Data Graphing with Initial State?
PostPosted: Sun Aug 14, 2016 8:27 am
by exos
For those that haven't found 'Initial State', it's a pretty decent IOT data grapher/streamer. I used it while experimenting with Smartthings and I was pretty happy with it's ability to track and store data. Anyone have any tips or example projects that could be used to get our data to Initial state?
Re: Data Graphing with Initial State?
PostPosted: Sun Aug 14, 2016 3:26 pm
by exos
OK folks small update. I'm thinking of sending a curl command to send variable and device state to Initial State in order to allow graphing. I have never used the restful API before. I am using the examples at initial state's restful api site. How would I integrate with this example in order to send the data?
curl --include \
--request POST \
--header "Content-Type: application/json" \
--header "X-IS-AccessKey: YOUR_KEY" \
--header "X-IS-BucketKey: curl_example_bucket" \
--header "Accept-Version: 0.0.1" \
--data-binary "[
\"key\": \"temperature\",
\"value\": \"22.2\"
\"key\": \"power\",
\"value\": \"6\"
\"key\": \"status\",
\"value\": \":thumbsup:\"
\"key\": \"current\",
\"value\": \"156\"
\"key\": \"door\",
\"value\": \"open\"
'https://groker.initialstate.com/api/events'
I know I can reach the device from here: http://localhost/devices/KingdomBee.html
I also have a list of the items under the "KingdomBee". How would I write that restful address and then how would it be inserted into the above example? When I put the address in with what I thought would work for the device it simply displayed the localhost address at initial state. When I removed the "" it failed.
