar 07, 2018 12:17 pm
Yeah, that's what I thought.
If it was a web service then the GhostXML plugin would read it, but I suspect it needs Python to call the C code and insert into states.
Thomas, cab you post the C code?
Wed Mar 07, 2018 1:02 pm
thomas_ja27 offline
Here it is:
It consists of several codes, linking the entire program so that you can see.
In the makefile, I see that the program (test_rx) is composed of 4 codes: rs232.c, read.c, fcs.c and aes.c
https://www.dropbox.com/sh/avdtlvaad3jabs9/AAAqdC9z51MllaxBt72-OaMXa?dl=0
Here is the code of "read.c"
 * Main: read from han-port or file
#include <fcntl.h>
#include <sys/ioctl.h>
#include <errno.h>
#include <paths.h>
#include <termios.h>
#include <sysexits.h>
#include <sys/param.h>
#include <sys/select.h>
#include <sys/time.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <time.h>
#include <math.h>
#include <inttypes.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <arpa/inet.h>
#ifdef _WIN32
#include <Windows.h>
#else
#include <unistd.h>
#include <netdb.h>
#endif
#include "rs232.h"
#include "aes.h"
typedef struct {
  int act_pow_pos; /* OBIS Code 1.0.1.7.0.255 - Active Power + (Q1+Q4) */
} Items1;
typedef struct {
  char obis_list_version[1000]; /* OBIS Code 1.1.0.2.129.255 - OBIS List Version Identifier */
  char gs1[1000]; /* OBIS Code 0.0.96.1.0.255 - Meter-ID(GIAI GS1 - 16 digits */
  char meter_model[1000]; /* OBIS Code 0.0.96.1.7 - Meter Type */
  int act_pow_pos; /* Active Power + */
  int act_pow_neg; /* Actve Power - */
  int react_pow_pos; /* Reactive Power + */
  int react_pow_neg; /* Reactive Power - */
  int curr_L1; /* Current Phase L1 */
  int volt_L1; /* Voltage L1 */
} Items9;
typedef struct {
  char meter_model[1000]; /* OBIS Code 0.0.96.1.7.255 - Meter Type */
  int act_pow_neg;  /* Active Power - */
  int curr_L1;  /* Current Phase L1 mA */
  int curr_L2;  /* Current Phase L2 mA */
  int curr_L3; /* Current Phase L3 mA */
  int volt_L2; /* Voltage L2 */
  int volt_L3; /* Voltage L3 */
} Items13;
typedef struct {
  int curr_L1;
  int volt_L1;
  char date_time[1000]; /* OBIS Code: 0.0.1.0.0.255 - Clock and Date in Meter */
  int act_energy_pos;
  int act_energy_neg;
  int react_energy_pos;
  int react_energy_neg;
} Items14;
typedef struct {
  int curr_L1; /* Current L1 */
  int curr_L2; /* Current L2 */
  int curr_L3; /* Current L3 */
  int act_energy_pa; /* Active Energy +A */
  int act_energy_ma; /* Active Energy -A */
  int act_energy_pr; /* Active Energy +R */
  int act_energy_mr; /* Active Energy -R */
} Items18;
7e                                                     : Flag (0x7e)
a0 87                                                  : Frame Format Field
01 02                                                  : Source Address
01                                                     : Destination Address
10                                                     : Control Field = R R R P/F S S S 0 (I Frame)
9e 6d                                                  : HCS
e6 e7 00                                               : DLMS/COSEM LLC Addresses
0f 40 00 00 00                                         : DLMS HEADER?
