Custom web services integration
Wed May 21, 2014 7:53 am
jasondoiron offline
Can anybody please share an example of calling a simple web service from indigo?
I have written a custom PHP software application which sits on my home web server and I'm looking for the best way to communicate with it from Indigo.
Use-case Example:
* Access data in a SQL database to view real-time dashboards in Indigo (ex. home energy usage)
Jason
Wed May 21, 2014 8:41 am
Re: Custom web services integration
Any Python example of a web service consumer would work since Python is the primary scripting and plugin environment.
Thu May 22, 2014 9:18 pm
vtmikel offline
I do a lot of this, you might want to take a look at the NEST plugin I built for an example of calling a web service. Alternatively, for a external app to communicate with Indigo, I use a plugin that can create Indigo devices based on JSON objects which can hold state. You can update the state by publishing JSON updates to indigo. This requires some additional hardware and software configuration outside of indigo though. I can't guarantee it will plug and play for you, but you might get some ideas from the code.
