Sun radiation/direction
Tue Aug 04, 2015 1:59 am
MarcoGT offline
Hi all,
windows in my flat are towards south and west.
In summer, in North Germany, we have sun till 2245 about.
Is there a way to get the solar incidence/radiation/direction and close/open the shades?
Anyone already tried something?
Tue Aug 04, 2015 4:01 am
Re: Sun radiation/direction
I looked at Weather Underground data, but this doesn't appear to be available via the API. I did find this site which has data for Berlin: NOAA Solar Calculator. It may have data that you can use, or at least point you to something useful.
Cheers,
Dave
Tue Aug 04, 2015 6:37 am
MarcoGT offline
Thanks, I will give it a try, but at first look I have not found anything about Hamburg in Germany.
I also found http://pysolar.org/, mentioned also on the forum, but it seems, as already said, too much.
Tue Aug 04, 2015 7:36 am
Apologies. It's Berlin and not Hamburg. Would that not be close enough?
That looks really interesting!
Dave
Tue Aug 04, 2015 1:51 pm
freshwuzhere offline
You checked out Cynical Weather? It will give you 2 of your 3 requirements for an "orientation device".
http://www.cynic.org/indigo/plugins/online/weather.html
Tue Aug 04, 2015 3:03 pm
MarcoGT offline
Very nice, this is basically what I need :) thanks :)
Wed Aug 05, 2015 11:22 pm
MarcoGT offline
Yesterday I tried with the Cynical Weather plugin and it works; I get basically and index (one for each window) between 0-100 which indicates "how much sun" I have on the windows.
Now I can play with it to adjust my shades; about that I have a question :mrgreen:
I can do for example
if index_bedroom > 80
    set shades at 50
But it could also be that later I set the shade manually at 80
At the next evaluation of "index" Indigo will set again the shade at 50 :mrgreen:
I thought I could set a variable "override" and set it to "true" when I moved the shade manually, but I have to modify all my triggers/schedules at setting that variable to "false".
How can I distinguish that the shade was moved by me and not by a schedule/trigger?
Thu Aug 06, 2015 5:11 am
You can do it with Python, but does it matter who did what? You could do something like this:
if index_bedroom > 80 and shade_level < 50:
    set shades at 50
But what might even be a bit easier is if you can come up with a simple ratio for index to shade level--say:
shade_level = index_bedroom - 30
new_shade_level = lambda(shade_level): (abs(shade_level) + shade_level) / 2
if new_shade_level < current_shade_level
    set shades at new_shade_level
which lets you use one block of code to evaluate every shade condition (the second line--the one with Lambda--ensures that new_shade_level is never a negative value.
Dave
Thu Aug 06, 2015 5:57 am
MarcoGT offline
    set shades at 50
Well, this cannot work always (if I am not missing something)
If for example index > 80 and shade < 50, the action is triggered and shade is set at 50
But then, my wife sets manually shade at 40, the Indigo set it again at 50, am I missing something?
Thu Aug 06, 2015 6:17 am
Ah. I misunderstood.
Do your shades report back a status change when someone moves them manually?
Thu Aug 06, 2015 6:22 am
MarcoGT offline
Yes, at least if with "status change report" it means that Indigo logs something.
In logs there is the changing of value (0=totally close-100=totally open)
But I think it is hard to understand who did the change, if my wife or Indigo due to trigger/schedule
Thu Aug 06, 2015 6:55 am
MarcoGT offline
Yes, yestarday I started to implement it with variable on auto/manual (or true/false)
What was missing is the schedule :)
You gave me the hint, thanks a lot :)
Thu Aug 06, 2015 7:05 am
Sorry--I hit 'submit' instead of 'preview'. :) Here's one way you can accomplish this.
    Create a variable that represents a manual override of the shade level. This can be whatever you want (true/false), (manual/auto), etc.
    Create a schedule that resets this variable to automatic mode at midnight or whenever.
    Create a trigger that changes the value of this variable to manual if a change in shade level is reported.
    Create a trigger that sets the shade level based on the radiation index only if the override variable doesn't indicate a manual override.
Each day would start with the shades in automatic mode. If someone manually changes a shade, the mode would switch to manual mode for the rest of that day. You could add additional logic based on other events (i.e., if you set your status from 'home' to 'away', resume automatic mode). You might need to put in a slight delay on the setting of the variable by the radiation trigger to account for confirmations (i.e., if Indigo changes the shade level and then the device reports back it's confirmation of the action.)
I'm not sure that I'm being clear--does that all make sense?