09 0c 07 d0 01 03 01 0e 00 0c ff 80 00 03              : Information
02 0e                                                  : Information
09 07 4b 46 4d 5f 30 30 31                             : Information
09 10 36 39 37 30 36 33 31 34 30 30 30 30 30 39 35 30  : Information
09 08 4d 41 31 30 35 48 32 45                          : Information
06 00 00 00 00                                         : Information
06 00 00 00 0e                                         : Information
06 00 00 09 01                                         : Information
97 35                                                  : FCS
7e                                                     : Flag
typedef struct {
  int year;
  int month;
  int day;
  int hour;
  int min;
  int sec;
  char tm[100];
  int num_items;
  union {
    Items1 msg1;   /* List 1: 1-and-3-phase */
    Items9 msg9;   /* List 2: 1-phase */
    Items13 msg13; /* List 2: 3-phase */
    Items14 msg14; /* List 3: 1-phase */
    Items18 msg18; /* List 3: 3-phase */
} HanMsg;
HanMsg msg;
 * FUNCTION: verifyMessage()
int verifyMessage(unsigned char *buf,
        unsigned int buf_len)
  /* warning killers */
  buf = buf;
  buf_len = buf_len;
  return 0;
 * FUNCTION: decodeMessage()
int decodeMessage(unsigned char *buf,
        int buf_len,
        HanMsg *msg)
  buf_len = buf_len;
  memset(msg, 0, sizeof(HanMsg)); /* clear/init data */
  if (buf[17] == 0x09) {
    msg->year = buf[19]<<8 | buf[20];
    msg->month = buf[21];
    msg->day = buf[22];
    msg->hour = buf[24];
    msg->min = buf[25];
    msg->sec = buf[26];
    sprintf(msg->tm, "%d-%02d-%02d %02d:%02d:%02d", msg->year, msg->month, msg->day, msg->hour, msg->min, msg->sec);
    int offset = 17 + 2 + buf[18];
    if (buf[offset]== 0x02) {
      msg->num_items = buf[offset+1];
    offset+=2;
    if (msg->num_items == 1) { /* Num Records: 1 */
      if (buf[offset]==0x06) { /* Item 1 */
   msg->msg1.act_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
    else if (msg->num_items==9) { /* Num records: 9 */
      unsigned int num_bytes=0;
      if (buf[offset]==0x09) { /* Item 1 */
   num_bytes = buf[offset+1];
   strncpy(msg->msg9.obis_list_version, (const char *) buf+offset+2, num_bytes);
   msg->msg9.obis_list_version[num_bytes] = '\0';
      offset+=2+num_bytes;
      if (buf[offset]==0x09) { /* Item 2 */
   strncpy(msg->msg9.gs1, (const char *) buf+offset+2, num_bytes);
   msg->msg9.gs1[num_bytes] = '\0';
      if (buf[offset]==0x09) { /* Item 3 */
   strncpy(msg->msg9.meter_model, (const char *) buf+offset+2, num_bytes);
   msg->msg9.meter_model[num_bytes] = '\0';
      if (buf[offset]==0x06) { /* Item 4 */
   msg->msg9.act_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 5 */
   msg->msg9.act_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 6 */
   msg->msg9.react_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 7 */
   msg->msg9.react_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 8 */
   msg->msg9.curr_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 9 */
   msg->msg9.volt_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
    else if (msg->num_items==13) { /* Num records: 13 */
      unsigned int num_bytes = 0;
   strncpy(msg->msg13.obis_list_version, (const char *) buf+offset+2, num_bytes);
   msg->msg13.obis_list_version[num_bytes] = '\0';
   strncpy(msg->msg13.gs1, (const char *) buf+offset+2, num_bytes);
   msg->msg13.gs1[num_bytes] = '\0';
   strncpy(msg->msg13.meter_model, (const char *) buf+offset+2, num_bytes);
   msg->msg13.meter_model[num_bytes] = '\0';
   msg->msg13.act_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg13.act_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg13.react_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg13.react_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg13.curr_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg13.curr_L2 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 10 */
