Is this the end of Gmail for Home Automation?
Sat Oct 01, 2022 9:05 am
nanochow offline
Re: Is this the end of Gmail for Home Automation?
madscientist wrote:
Kzintar wrote:
Thanks for the confirmation that you've previously been successful with iCloud. I'm more certain than ever that the problem is that I have something wrong with my Email+ SMTP configuration.
I'll keep experimenting!
K.
I was having the same problem setting up SMTP. My gmail account settings didn't work, even with setting up a separate application password. My icloud account also didn't work, with or without using an application password. I tried just about everything and was ready to give up and set up something via node-red. But before I did I created a second email+ SMTP device using the same settings that failed previously, and I deleted the original STMP device. It worked! So before giving up, try deleting the device from Indigo and starting over.
Awesome! That worked. Thank you :-)
