AppleTV and PS4
Sun Apr 23, 2017 8:14 pm
pmgendon offline
AppleTV and PS4
Hey guys,
I was wondering if there is any way to integrate an AppleTV 4th gen and a PS4 in indigo?
thanks
pm
Mon Apr 24, 2017 3:59 am
durosity offline
Re: AppleTV and PS4
What do you want to accomplish? If it’s just control then probably the easiest option would be a Logitech Harmony Hub. AFAIK there’s no way of reading current states from the AppleTV or PS4 (unless it’s a jailbroken AppleTV 2).
Sat Dec 22, 2018 8:07 am
davinci offline
Re: AppleTV and PS4
Actually, now there is a way for Apple TV:
https://github.com/jeanregisser/mediaremotetv-protocol
Sat Dec 22, 2018 8:44 am
durosity offline
Re: AppleTV and PS4
Awesome! Who wants to write a plugin?
Tue Dec 25, 2018 3:18 am
davinci offline
Re: AppleTV and PS4
That would be nice.
I found an "easier" library to directly access Apple TV. Looks promising. Not sure if it is required to install the python libraries or if they can be integrated.
https://github.com/postlund/pyatv
Thu Dec 27, 2018 11:31 am
Re: AppleTV and PS4
davinci wrote:
That would be nice.
Requires Python 3, so while you might be able to get it to work in a round about way, it won't likely be a generic plugin integration.
Fri Dec 28, 2018 2:11 pm
davinci offline
Re: AppleTV and PS4
Thanks for the clarification.
Is it possible to use a Python script inside of Indigo (external script)?
I have to find a way to install it on Mac, because the guide only covers Linux.
Fri Dec 28, 2018 2:48 pm
Re: AppleTV and PS4
You're gonna want to be VERY careful. 3rd party Python installers will often screw up Python paths that cause the built-in Python 2.7 (and therefore Indigo's Python integration) to break.
Sat Dec 29, 2018 9:44 am
davinci offline
Re: AppleTV and PS4
Yes I am aware of this. Is it possible to use those libraries without actually installing? Kind of like sandboxing. I know it works for individual python files but I'm not sure about this.
It might be overkill for my use case since I only need the GUID and I can wake up Apple TV anyway. The script can also read the GUID.
Sun Dec 30, 2018 6:42 am
davinci offline
Re: AppleTV and PS4
I can't get it to run. I was testing in a virtual machine but it can't find the Apple TV.
Any ideas how to get the GUID without setting up a real linux?
Mon Dec 31, 2018 5:43 pm
Re: AppleTV and PS4
I found a post on the net that indicated that you should use the ATV's serial number as the GUID (which you can get in the About screen). Give that a try.