   msg->msg13.curr_L3 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 11 */
   msg->msg13.volt_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 12 */
   msg->msg13.volt_L2 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 13 */
   msg->msg13.volt_L3 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
    else if (msg->num_items==14) { /* Num records: 14 */
   strncpy(msg->msg14.obis_list_version, (const char *) buf+offset+2, num_bytes);
   msg->msg14.obis_list_version[num_bytes] = '\0';
   strncpy(msg->msg14.gs1, (const char *) buf+offset+2, num_bytes);
   msg->msg14.gs1[num_bytes] = '\0';
   strncpy(msg->msg14.meter_model, (const char *) buf+offset+2, num_bytes);
   msg->msg14.meter_model[num_bytes] = '\0';
   msg->msg14.act_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.act_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.react_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.react_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.curr_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.volt_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x09) { /* Item 10 */
   int year = buf[offset+2]<<8 | buf[offset+3];
   int month = buf[offset+4];
   int day = buf[offset+5];
   int hour = buf[offset+7];
   int min = buf[offset+8];
   int sec = buf[offset+9];
   sprintf(msg->msg14.date_time, "%d-%02d-%02d %02d:%02d:%02d", year, month, day, hour, min, sec);
   msg->msg14.act_energy_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.act_energy_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg14.react_energy_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 14 */
   msg->msg14.react_energy_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
    else if (msg->num_items==18) { /* Num records: 18 */
   strncpy(msg->msg18.obis_list_version, (const char *) buf+offset+2, num_bytes);
   msg->msg18.obis_list_version[num_bytes] = '\0';
   strncpy(msg->msg18.gs1, (const char *) buf+offset+2, num_bytes);
   msg->msg18.gs1[num_bytes] = '\0';
   strncpy(msg->msg18.meter_model, (const char *) buf+offset+2, num_bytes);
   msg->msg18.meter_model[num_bytes] = '\0';
   msg->msg18.act_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.act_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.react_pow_pos = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.react_pow_neg = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.curr_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.curr_L2 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.curr_L3 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.volt_L1 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.volt_L2 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
   msg->msg18.volt_L3 = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x09) { /* Item 14 */
   sprintf(msg->msg18.date_time, "%d-%02d-%02d %02d:%02d:%02d", year, month, day, hour, min, sec);
      if (buf[offset]==0x06) { /* Item 15 */
   msg->msg18.act_energy_pa = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 16 */
   msg->msg18.act_energy_ma = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 17 */
   msg->msg18.act_energy_pr = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
      offset+=1+4;
      if (buf[offset]==0x06) { /* Item 18 */
   msg->msg18.act_energy_mr = buf[offset+1]<<24 | buf[offset+2]<<16 | buf[offset+3]<<8 | buf[offset+4];
    else {
      return 1; /* Error - Unknown msg size */
    return 0; /* Message OK */
  return 1; /* Error - Unknown msg type */
 * FUNCTION: printMessage()
int printMessage(unsigned char *buf,
       int buf_len,
       HanMsg *msg,
       char *tm_str,
       FILE *rec_file)
  int i;
