Shut down remote Windows computer
Wed Dec 17, 2014 8:53 am
DrLove offline
Hi!
I'm new to Indigo/Python/Applescripts, just converted from HomeSeer. In HS I could shut down a remote windows-computers by running "shutdown.exe -s -f -t 0 -m \\<computer name>" on the lokal HS-computer (Windows).
I have installed Samba on the Indigo computer and can run "net rpc shutdown -I 192.168.123.13 -U <PC-USER>%<PC-PSW>" in Terminal to shut down the remote computer but how do I use this in a script?
Or is there another way to use scripting (or plugin) to do this from Indigo?
Best regards, L
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Wed Dec 17, 2014 10:37 am
Re: Shut down remote Windows computer
The following AppleScript should work:
tell application "Finder" of machine "eppc://192.168.123.13"
   using terms from application "Finder"
      shut down
   end using terms from
end tell
You'll want to run it once manually - it'll prompt you for authentication from the other Mac but it can save that to the Keychain which (I think) will avoid the dialog in subsequent runs.
Wed Dec 17, 2014 2:09 pm
DrLove offline
Thanks, but the other computer is still a windows machine :(
L
Blog (in Swedish)
Sweden
Wed Dec 17, 2014 2:22 pm
OH - sorry, guess I didn't read closely enough.
You can execute that shell command thusly in AppleScript:
do shell script "net rpc shutdown -I 192.168.123.13 -U <PC-USER>%<PC-PSW>"
Thu Dec 18, 2014 1:32 am
DrLove offline
Nothing happens :( What could be wrong? "net rpc shutdown -I 192.168.123.13 -U <PC-USER>%<PC-PSW>" works from Terminal but w/ do shell script "net rpc shutdown -I 192.168.123.13 -U <PC-USER>%<PC-PSW>" in an embedded applescript nothing happens.
EDIT: I get this when I run it:
"sh: net: command not found"
/L
Blog (in Swedish)
Sweden
Thu Dec 18, 2014 8:17 am
Use the full (absolute) path to the net executable. I'm not sure what that is, but "which net" from the Terminal will probably show it for you.
Thu Dec 18, 2014 9:13 am
DrLove offline
Works!!
Love the support! Migrating from HomeSeer looks like a no brainer w/ the help from the forum.
//L
Blog (in Swedish)
Sweden
Thu Dec 18, 2014 2:22 pm
I'll be looking at adding this to my control pages - I have WOL for my PC, but shutdown for my windows server (which is essentially headless) would be cool.
Fri Dec 19, 2014 3:31 am
DrLove offline
Works great, but you will have to install Samba (OSx version of Samba does not work).
Configure PC
Install Homebrew on Mac (don't forget "brew doctor" in the end)
Install Samba on Mac (Terminal): "brew install samba"
//L
Blog (in Swedish)
Sweden
