Simple Examples for REST calls
Tue Sep 20, 2016 8:47 am
rbdubz3 offline
I am attempting to make some RESTful API calls in order to build scripts for manipulating OSRAM Lightify bulbs. I am a python newbie so looking for simple examples demonstrating the following:
1) making REST calls - POST/GET/DELETE/etc
2) obtaining a security auth token and re-using for subsequent RESTful calls
Thanks in advance.. I starting poking around in the Hue Plugin but I am a bit too new on Python (I've done it in java).
Any pointers appreciated
I automate because I am lazy :D - My Plugins: https://forums.indigodomo.com/viewforum.php?f=309
Tue Sep 20, 2016 5:13 pm
Re: Simple Examples for REST calls
How are you running these Python scripts?
Tue Sep 20, 2016 6:33 pm
You should definitely still answer Jay's question, but here's a sample of one way to do it.
#! /usr/bin/env python2.6
# -*- coding: utf-8 -*-
import requests
from requests.auth import HTTPDigestAuth
url = 'http://server_url_goes_here:8176/devices/Living%20Room%20%2D%20Vase?toggle=1&_method=put'
    requests.get(url, auth=HTTPDigestAuth('username', 'password'))
except KeyError, error:
    indigo.server.log(u"restful_api_example.py KeyError: %s" % error, isError=True)
except TypeError, error:
    indigo.server.log(u"restful_api_example.py TypeError: %s" % error, isError=True)
except ValueError, error:
    indigo.server.log(u"restful_api_example.py ValueError: %s" % error, isError=True)
except Exception, error:
    indigo.server.log(u"restful_api_example.py Error: %s" % error, isError=True)
Note the part of the URL that includes a device name. You'll need to format yours depending on your device's name. You'll also need to add your server IP, username and password.
Dave
Tue Sep 20, 2016 8:23 pm
rbdubz3 offline
Thanks and apologies for lack of clarity in my post.. I guess I haven't gotten that far in figuring out "How" I am gonna run it.. I was playing around with the "Scripting Shell" for now and running by command line. If I can get something working I am open to suggestions :)
Tue Sep 20, 2016 8:26 pm
I asked because you don't need to use the Indigo RESTful API if you're running scripts from Indigo. There's a much more direct object model that gives you direct access to Indigo "things" as Python objects - no need for RESTful API calls (or any kind of connectivity stuff).
If you're talking about communicating with the Lightify stuff from an Indigo Python script, then that's different. You'd need to identify what kind of API they provide and how it's authentication works. Then you can figure out how to do it in Python.
Tue Sep 20, 2016 8:48 pm
rbdubz3 offline
Gotcha.. my bad again... My goal is to use the Indigo Python object model to call these OSRAM Lightify REST APIs. So I will give the Python libs mentioned below by @DaveL17. Thanks!
Tue Sep 20, 2016 9:07 pm
rbdubz3 offline
BTW.. any tip on how to install the python packages? When using the "Open Scripting Shell" tool to run the line 'import requests' I get the error:
File "<console>", line 1, in <module>
ImportError: No module named requests
Tue Sep 20, 2016 9:16 pm
Obviously, my example is meant to show how you can control Indigo from Python (outside Indigo.) You would also need to adapt the script to the OSRAM API, and as Jay point out, the authentication method may be different.
Re: your more recent post, I should've mentioned that you'd possibly need to install the requests module. Methods (and opinions) vary, but I've had success with this approach: Open a terminal window and enter the following command:
sudo easy_install pip
and follow the prompts. After that's complete and presuming it's successful, then follow up with the following:
sudo pip install requests
This *should* do it.
Dave
Tue Sep 20, 2016 9:23 pm
rbdubz3 offline
yeah thanks Dave.. i did find some info on an older post of yours here - viewtopic.php?f=181&t=14572&p=110126&hilit=installing+modules#p100734 .. Hopefully this version of the module is ok
Tue Sep 20, 2016 11:49 pm
rbdubz3 offline
Ok.. thanks for the head start Dave and Jay.. I had some success with the Python scripts calling OSRAM REST APIs.. Able to do the following actions:
- authenticate on Osram and get a token for the Hub
- perform 'get' calls to turn groups of devices On/Off
Next Steps:
1) json parsing - I need to figure out how to use Python to parse the json responses in order to get the auth token for subsequent get calls.. The group On/Off commands issues above I just copied it by hand into the scripting tool
2) plug the script into Indigo.. I am planning to use my Insteon motion sensor to turn the Osram Lights On/Off based on whether motion is detected in the room (using Occupancy Mode)
Any tips appreciated
Wed Sep 21, 2016 3:47 am
Glad to hear that you got it working. Here's a basic example that pulls the JSON from a URL. You'll need to adapt it to work with the OSRAM return data.
import simplejson
import urllib2
f = urllib2.urlopen(url)
simplejson_string = f.read()
f.close()
parsed_simplejson = simplejson.loads(simplejson_string)
value = parsed_simplejson['title'])
Wed Sep 21, 2016 7:49 am
rbdubz3 offline
Thanks again.. I have my crude example running now.. Hooked it in by adding a trigger action to 'Execute Script' .. Try not to laugh.. but here it is.. Nothing fancy, zero error handling/etc .. Below is the one to turn 'ON' the bulbs .. I also have one working to flip them off
import requests
import simplejson
authurl = 'https://us.lightify-api.org/lightify/services/session'
authpayload = {'username': 'userlarry', 'password': 'pwddaryl', 'serialNumber': 'someserno'}
authheaders = {'Content-Type': 'application/json'}
r = requests.post(authurl, headers=authheaders, data=simplejson.dumps(authpayload))
# parse the token
parsed_authresp = simplejson.loads(r.text)
securityToken = parsed_authresp['securityToken']
onurl='https://us.lightify-api.org/lightify/services/group/set?idx=3&onoff=1'
actionheaders={'Content-Type': 'application/json', 'authorization': securityToken}
r = requests.get(onurl, headers=actionheaders)
Wed Sep 21, 2016 10:04 am
Nice! You're on your way to building a plugin.
One comment: you should use json rather than simplejson - the former is built-in to Python starting with 2.6 (which is what we're using) and the latter is a library we include with Indigo - but we won't be including it in the next version of Indigo since it's already built-in to Python now. The API is the same, just change your import line to import json
Wed Sep 21, 2016 11:41 am
rbdubz3 offline
Great.. thanks for the tip Jay.. I will swap out the json libs. Not sure about an official plugin yet but we'll see
Next tasks are as follows:
1) Move the Indigo server/setup and Lightify ON/OFF stuff to my home iMac to check stability (right now it is running on my work macbook).
2) Program an Insteon Keypad button to manipulate Lightify Bulbs in my media room - ON/OFF/COLOR for starters .. followed by dimming
3) Maybe work on holding the state of things such as color temp, brightness, etc