  int debug_hex = 0;
  for(i=0; i<buf_len; i++) {
    if (i>0) {
      if (debug_hex) printf(" ");
    if (debug_hex) printf("%02x", buf[i]);
    if (rec_file) fputc(buf[i], rec_file);
  if (rec_file) fflush(rec_file);
  printf("{\"Date_Time\":\"%s\",\n", msg->tm);
  if (tm_str) {
    int year, month, day;
    int hour, min, sec;
    /* FORMAT = "2017-06-07 22:25:30" */
    if (sscanf(msg->tm, "%4d-%2d-%2d %2d:%2d:%2d",
          &year, &month, &day,
          &hour, &min, &sec) == 6) {
      struct tm info;
      time_t tm_sec;
      info.tm_year = year - 1900;
      info.tm_mon = month - 1;
      info.tm_mday = day;
      info.tm_hour = hour;
      info.tm_min = min;
      info.tm_sec = sec;
      info.tm_isdst = -1;
      tm_sec = mktime(&info);
      printf("\"Meter_Time\":%1ld,\n", tm_sec);
    printf("\"Host_Time\":%s,\n", tm_str);
  switch (msg->num_items) {
  case 1:
    printf("\"Act_Pow_P_Q1_Q4\":%1d}\n", msg->msg1.act_pow_pos);
    break;
  case 9:
    printf("\"OBIS_List_Version\":\"%s\",\n", msg->msg9.obis_list_version);
    printf("\"GS1\":\"%s\",\n", msg->msg9.gs1);
    printf("\"Meter_Model\":\"%s\",\n", msg->msg9.meter_model);
    printf("\"Act_Pow_P_Q1_Q4\":%1d,\n", msg->msg9.act_pow_pos);
    printf("\"Act_Pow_M_Q2_Q3\":%1d,\n", msg->msg9.act_pow_neg);
    printf("\"React_Pow_P\":%1d,\n", msg->msg9.react_pow_pos);
    printf("\"React_Pow_M\":%1d,\n", msg->msg9.react_pow_neg);
    printf("\"Curr_L1\":%1d,\n", msg->msg9.curr_L1);
    printf("\"Volt_L1\":%1d}\n", msg->msg9.volt_L1);
    break;
  case 13:
    printf("\"OBIS_List_Version\":\"%s\",\n", msg->msg13.obis_list_version);
    printf("\"GS1\":\"%s\",\n", msg->msg13.gs1);
    printf("\"Meter_Model\":\"%s\",\n", msg->msg13.meter_model);
    printf("\"Act_Pow_P_Q1_Q4\":%1d,\n", msg->msg13.act_pow_pos);
    printf("\"Act_Pow_M_Q2_Q3\":%1d,\n", msg->msg13.act_pow_neg);
    printf("\"React_Pow_P_Q1_Q2\":%1d,\n", msg->msg13.react_pow_pos);
    printf("\"React_Pow_M_Q3_Q4\":%1d,\n", msg->msg13.react_pow_neg);
    printf("\"Curr_L1\":%1d,\n", msg->msg13.curr_L1);
    printf("\"Curr_L2\":%1d,\n", msg->msg13.curr_L2);
    printf("\"Curr_L3\":%1d,\n", msg->msg13.curr_L3);
    printf("\"Volt_L1\":%1d,\n", msg->msg13.volt_L1);
    printf("\"Volt_L2\":%1d,\n", msg->msg13.volt_L2);
    printf("\"Volt_L3\":%1d}\n", msg->msg13.volt_L3);
    break;
  case 14:
    printf("\"OBIS_List_Version\":\"%s\",\n", msg->msg14.obis_list_version);
    printf("\"GS1\":\"%s\",\n", msg->msg14.gs1);
    printf("\"Meter_Model\":\"%s\",\n", msg->msg14.meter_model);
    printf("\"Act_Pow_P_Q1_Q4\":%1d,\n", msg->msg14.act_pow_pos);
    printf("\"Act_Pow_M_Q2_Q3\":%1d,\n", msg->msg14.act_pow_neg);
    printf("\"React_Pow_P_Q1_Q2\":%1d,\n", msg->msg14.react_pow_pos);
    printf("\"React_Pow_M_Q3_Q4\":%1d,\n", msg->msg14.react_pow_neg);
    printf("\"Curr_L1\":%1d,\n", msg->msg14.curr_L1);
    printf("\"Volt_L1\":%1d,\n", msg->msg14.volt_L1);
    printf("\"Date_Time2\":\"%s\",\n", msg->msg14.date_time);
    printf("\"Act_Energy_P\":%1d,\n", msg->msg14.act_energy_pos);
    printf("\"Act_Energy_M\":%1d,\n", msg->msg14.act_energy_neg);
    printf("\"React_Energy_P\":%1d,\n", msg->msg14.react_energy_pos);
    printf("\"React_Energy_M\":%1d}\n", msg->msg14.react_energy_neg);
    break;
  case 18:
    printf("\"OBIS_List_Version\":\"%s\",\n", msg->msg18.obis_list_version);
    printf("\"GS1\":\"%s\",\n", msg->msg18.gs1);
    printf("\"Meter_Model\":\"%s\",\n", msg->msg18.meter_model);
    printf("\"Act_Pow_P_Q1_Q4\":%1d,\n", msg->msg18.act_pow_pos);
    printf("\"Act_Pow_M_Q2_Q3\":%1d,\n", msg->msg18.act_pow_neg);
    printf("\"React_Pow_P_Q1_Q2\":%1d,\n", msg->msg18.react_pow_pos);
    printf("\"React_Pow_M_Q3_Q4\":%1d,\n", msg->msg18.react_pow_neg);
    printf("\"Curr_L1\":%1d,\n", msg->msg18.curr_L1);
