Home assistant
Wed May 11, 2016 8:43 am
aderrington offline
Home assistant
Has anyone tried using Home Assistant (https://home-assistant.io)
I'm intrigued as it seems to have multiple components that allow it to connect and talk to various services and devices such as an Amazon Fire Stick, Apple iCloud, IFTTT etc)
Could this be used alongside Indigo and integrate it somehow with indigo?
Sadly although i have some coding knowledge it's above my level.
Thoughts anyone?
Wed May 11, 2016 8:53 am
aderrington offline
Re: Home assistant
Or can anyone deconstruct the components to make something work for Indigo (so we don't have to run Home Assistant)
Wed May 11, 2016 9:30 am
Re: Home assistant
Dunno about the Fire Stick, but most any iCloud stuff should be replicable with AppleScripting.
Wed May 11, 2016 4:59 pm
Re: Home assistant
Well, one immediate problem I see is that it uses Python 3 - Indigo uses Python 2, so it would potentially require work. Also, the way they architected components is kinda stupid - rather than encapsulate support for any given technology (WeMo, Hue, etc) in one place, you have to add files in a variety of places for each device type. That means that you really need their glue code in order to make it work (at least that's my assumption without digging into actual code).
I don't know if it has an API, but if so then someone could conceivably write a plugin that would bridge devices from it to Indigo much like the Vera Bridge plugin does (or the Hue plugin, etc).
