[ANSWERED]: Disable log from WebServer when using REST?
Fri Apr 03, 2015 6:57 am
richo offline
I have a device that is sending commands using RESTfull every few second. Unfortunately WebServer is logging all of the calls which creates a huge and messy log file.
  Trigger                         Aktualizuj moc i licznik
  WebServer                       request to set variable "XLicznik" value to "0" from 192.168.0.171
  WebServer                       request to set variable "XPuls" value to "500" from 192.168.0.171
  WebServer                       request to set variable "XHeap" value to "10488" from 192.168.0.171
  WebServer                       request to set variable "XMoc" value to "884.52088452088" from 192.168.0.171
  WebServer                       request to set variable "XPuls" value to "501" from 192.168.0.171
  WebServer                       request to set variable "XHeap" value to "10512" from 192.168.0.171
  WebServer                       request to set variable "XMoc" value to "891.08910891089" from 192.168.0.171
  WebServer                       request to set variable "XPuls" value to "502" from 192.168.0.171
  WebServer                       request to set variable "XHeap" value to "10520" from 192.168.0.171
  WebServer                       request to set variable "XMoc" value to "871.67070217918" from 192.168.0.171
  WebServer                       request to set variable "XPuls" value to "503" from 192.168.0.171
  WebServer                       request to set variable "XMoc" value to "900" from 192.168.0.171
  WebServer                       request to set variable "XPuls" value to "504" from 192.168.0.171
  WebServer                       request to set variable "XMoc" value to "867.46987951807" from 192.168.0.171
Ryszard
Fri Apr 03, 2015 8:35 am
Re: Is it possible to disable log from WebServer when using
Not currently, but improved control over logging is on our feature request list. You can hack the file:
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/indigopy/indigodb.py
by searching for the function "def VariableSetValue" and then changing this line:
      self._Log(logStr)
to be commented out:
      # self._Log(logStr)
Note you need to stop/restart the Indigo Server for it to reload and that future installs of Indigo might overwrite the change, so you'll have to re-do it after an update/upgrade.
Fri Apr 03, 2015 9:25 am
richo offline
Re: [ANSWERED]: Disable log from WebServer when using REST?
Thanks for the quick response.
Ryszard