    printf("\"Curr_L2\":%1d,\n", msg->msg18.curr_L2);
    printf("\"Curr_L3\":%1d,\n", msg->msg18.curr_L3);
    printf("\"Volt_L1\":%1d,\n", msg->msg18.volt_L1);
    printf("\"Volt_L2\":%1d,\n", msg->msg18.volt_L2);
    printf("\"Volt_L3\":%1d,\n", msg->msg18.volt_L3);
    printf("\"Date_Time2\":\"%s\",\n", msg->msg18.date_time);
    printf("\"Act_Energy_P\":%1d,\n", msg->msg18.act_energy_pa);
    printf("\"Act_Energy_M\":%1d,\n", msg->msg18.act_energy_ma);
    printf("\"React_Energy_P\":%1d,\n", msg->msg18.act_energy_pr);
    printf("\"React_Energy_M\":%1d}\n", msg->msg18.act_energy_mr);
    break;
  printf("\n");
  return 0;
 * FUNCTION: my_read()
int my_read(int fd,
       unsigned char *buf,
       int len)
  int n;
  while (1) {
    n = read(fd, buf, len);
    if (n>=0) {
      break;
    if (errno == EAGAIN) {
      usleep(1000);
  return n;
 * FUNCTION: readMessage()
int readMessage(int read_fd,
      unsigned char *buf,
      FILE *rec_f,
      int print_hex_msg)
  int n;
  int debug;
  int length;
  debug=0;
  if (rec_f) {
    while(0) { /* dump data and exit */
      static int count=0;
      /* next byte */
      n = my_read(read_fd, buf, 4096);
      if (n>0) {
   fprintf(stderr, "*");
   fwrite(buf, n, 1, rec_f);
   fflush(rec_f);
      count+=n;
      if (count>500) {
   fclose(rec_f);
   exit(0);
  debug=0;
  while(1) { /* find start of header */
    /* next byte */
    n = my_read(read_fd, buf, 1);
    if (n==-1) {
      printf("read()==-1: errno: %s\n", strerror(errno));
    if (n<=0) return 0; /* EOF or ERROR */
    if (debug) { printf(" A(%02x)", buf[0]); fflush(stdout);}
    if (buf[0] == 0x7e) { /* good, frame start delimiter candidate */
      /* next byte */
      n = my_read(read_fd, buf+1, 1);
      if (debug) {printf(" B(%02x)", buf[1]); fflush(stdout);};
      /* 2 Byte Frame Format Field
    16 BITS: "TTTTSLLLLLLLLLLL"
    - T=Type bits: TTTT = 0101 (0xa0) = Type 3
    - S=Segmentation=0 (Segment = 1)
    - L=11 Length Bits
      if ((buf[1] & 0xa0) == 0xa0) { /* 16 bit frame format field = "0101SLLLLLLLLLLL" - Type 3 = 0101 (0xa0), S=Segmentation, L=Length bits */
   n = my_read(read_fd, buf+2, 1);
   if (debug) {printf(" C(%02x)", buf[2]); fflush(stdout);}
   length = ((buf[1] & 0x07) << 8) + buf[2]; /* length is 11 bits */
   break;
  /* read rest of message */
  int bytes_read = 3;
  int frame_delimiters = 2; /* start byte 0x7e + end byte 0x7e*/
  int bytes_left = length + frame_delimiters - bytes_read;
  while (bytes_left > 0) {
    n = my_read(read_fd, buf+bytes_read, bytes_left);
    if (debug) { printf(" M()"); fflush(stdout);}
    bytes_read += n;
    bytes_left -= n;
  if (print_hex_msg) {
    int i;
    for (i=0; i<bytes_read; i++) {
      printf("%02x ", buf[i]);
    printf("\n");
  return(bytes_read);
 * FUNCTION: decryptMessage()
int decryptMessage(uint8_t *msg,
         int msg_len,
         uint8_t *key)
  int debug=0;
  int first = 12;
  int last = msg_len - 3;
  int offset=first;
  uint8_t decrypted[16];
  while (offset<last)  {
    if (debug) printf("### remains: %1d\n", last-offset);
    AES128_ECB_decrypt(msg+offset, key, decrypted);
    memcpy(msg+offset, decrypted, 16);
    offset += 16;
  return 0;
 * FUNCTION: send_message()
int send_message(int l_fd_mcast,
       struct sockaddr_in *l_addr,
       unsigned char *l_msg,
       int l_msg_len)
  if (sendto(l_fd_mcast, l_msg, l_msg_len, 0, (const struct sockaddr *) l_addr, sizeof(*l_addr)) < 0) {
       perror("sendto");
       return -1;
  return 0;
 * FUNCTION: open_mc_send_socket()
int open_mc_send_socket(struct sockaddr_in *addr,
         char *mcast_addr,
         int mcast_port)
  int debug=0;
  int l_fd;
  /* create what looks like an ordinary UDP socket */
  if ((l_fd=socket(AF_INET,SOCK_DGRAM,0)) < 0) {
    perror("socket");
    return -1;
