Sun radiation/direction
Hi all,
windows in my flat are towards south and west.
In summer, in North Germany, we have sun till 2245 about.
Is there a way to get the solar incidence/radiation/direction and close/open the shades?
Anyone already tried something?
Re: Sun radiation/direction
I looked at Weather Underground data, but this doesn't appear to be available via the API. I did find this site which has data for Berlin: NOAA Solar Calculator. It may have data that you can use, or at least point you to something useful.
Cheers,
Dave
Cheers,
Dave
Thanks, I will give it a try, but at first look I have not found anything about Hamburg in Germany.
I also found http://pysolar.org/, mentioned also on the forum, but it seems, as already said, too much.
Apologies. It's Berlin and not Hamburg. Would that not be close enough?MarcoGT wrote:Thanks, I will give it a try, but at first look I have not found anything about Hamburg in Germany.
That looks really interesting!I also found http://pysolar.org/, mentioned also on the forum, but it seems, as already said, too much.
Dave
You checked out Cynical Weather? It will give you 2 of your 3 requirements for an "orientation device".
http://www.cynic.org/indigo/plugins/online/weather.html
Very nice, this is basically what I need thanks
Yesterday I tried with the Cynical Weather plugin and it works; I get basically and index (one for each window) between 0-100 which indicates "how much sun" I have on the windows.
Now I can play with it to adjust my shades; about that I have a question
I can do for example
But it could also be that later I set the shade manually at 80
At the next evaluation of "index" Indigo will set again the shade at 50
I thought I could set a variable "override" and set it to "true" when I moved the shade manually, but I have to modify all my triggers/schedules at setting that variable to "false".
How can I distinguish that the shade was moved by me and not by a schedule/trigger?
if index_bedroom > 80
set shades at 50
You can do it with Python, but does it matter who did what? You could do something like this:MarcoGT wrote:How can I distinguish that the shade was moved by me and not by a schedule/trigger?
if index_bedroom > 80 and shade_level < 50:
set shades at 50
shade_level = index_bedroom - 30
new_shade_level = lambda(shade_level): (abs(shade_level) + shade_level) / 2
if new_shade_level < current_shade_level
set shades at new_shade_level
Dave
Well, this cannot work always (if I am not missing something)DaveL17 wrote: You can do it with Python, but does it matter who did what? You could do something like this:
if index_bedroom > 80 and shade_level < 50: set shades at 50
If for example index > 80 and shade < 50, the action is triggered and shade is set at 50
But then, my wife sets manually shade at 40, the Indigo set it again at 50, am I missing something?
Ah. I misunderstood.
Do your shades report back a status change when someone moves them manually?
Yes, at least if with "status change report" it means that Indigo logs something.DaveL17 wrote:Ah. I misunderstood.
In logs there is the changing of value (0=totally close-100=totally open)
But I think it is hard to understand who did the change, if my wife or Indigo due to trigger/schedule
Yes, yestarday I started to implement it with variable on auto/manual (or true/false)
What was missing is the schedule
You gave me the hint, thanks a lot
Sorry--I hit 'submit' instead of 'preview'. Here's one way you can accomplish this.
I'm not sure that I'm being clear--does that all make sense?
- Create a variable that represents a manual override of the shade level. This can be whatever you want (true/false), (manual/auto), etc.
Create a schedule that resets this variable to automatic mode at midnight or whenever.
Create a trigger that changes the value of this variable to manual if a change in shade level is reported.
Create a trigger that sets the shade level based on the radiation index only if the override variable doesn't indicate a manual override.
