call a .py file from within Indigo and supply an argument
Mon Aug 15, 2016 6:36 pm
ryanbuckner offline
I want to call ./bmwpost.py 'LOCK_DOOR' from Indigo but I'm running into some issues and I'd love some help:
1) It appears I have python 2.6 and 2.7 installed based on an upgrade to El Capitan. My requests module will not run in 2.6 for some reason and I'm not sure how to fix that. Therefore a call from terminal runs fine, but tells me requests has not been installed when trying to run from Indigo
2) My workaround (is very newb but it kinda works, is to have Indigo launch a terminal window and call the .py with arguments, then close the terminal window. This works, however it has some real downsides:
a) there's no interaction with Indigo to populate variables , log, or anything else
b) it's just an API call to BMWs API but it takes the IndiogServer offline for about 30-50 seconds while it's running.
I'm sure this is all easy, but I'm new in the python environment so I would appreciate some detailed help if changing paths or profiles is involved.
Thanks in advance!!!!
Mon Aug 15, 2016 6:48 pm
Re: How do I call a .py file with an argument from Indigo
sudo easy_install-2.6 pip
sudo pip2.6 install requests
Mon Aug 15, 2016 8:12 pm
ryanbuckner offline
Re: call a .py file from within Indigo and supply an argumen
Thanks so much! That helped.
Now how can I call that file and send an argument :
I want to call
python /My Path/bmwpost.py 'LOCK_DOOR'
Tue Aug 16, 2016 6:03 am
ryanbuckner offline
Also, if you are willing to help more (thank you)!When calling from Indigo, If I try to import bmw.py from another script it throws an import statement. From terminal it works.
Tue Aug 16, 2016 6:12 am
Need to see the actual error messages, and maybe the scripts as well.
I don't think there's a way to provide arguments to an external script called from Indigo. But I'm not sure since I don't use any. If it was me, I'd edit the script to either not need the argument or to get it from an Indigo variable.
Tue Aug 16, 2016 7:25 am
[edit] added more code
import subprocess
# var_name1 2 are the input variables
p1 = indigo.variables["var_name1"].value
p2 = indigo.variables["var_name2"].value
ret=subprocess.Popen("/usr/bin/python  /users/yourid/ypgm "+p1+" "+ p2,shell=True,stdout=subprocess.PIPE, stderr=subprocess.PIPE)).communicate()
## result result is name of variable for the return value
indigo.variable.updateValue["result",ret[0]]
inside your py program
import sys
p1= sys.argv[1]  # these are strings
p2 = sys.argv[2]
out= p1+p2
print " this is your output " + out
Then ret[0] has the std out = "this is your output " + out
and ret[1] std err output
Tue Aug 16, 2016 9:03 am
ryanbuckner offline
Thanks all!
I have the py accepting and using the arguments. I'm struggling on the call to the .py from Indigo.
In terminal I would type ./bmwpost.py 'LOCK_DOOR'
Tue Aug 16, 2016 9:37 am
You need to use the full path. Like in the example
When opening a shell from indigo it does not know your path.
Tue Aug 16, 2016 9:39 am
If your pgm is in your home dir it would be
/users/yourid/bmwpost.py lock_door
Tue Aug 16, 2016 10:55 am
ryanbuckner offline
much appreciated. I'll give it a shot.
Fri Aug 19, 2016 6:22 am
Gusten offline
Hi
Is there anyway you can share the .py script?
I am in a similar situation and would like to see the script so i can understand and mayby solve my issues
Thanx
Martin
Tue Oct 11, 2016 8:41 am
ryanbuckner offline
Happy to share.
You can find the .py here:https://github.com/edent/BMW-i-Remote
instructions on how to get your Auth Codes for the API here : https://shkspr.mobi/blog/2015/11/reverse-engineering-the-bmw-i3-api/
What I'm struggling with is probably simple. Just getting the .py to run as an attachment.