  /* set up destination address */
  memset(addr, 0, sizeof(*addr));
  addr->sin_family = AF_INET;
  addr->sin_addr.s_addr = inet_addr(mcast_addr);
  addr->sin_port = htons(mcast_port);
  if (debug) printf("mc send socket: %1d\n", l_fd);
  return l_fd;
 * FUNCTION: open_mc_listen_socket()
int open_mc_listen_socket(struct sockaddr_in *l_mc_addr,
           char *l_mc_host,
           int l_mc_port)
  int debug=0;
  int l_fd;
  unsigned int yes=1;
  if ((l_fd = socket(AF_INET, SOCK_DGRAM, 0)) < 0) {
    perror("socket");
    return -1;
  if (setsockopt(l_fd, SOL_SOCKET, SO_REUSEADDR, &yes, sizeof(yes)) < 0) {
    perror("Reusing ADDR failed");
    exit(1);
  if (debug) printf("mc listen socket: %1d\n", l_fd);
  memset(l_mc_addr, 0, sizeof(*l_mc_addr));
  l_mc_addr->sin_family = AF_INET;
  l_mc_addr->sin_addr.s_addr = htonl(INADDR_ANY);
  l_mc_addr->sin_port = htons(l_mc_port);
  if (bind(l_fd, (const struct sockaddr *) l_mc_addr, sizeof(*l_mc_addr)) == -1) {
      perror("bind");
      exit(1);
  struct ip_mreq l_mreq;
  /* receive */
  l_mreq.imr_multiaddr.s_addr = inet_addr(l_mc_host);
  l_mreq.imr_interface.s_addr = htonl(INADDR_ANY);
  if (setsockopt(l_fd, IPPROTO_IP, IP_ADD_MEMBERSHIP, &l_mreq, sizeof(l_mreq)) < 0) {
    perror("setsockopt mreq");
    exit(1);
  return l_fd;
 * FUNCTION: open_usocket()
int open_usocket(char *hostname,
       int port_num)
  /* tcp socket */
  int sockfd = socket(AF_INET, SOCK_STREAM, 0);
  if (sockfd < 0) {
    fprintf(stderr, "ERROR opening socket");
    return -1;
  /* server/ip address */
  struct hostent *server = gethostbyname(hostname);
  if (server == NULL) {
    printf("ERROR, no such host");
    return -1;
  struct sockaddr_in serv_addr;
  memset((char *)&serv_addr, 0, sizeof(serv_addr));
  serv_addr.sin_family = AF_INET;
  memcpy((char *)&serv_addr.sin_addr.s_addr,
    (char *)server->h_addr,
    server->h_length);
  serv_addr.sin_port = htons(port_num);
  if (connect(sockfd, (struct sockaddr *)&serv_addr, sizeof(serv_addr)) < 0) {
    printf("connect() error\n");
    return -1;
  return sockfd;
 * FUNCTION: usage()
void usage(char *pname,
      int trap)
  printf("usage(trap) ==  %1d\n", trap);
  printf("usage: %s [-i|x|n|m|M|l] [-f <filename>] [-k <decrypt-key>] [-h <hostname|ip-address> [-p <tcp port>]] [-d <device] [-P <E|O|N>\n", pname);
  printf("             -i : Print intial settings\n");
  printf("             -x : Print message in hex\n");
  printf("             -n : No logging to file\n");
  printf("             -f : Replay from file\n");
  printf("             -h : Read MBUS via TCP adapter, host/ip\n");
  printf("             -p : Read MBUS via TCP adapter, port num\n");
  printf("             -k : AES128 key in hex, 32 characters á 4 bit\n");
  printf("             -d : Read from serial device\n");
  printf("             -P : serial port byte parity N(one) E(ven) O(dd)\n");
  printf("             -m : Tx Multicast HAN messages\n");
  printf("             -M : Tx Multicast HAN messages, sleep 1s after send (when replay from file)\n");
  printf("             -l : Rx Multicast HAN messages\n");
  exit (1);
 * FUNCTION: main()
int main(int argc,
    char *argv[])
  int debug=0;
  int print_init = 0;
  int print_hex = 0;
#ifndef SERIAL_PORT
  char serial_device[100] = "/dev/ttyS0";
#else
  char serial_device[100] = SERIAL_PORT;
#endif
  char mode[] = {'8', /* bits in byte */
       'N', /* parity - E(ven), O(dd) or N(one) */
       '1', /* num stop bits */
       0}; /* end of string */
  int bdrate = 2400; /* 2400 baud */
  int read_serial = 1;
  int read_tcp_socket = 0;
  int read_mcast_socket = 0;
  int read_file = 0;
  int write_file = 1;
  int send_mcast = 0;
  int sleep_1s = 0;
  char mcast_ip_addr[100] = "239.255.199.34";
  int mcast_ip_port = 23932;
  int fd_mcast;
  struct sockaddr_in mcast_addr;
