[ANSWERED]Need help with scripting/programming for SMS text
Sat Dec 27, 2014 10:18 am
lochnesz offline
I would like to be able to send text messages as an action in Indigo.
I have a 3g dongle with SMS capabilities, and I control it using "terminal" and "screen". After connecting to the 3g dongle (screen '/dev/tty.GI505 Modem' 115200) I can use AT commands to send text messages. So far so good.
Now I would like Indigo to send the text messages for me when I trigger the text sending action. I would like to have variables in Indigo with phone number and text to send, also Z-wave device names etc.
Can anyone with scripting/programming knowledge help me with this?
A bonus would be if there is a way to receive text messages and control my Indigo network that way...
Mon Dec 29, 2014 12:27 pm
Re: Need help with scripting/programming for SMS text sendin
We include pyserial - which is a python library to control serial devices. I suspect if you write a script that opens that port then you should be able to write the necessary AT commands to it. You'll need to know some Python, but it's a straight-forward language really.
Mon Dec 29, 2014 12:35 pm
lochnesz offline
Thanks Jay, I am not familiar with python but I will give it a try.
(If anyone can give me a helping hand I'd appreciate it.)
Mon Jan 05, 2015 12:34 pm
lochnesz offline
Okay, I think I am on the right path, but would need some help.
This works with variables inside the script:
#!/usr/bin/env python
import serial
import time
phonenumber = "+1234567890"
message = "Test message"
ser = serial.Serial('/dev/tty.GI505 Modem', 115200)
ser.write('ATZ\r')
time.sleep(1)
ser.write('AT+CMGF=1\r')
time.sleep(1)
ser.write('''AT+CMGS="''' + phonenumber + '''"\r''')
time.sleep(1)
ser.write(message + "\r")
time.sleep(1)
ser.write(chr(26))
time.sleep(1)
ser.close()
But this doesn't work, when I try to give the python variables values from Indigo:
import serial
import time
phonenumber = indigo.variables[172971071]
message = indigo.variables[225832042]
ser.write('ATZ\r')
time.sleep(1)
time.sleep(1)
time.sleep(1)
time.sleep(1)
ser.write(chr(26))
time.sleep(1)
ser.close()
I get error: embedded script: cannot concatenate 'str' and 'Variable' objects
Anyone have a clue?
Mon Jan 05, 2015 12:45 pm
it should be:
phonenumber = indigo.variables[172971071].value
message = indigo.variables[225832042].value
See the variable documentation here
Hope this helps :)
Mon Jan 05, 2015 12:48 pm
lochnesz offline
Many thanks! Works perfect now!
Tue Jan 06, 2015 2:06 pm
lochnesz offline
Re: [ANSWERED]Need help with scripting/programming for SMS t
Here is the result of the script for sending SMS text messages via serial mobile modem.
#sms from indigo
#version 1.1
#uses pyserial
#create variable "mob_number_1" in indigo before running this script
#create variable "mob_message_1" in indigo before running this script
#create variable "mob_sms_last_run" in indigo before running this script
import serial
import time
phonenumber1 = indigo.variables["mob_number_1"].value # get the phone number from indigo variable
message1 = "S.O.M: " + indigo.variables["mob_message_1"].value + " E.O.M." # message content
indigo.server.log ("Starting sending text message to " + phonenumber1) #indigo log message
indigo.server.log ("Message to send: " + message1) #indigo log message
ser = serial.Serial('/dev/tty.GI505 Modem', 115200, timeout=2) #serial port is /dev/tty.GI505 Modem, baudrate 115200, timeout 2
ser.write('ATZ\r')
time.sleep(.5)
ser.write('AT+CMGF=1\r') #set modem to text mode
time.sleep(.5)
ser.write('''AT+CMGS="''' + phonenumber1 + '''"\r''') #send text message1 to this number
time.sleep(.5)
ser.write(message1 + "\r") #text message body
time.sleep(.5)
ser.write(chr(26)) #ctrl-z
time.sleep(1)
res = ser.read(size=256) #read result from modem
time.sleep(1)
ser.close()
indigo.server.log ("Modem result codes: " + "\r" + res) #indigo log message
localtime = time.asctime( time.localtime(time.time()) )
indigo.variable.updateValue("mob_sms_last_run", value=localtime)
indigo.server.log ("Text message sending script completed on: " + localtime) #indigo log message