  char host[30] = "<undefined>";
  char fname[200] = "empty";
  uint8_t key[16] = {0x00, 0x11, 0x22, 0x33, 0x44, 0x55, 0x66, 0x77,
           0x88, 0x99, 0xaa, 0xbb, 0xcc, 0xdd, 0xee, 0xff};
  int port_num=10001;
  int decrypt=0;
  char *pname = argv[0];
  char *match = pname;
  while ((match = strstr(match, "/")) != NULL) {
      match++;
      pname = match;
  if (debug) printf("num args: %d\n", argc);
  int a;
  for (a=1; a<argc; a++) {
    if (strcmp(argv[a], "-f")==0) {
      if (a+1==argc) {
   usage(pname, 0);
      a++;
      strcpy(fname, argv[a]);
      read_serial = 0;
      read_file = 1;
      write_file = 0;
    else if (strcmp(argv[a], "-k")==0) {
      if (a+1==argc) {
   usage(pname, 1);
      a++;
      if (strlen(argv[a])!=32) {
   usage(pname, 99);
      int k,l;
      for (k=0, l=0; k<16; k++, l+=2) {
   char str[10];
   sprintf(str, "%c%c%c", argv[a][l], argv[a][l+1], '\0');
   unsigned int val;
   if (sscanf(str, "%02x", &val)==0) {
     usage(pname, 98);
   key[k] = val;
   if (debug) printf("str: %1s, key[%1d] = %1d\n", str, k, key[k]);
      decrypt=1;
    else if (strcmp(argv[a], "-h")==0) {
      if (a+1==argc) {
   usage(pname, 3);
      a++;
      strcpy(host, argv[a]);
      read_serial = 0;
      read_tcp_socket = 1;
      read_file = 0;
    else if (strcmp(argv[a], "-p")==0) {
      if (a+1==argc) {
   usage(pname, 4);
      a++;
      port_num = atoi(argv[a]);
      read_serial = 0;
      read_file = 0;
    else if (strcmp(argv[a], "-l")==0) {
      strcpy(host, mcast_ip_addr);
      read_serial = 0;
      read_mcast_socket = 1;
      read_file = 0;
    else if (strcmp(argv[a], "-m")==0) {
      send_mcast = 1;
      sleep_1s = 0;
    else if (strcmp(argv[a], "-M")==0) {
      send_mcast = 1;
      sleep_1s = 1;
    else if (strcmp(argv[a], "-d")==0) {
      if (a+1==argc) {
   usage(pname, 4);
      a++;
      strcpy(serial_device, argv[a]);
    else if (strcmp(argv[a], "-P")==0) {
      if (a+1==argc) {
   usage(pname, 4);
      a++;
      switch (argv[a][0]) {
      case 'E':
   mode[1] = argv[a][0];
   break;
      case 'O':
   break;
      case 'N':
   break;
      default:
   usage(pname, 4);
    else if (strcmp(argv[a], "-n")==0) {
      write_file = 0;
    else if (strcmp(argv[a], "-i")==0) {
      print_init = 1;
    else if (strcmp(argv[a], "-x")==0) {
      print_hex = 1;
    else {
      usage(pname, 5);
  if (read_tcp_socket && strcmp(host, "<undefined>")==0) {
    usage(pname, 80);
  if (print_init) {
    printf("\n###################### SETTINGS #######################\n");
    printf("read serial: %1d\n", read_serial);
    printf("  serial_device: %s, bitrate: %1d\n", serial_device, bdrate);
    printf("read mcast socket: %1d\n", read_mcast_socket);
    printf("  mcast ip: %s\n", mcast_ip_addr);
    printf("  mcast port: %1d\n",mcast_ip_port);
    printf("read file: %1d\n", read_file);
    printf("  fname: %s\n", fname);
    printf("write file: %1d\n", write_file);
    printf("read tty tcp socket: %1d\n", read_tcp_socket);
    printf("  tcp host: %s\n", host);
    printf("  tcp port: %1d\n", port_num);
    printf("decrypt messages: %1d\n", decrypt);
    printf("  key: %s\n", key);
  /* OPEN LOG FILE ? */
  FILE *rec_f = NULL;
  if (write_file) { /* read from rs232 and log to file? */
    sprintf(fname, "han-data-%1ld.dat", clock());
    if ((rec_f=fopen(fname, "w+"))==NULL) {
      printf("could not open han log file\n");
      return 1;
  int read_fd = 0;
  /* Open FILE, RS232, TCP SOCKET or MCAST (UDP) SOCKET? */
  if (read_file) {
    if ((read_fd = open(fname, O_RDONLY)) == -1) {
      printf("can't open file: %s\n", fname);
      usage(pname, 6);
    else {
      if (debug) printf("open_file OK: %1d\n", read_fd);
  else if (read_serial) {
    if ((read_fd = open_serial(serial_device, bdrate, mode)) == -1) {
      printf("Can not open rs232 port %s\n", serial_device);
      return -1;
    else {
      if (debug) printf("open_serial OK: %1d\n", read_fd);
  else if (read_tcp_socket) {
    if ((read_fd = open_usocket(host, port_num)) == -1) {
      printf("Can not open tcp socket %s:%1d\n", host, port_num);
      return -1;
    else {
      if (debug) printf("open_usocket OK: %1d\n", read_fd);
  else if (read_mcast_socket) {
    if ((read_fd = open_mc_listen_socket(&mcast_addr, mcast_ip_addr, mcast_ip_port)) == -1) {
      printf("Can not open udp mc socket: %1d\n", read_fd);
      exit(1);
    if (debug) printf("open_mc listen socket returned: %1d\n", read_fd);
  if (send_mcast) {
    fd_mcast = open_mc_send_socket(&mcast_addr, mcast_ip_addr, mcast_ip_port);
  if (print_init) {
    printf("#######################################################\n\n");
  int buf_len;
  unsigned char buf[4096];
  unsigned char buf2[4096];
  socklen_t mcast_addrlen = sizeof(mcast_addr);
  long ms; // Milliseconds
  time_t s;  // Seconds
  struct timespec spec;
  char tmstr64[100];
  while (1) {
    if (read_mcast_socket) { /* MULTICAST RECEIVE */
      buf_len = recvfrom(read_fd, buf, sizeof(buf), 0,
          (struct sockaddr *) &mcast_addr, &mcast_addrlen);
      if (buf_len < 0) {
   perror("recvfrom");
   exit(1);
      } else if (buf_len == 0) {
   break;
      if (debug) printf("%s: message = \"%s\"\n", inet_ntoa(mcast_addr.sin_addr), buf);
    else { /* SERIAL, FILE or TCP RECEIVE */
      if ((buf_len = readMessage(read_fd, buf, rec_f, print_hex)) <= 0) {
   break;
    if (verifyMessage(buf, buf_len)) {
      printf("verify failed\n");
      continue;
    /* save received buffer */
    memcpy(buf2, buf, buf_len);
    if (decrypt) {
      decryptMessage(buf, buf_len, key);
    if (send_mcast) { /* send orig buffer */
      send_message(fd_mcast, &mcast_addr, buf2, buf_len);
      if (sleep_1s) { /* only when replay from file */
   sleep(1);
    char *tm_str = NULL;
    if (1) { /* was: if (read_serial) { */
      clock_gettime(CLOCK_REALTIME, &spec); /* OR: CLOCK_MONOTONIC */
      s  = spec.tv_sec;
      ms = round(spec.tv_nsec / 1.0e6); // Convert nanoseconds to milliseconds
      strftime(tmstr64, 20, "%Y-%m-%d %H:%M:%S", localtime(&s));
      char ms_str[10];
      sprintf(ms_str, "%.ld", ms);
      strcat(tmstr64, ms_str);
      sprintf(tmstr64, "%ld.%03ld", s, ms);
      tm_str = (char*) &tmstr64;
    if (decodeMessage(buf, buf_len, &msg)) {
      if (debug) printf("decode failed\n");
      printMessage(buf, buf_len, &msg, tm_str, rec_f);
      continue;
    if (debug) printf("print done\n");
    fflush(stdout);
  return 0;
/**************************** end of file **************************************/
Wed Mar 07, 2018 1:11 pm
thomas_ja27 offline
There is also a pdf in the Dropbox folder that shows the raw data that the meter sends out.
Thu Mar 08, 2018 12:28 am
thomas_ja27 offline
Found another project that works on ESP8266
https://github.com/roarfred/AmsToMqttBridge/tree/master/Code/Arduino/HanReader
Is this easier to port over to a plug-in that supports usb connection in OSX?
Sun Mar 11, 2018 2:35 pm
Asconasny offline
i´ve just started using the esp8266 soultion. using the mqtt plugin i get a json string like
{"id":"espdebugger","up":14858642,"t":1520792650,"data":{"lv":"KFM_231","id":"6970638926877215","type":"MC304H3E","P":2780,"Q":0,"I1":9118,"I2":6673,"I3":5542,"U1":2386,"U2":0,"U3":2423}}
Anyone know a way to get this split up into variable or devices?
Like a variable just containing number 2780
Sun Mar 11, 2018 3:16 pm
#import json
jsonData = json.loads(inputString)
print str(jsonData["data"]["P"] )        # should output 2780
Mon Mar 12, 2018 5:33 am
Asconasny offline
got it working with Node-Red, problem solved :)
